Old 06-06-2017, 11:00 PM   #16745
zeal86
zeal86's Avatar
Drives:
Looking at your plate thingy there, I suggest you include the pulley cover on the right side. I think it will look much more complete and offer some good attachment points
Sent from my XT1575 using Tapatalk
I actually hadn't thought of incorporating the pulley cover... I'll have to look into that... I may like it. Thanks.
It is still a work in progress... just a preliminary template.... there will be many tweaks to my cover.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-07-2017, 08:01 AM   #16746
randomthoughts
Drives: 2014 White BRZ
I just asked the same thing on ur build thread lol
randomthoughts is offline   Reply With Quote
Old 06-07-2017, 12:23 PM   #16747
MJones_RB
MJones_RB's Avatar
More work on my Alt/Comp cover...
I also started researching how to go about making Door Strap Pulls today. I found some good info on the net. I have two ideas that I'm debating. If I'm successful, expect a write-up sometime in the future.
Since I received some parts today, I now have some straight forward installs and some fabrication heavy installs...I wish I had more time!
Man, I always love your posts!
MJones_RB is offline   Reply With Quote
Old 06-07-2017, 04:03 PM   #16748
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Here are godSnow pulleys installed.
Stock Pulley set up weights 6.25 lbs
New pulleys weight 1.3lbs
To get the old pulleys off I kept the belt on first to get the bolts on the Alt, And Water loosened. I did not need air ratchet on the Alt bolt using this method. I need my trusty 4ft Iron Pipe over my breaker to get the Crank loose. Pulled so much I got the wheels to move slightly then it finally broke
Forgot to take pic with air intake out of the way.
Great way to save nearly 5lbs reciprocating mass. And I don't see the need to spend any more on namebrand pulleys. Overrall quality was very good some slight nicks on the outer edges counted maybe 5 between the 3 pulleys, everything on the belt drive areas where smooth.
SuperTom is offline   Reply With Quote
Old 06-07-2017, 05:50 PM   #16749
SuperTom
SuperTom's Avatar
My day is not over just installed these Perrin Control Arm Braces got them on the Perrin Garage Sale on ebay $35. Otherwise I wouldn't spend big money on something like this.
Perrin 10.3 oz
Stock 15.2 oz
Simply jack up front. Unbolt old ones, Slide on new ones, Red Threadlock, bolt to spec
Don't know if they will do much but seem more robust and 5oz lighter at the same time.
Old 06-08-2017, 02:02 PM   #16750
Teseo
Drives: frs
Old 06-08-2017, 04:57 PM   #16751
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That is not reciprocating mass. It is ROTATING mass which is why pulleys are an aesthetic mod only.
Old 06-08-2017, 05:09 PM   #16752
MJones_RB
MJones_RB's Avatar
PERRIN GARAGE SALE?!?
Old 06-08-2017, 06:44 PM   #16753
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Did not do this for the car or with it in mind, but picked up a watch and came to realize when I cracked it open that it actually matches the car's interior theme pretty well.
Faux CF, red stitching, etc.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 06-08-2017, 07:00 PM   #16754
SuperTom
SuperTom's Avatar
yep just type in perrin sale on fleabay and stuff will pop up
Old 06-08-2017, 07:56 PM   #16755
StraightOuttaCanadaEh
Wes
Got annoyed at how prominent the torque dip has been feeling recently. Can't figure out what it is. Increased familiarity and awareness for the car? Dirty air filter from all the pollen? Warmer weather? AC was on? Anyone ever noticed that? Been driving it 8K and it's never been this obvious. It almost feels like the car is being held back by TCS, although I'm in track mode.
Old 06-08-2017, 08:18 PM   #16756
new2subaru
Weight Weenie
Drives: 15 FR-S
Although it could be anyone of the things you mentioned or all of them, based on the mileage and the recent temps, I think it's familiarity and awareness. I'm going through the same thing at 15K.
Old 06-08-2017, 08:24 PM   #16757
Wes
I'm leaning towards those two as well. Although another owner was telling me recently how the 2017 86 doesn't have a torque dip and it's zippy, and I can very clearly detect one. Still firmly present lol
Old 06-08-2017, 08:28 PM   #16758
new2subaru
Weight Weenie
Drives: 15 FR-S
lol I still think the car is zippy, but the longer I drive it the more I look down and find myself above 4k consistently. It's helping!
