Old 06-06-2017, 10:41 PM   #155
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
Originally Posted by Sportsguy83 View Post
Me neither but he's running 2000cc injectors, really don't know if it makes htat much of a difference.
Jeeeezus 2000CC!
To test if it's injector related, you could swap in the stock injectors and get a tune mapped for them. That will at least tell you if that is the issue.
I'd hate to see you flying someone out to and have it turn out to be something simple as that!
COO86L is offline   Reply With Quote
Old 06-07-2017, 08:44 PM   #156
Kris86
Kris86's Avatar
Drives: RHD Gt86
Originally Posted by COO86L View Post
Jeeeezus 2000CC!
I'm actually running 900cc Deatschwerks injectors..
I could definitely swap them out for the stock ones but would my injectors cause a vacuum leak for real tho ?
Appreciate your help and suggestions
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 06-08-2017, 09:44 AM   #157
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by Dipstik-sportech View Post
The initial startup rough idle is caused by it firing up on larger than stock port injectors. Mines done it for years, you get use to holding the throttle a bit for 20-30sec until it kink onto the direct injectors.
That's good to know. My new motor does this on every startup regardless of temps. Rough idle, stalls unless you hold about 1500 rpm. You can tell when the ECU gets it sorted out cause it blips the throttle then then idle slowly settles down to 900 rpm and smooth as can be after that. If the car has only been off for 10 minutes or so this does not happen. I'm running ID1000's.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
Kris86 (06-08-2017)
Old 06-08-2017, 09:48 AM   #158
Deep Six
Deep Six's Avatar
Additionally, James was data logging my car and adjusting the tune after the new motor went in and he was showing me issues with the cam timing, possibly VVT related during this startup issue. He did not know why it was happening but it would resolve itself every time and the readings went back to normal.
[SIGPIC][/SIGPIC]
Kris86 (06-08-2017)
Old 06-08-2017, 01:46 PM   #159
Kris86
Kris86's Avatar
Drives: RHD Gt86
who is your tuner?
can you PLEASE check and see what your map sensor is reading at idle for me?
what compression ratio engine are you running?
Old 06-09-2017, 08:13 AM   #160
Deep Six
Deep Six's Avatar
Originally Posted by Kris86 View Post
who is your tuner?
James (HRI Tuning) is my tuner and the motor was built by Rev Works. I chose 11.5 compression ratio because I wanted a little more room for additional boost without seriously compromising off boost performance.
I would give Scott at RevWorks a call. They have built probably a hundred plus FA20/EJ25's and he also has Mike (M Tuned) in his shop on a regular basis.
http://www.revworksinc.com/
https://www.hrituning.com/
[SIGPIC][/SIGPIC]
Kris86 (06-09-2017)
Old 06-11-2017, 03:10 AM   #161
COO86L
COO86L's Avatar
Sorry I haven't read word for word your whole post but what is your current vacuum level at warm idle (if you can maintain warm idle)?
Those DW 900's are fairly bulky injectors but shouldn't cause this much issue as they've been used quite often. I'd definitely at least try swapping OEM injectors and changing map to suit just as a test. Easy way to rule it out.
As to vacuum, I'd hook up an external vacuum gauge to a vacuum source just to see what it's coming back with.
As I believe a couple people have stated, leak down etc looks normal for a fresh engine. Have you done any break in what so ever, any moderate loading to bed the rings in? Engine hasn't idled at operating temperature for extended periods of time before rings bedding in? This could cause low compression etc due to poor ring bedding. Id also try running the engine in on the dyno (moderate load, 50% throttle then 75% throttle) or however your engine builder recommends and check everything again.
The Following User Says Thank You to COO86L For This Useful Post:
Kris86 (06-11-2017)
Old 06-11-2017, 03:43 PM   #162
Kris86
Kris86's Avatar
Drives: RHD Gt86
Thank you so much for your help and input, I really appreciate it.
We thought it could be the rings being gapped to much, so we pulled the motor and changed the rings for a fresh set. Nothing changed.
We have not really done any breaking in THB, we have taken the car for a 5 minute drive here and there, and had it idling doing fifteen minute data logs here and there.
Was just trying to get a good tune in to be able to drive it around and break it in properly.
Symptoms are, The car starts but has a hard time idling when cold, but when it does warm up, it idles on its own and I can lock it off and turn it back on with out any throttle assistance.
I was just told that due to the poor vacuum the map cannot be cleaned up any further
Old 06-11-2017, 09:52 PM   #163
COO86L
COO86L's Avatar
What were the rings gapped to?
Honestly if it's running fine when warm, I'd be bedding those rings in asap. You don't want to run it at low loads or idle for too long or the bore surface that the rings bed to will be too smooth to bed the rings in.
Provided it's running and not showing any signs of knock etc I'd run it up, get to around 3000rpm and throttle at 50% and apply load with dyno. Do this for a time then return to idle to give engine components time to cool, then repeat at about 75% throttle 3000rpm and load from dyno to hold it there.
Let it cool etc, swap out fluids and then look into your tuning issues.
Of course this is the procedure I use. But if anyone has issue with it such as your tuner or engine builder, then I'd apply the logic they want to see for bedding the rings in.
The Following 2 Users Say Thank You to COO86L For This Useful Post:
Kris86 (06-12-2017), Sportsguy83 (07-03-2017)
Old 06-12-2017, 09:44 AM   #164
Kris86
Kris86's Avatar
Drives: RHD Gt86
The top ring was gapped too .017 and bottom ring was gapped to .019 ( CP pistons )
Is there any way I would be able to do such breaking in on the road instead ? I know it would be a lot easier on a dyno but I kinda wanted to save the dyno time for when the tuner is actually flown in.
Thank you again for such detailed explanations,
Again I do truly appreciate it greatly
Old 06-12-2017, 09:49 AM   #165
COO86L
COO86L's Avatar
For road only I'd try both of two methods
1. Flog the absolute shit out of it! Not so much redline every gear but don't baby it. High load is good
2. Brake loading. This requires a good stretch of road etc that you can apply throttle as well as the brake to increase load on the engine while also keeping rpm low. You have to be mindful of engine heat as well as brake heat. You don't want to overheat your brakes nor your engine.
Old 07-07-2017, 06:15 PM   #166
COO86L
COO86L's Avatar
Any update as to how you're going?
Old 07-08-2017, 07:47 PM   #167
Kris86
Kris86's Avatar
Drives: RHD Gt86
Hey bro, I really appreciate your concerns
So I bought a new compression tester this week and just did a new test today. @FRS Justin @Amputechture @GsxrMe @Dipstik-sportech @Moto-Phil
Cyl # 1 = 139
Cyl # 2 = 138
Cyl # 3 = 140
Cyl # 4 = 135
So I guess my old gauge or hose has a issue......
And I also guess that rules out the compression taking the blame for the low vacuum
Only problem is I still have my vacuum issue and it hasn't gotten any better and is still causing havoc with the tuning.
Old 07-09-2017, 06:31 AM   #168
BRX
BRX's Avatar
Drives: Toyota GT86
I read the whole thread hoping to see results to compare to my own build.
Have you replaced the damaged compressor seal you posted before? It's supposed to go around the plate behind the blades and not on the housing. A bit obvious but you never know.
I see you are venting the crankcase to the atmosphere. What have you done to the intake manifold and EVAP hoses? I suggest you plug them off and delete them. I deleted my PCV solenoid as it can't hold much boost. I would recheck all the hoses as there might be a simple misplaced hose that's hooked up in the wrong location.
You could also double check your fuel system as it is no longer a returnless system. Your fuel regulator needs a vacuum line to function correctly, at least on my other builds it did. Not sure how the FBM kit works but I'm pretty sure it needs a boost source at least.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 07:44 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 01:06 PM
Most effective ways to make a "fast" NA car Kronos Engine, Exhaust, Transmission 68 02-16-2014 01:59 PM
XSXV: Nissan R34 Skyline from "Fast and Furious" goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 10-25-2012 04:15 PM
come and hoon they say.... it will be "like Fast and the Furious", they say... davey90 AUSTRALIA 5 10-23-2012 12:11 AM
