Old 01-19-2020, 07:53 PM   #155
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Originally Posted by Inazuma in NS View Post
Anyone had luck with photos via USB and adding a custom background?
***nevermind found it. Needed a subfolder and it worked
There are some folks ( paging @Juzzotec ) who would like to know how you made this work!
Did you use something like the following on your USB drive:
Anything special about the photo like limiting the file size or the dimensions of the image?
Was the photo a .jpg file or something else?
Where did you go in the Pioneer setup to do this?
Thanks!
LimitedSlip is offline   Reply With Quote
Old 01-19-2020, 10:22 PM   #156
Juzzotec
Juzzotec's Avatar
Drives: Toyota 86 GTS
Thanks!
@LimitedSlip How does it look once you set a custom background... pixelated?
Juzzotec is offline   Reply With Quote
Old 01-20-2020, 04:55 PM   #157
Inazuma in NS
Inazuma in NS's Avatar
Drives: 2017 BRZ Inazuma
It was quite simple actually....formatted a USB stick using Fat32. Originally I added the files and it wouldn't work until I created a folder named "Photos", once i did that it actually read all my photo's and no it doesn't look pixelated. It did stretch out a couple of them....its close to 800x400 pixels. I'm playing to find the perfect size but I have several already done that look great but I want to try and make it look perfect.
As for where....thats pretty simple too. Several uTube videos describe how on AVH models. Select the USB from the media type...it will file your photos. The first time I plugged it in it took a minute, I think it creates its own directory almost...one utube video said manually create one but I think it worked automatically. Then there is a button that looks like download (bottom left), click that and it takes a minute to save it and you chose which screen you want it saved on. You can only save one picture on the radio. Once I figured it out the process took less than 2 mins. File format I used was jpeg and as for file size I had various sizes and all worked. Here is one of the video's from uTube.
I'd post a picture of it in my dash but chose a "naughty" picture and wouldn't want to offend anyone It's almost as perfect as on my iPad in terms of resolution (to what my eyes can see) I'm sure pixel count varies in the actual display.
[ame]https://www.youtube.com/watch?v=odAhX26wft0[/ame]
Inazuma in NS is offline   Reply With Quote
Old 01-20-2020, 07:13 PM   #158
Inazuma in NS
@Juzzotec
Sorry I just went back and read over the whole thread and saw some of your previous issues. I didn't see any real pixelation on the majority of my files.
Here are some sample pictures I just went and took.
https://photos.app.goo.gl/n8N3VvWv2XJtitmE8
640x480 72dpi 77KB
https://photos.app.goo.gl/oBJZ1Ey8gFcSxKLKA
1440x900 96dpi 363KB
https://photos.app.goo.gl/dfzfckumy4mjfGeX7
1980x1080 96dpi 285KB
The pictures are off a bit as any pictures you take with a camera of a LCD monitor and some small horizontal lines but you really don't see that when viewing normally. Have you watched a movie using a USB? Mine plays in High Def in a widescreen format that's as good as watching it on my computer monitor with 0 distortion.....
I did notice some pictures I thought would be perfect size in width didn't stretch as I thought and the display added some blank height with a black strip top and bottom approx 3/4 of an inch. I'm assuming that the pixel height is the main factor when it resizes the aspect....however the three pictures I posted are almost identical to their original aspect ratios.
update...playing with some different ratios and sizes, a ratio of 4:3 seems best so far without compression. Ideal dimensions 640px x 480px. My first picture is exact to the original.
Old 01-21-2020, 02:04 PM   #159
Inazuma in NS
@Juzzotec
640x480 72dpi 77KB
I should note this centers the image and does leave a gap on each side....if you are trying to do full screen I havent quite perfected the size....ratio of 5:3 seems close for full screen
Old 01-21-2020, 02:46 PM   #160
LimitedSlip
The HU specs indicate the display has an aspect ratio of 16:9 and a screen resolution of 800 x 480 (which would appear to be a 15:9 aspect ratio). If we take a ratio of 5:3 and multiply by 3 (so as to have a common denominator of 9) the result is 15:9. So, a .jpg of 5:3 really should fit pretty well on the display.
Old 05-27-2020, 11:00 PM   #161
Rako
Drives: 2023 GR86 M/T
Has anybody experienced regional limitations since this is an Australian unit?
Rako is offline   Reply With Quote
Old 05-27-2020, 11:08 PM   #162
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
FM frequencies probably won’t play very nice. Other than that it should be fine, as long as you install it upside down.
Old 05-28-2020, 10:37 AM   #163
Nails
Drives: 2016 FR-S (Halo MT)
I don't listen to the radio much, but I get all of the larger stations within my area on my AVH-ZL5150.
One tip if you get the head unit, make sure the antenna is powered when you wire everything together. I made that mistake initially and the reception was very poor as a result.
Nails is offline   Reply With Quote
Old 05-28-2020, 02:55 PM   #164
LimitedSlip
From the Owners Manual pages 22 and 68. It works fine in the U.S.
Old 06-13-2020, 01:10 AM   #165
fatboydean
Drives: 2016 BRZ Hikari
haha my car is Canadian DM 2016 BRZ which harness should I choose?
fatboydean is offline   Reply With Quote
Old 06-13-2020, 07:24 PM   #166
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Choose the 13-15 harness.
JBezugs is offline   Reply With Quote
Old 05-03-2021, 12:05 AM   #167
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I just installed the AVH-ZL5150 using the compete AutoHarnessHouse kit and my FM reception is horrible. I don't think I missed any connections, how can I check the antenna is powered?
Old 05-03-2021, 10:00 AM   #168
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Read through this.
https://www.ft86club.com/forums/showthread.php?t=141915
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Looking for suggestions on what carplay compatible head unit to get. wparsons Electronics | Audio | NAV | Infotainment 8 03-02-2018 08:09 AM
Android head unit drz400dude Electronics | Audio | NAV | Infotainment 6 12-20-2016 12:47 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 08:48 PM
New 200mm head unit from Pioneer AVIC-F7302 Clot Electronics | Audio | NAV | Infotainment 8 09-16-2014 11:39 AM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
