Old 06-03-2017, 07:29 PM   #16717
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by pcuerpo View Post
finally installed my Auto Craft Evolution gauge panel
How much plastic did you have to cut out, and does it screw in?
Old 06-03-2017, 07:31 PM   #16718
Ashikabi
Ashikabi's Avatar
It's a gauge pod. It replaced the stock panel
Sent from my XT1575 using Tapatalk
Old 06-03-2017, 08:36 PM   #16719
Sapphireho
Famous Potatoes
Sapphireho's Avatar
And there is plastic right behind that stock panel you have to cut, or that Guage pod would stick out 3 inches or more.
Old 06-03-2017, 09:17 PM   #16720
Ashikabi
Ashikabi's Avatar
Oh I gotcha
Old 06-04-2017, 11:30 AM   #16721
NOI
NOI's Avatar
Drives: 2 Subarus and a 2013 FRS
Put on some new Bosch Icons. The guys at OReilly got a kick out of the car. Only one knew what it was and the was the grey hair...weird.
NOI is offline   Reply With Quote
Old 06-04-2017, 12:00 PM   #16722
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Had the car detailed...steam cleaned the engine bay
N1rve
Old 06-04-2017, 02:23 PM   #16723
arxm
Drives: 2013 FR-S, 2023 BRZ
so I've been looking at lowering springs as I just daily my car and want to reduce some wheel gap and have been looking at the Eibach Sportlines. Ive read lots of good things about them and feel like 1.4" is a perfect drop as it should close the gap but leave some room for travel. My one question is if 1.4" is too much for the stock struts. Ive tried looking into this but I've seen very conflicting things being said, some people say its fine some say to upgrade shocks, my car only has 120k km (75k miles) and I don't think the shocks are near their end of life. Can anyone provide some insight to a novice on what the best course of action would be?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 06-04-2017, 03:48 PM   #16724
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
When you reduce the travel of the shocks, they don't work as well. Suspension travel is very important to the handling. When you lower the car on the stock shocks (struts, dampers, shocks, they are all interchangeable terms) and reduce suspension travel you don't do anything for the car's handling performance and the limited travel will reduce the life span of the shocks too.
If the ride is OK for you and performance is not important just keep the stock shocks until they blow out. Some aftermarket shocks may be engineered with extra suspension travel and won't suffer the same performance degradation and may even improve the car's handling. I haven't looked into it much so I don't know which shocks are best for an 86 on lowering springs.
Old 06-04-2017, 06:51 PM   #16725
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Started driving, everything seemed fine until I had to merge onto a 35 mph street and blah, nothing. No power. Somehow I put it into valet mode. Boy, thought something went out.
Old 06-04-2017, 11:25 PM   #16726
jorgerendonjr
Drives: Frs
Got my TRD on today, starting with a nice pair of rims and then on the interior side of things I got the seat gap fillers and seat belt pads for both passenger and driver side. Finally got to installing the oem sliding arm rest, and a new pair of smoked intec carbon tail lights (ferrari look alikes)
jorgerendonjr is offline   Reply With Quote
Old 06-04-2017, 11:38 PM   #16727
zeal86
zeal86's Avatar
Drives:
So I started my Alternator/Condenser cover fabrication tonight. I'm just roughing it out right now...I plan on making a one piece design. So far I have only focused on the alternator side.
This is what my template looks like so far...
(I'll probably fab a cover for the alternator cable when I get going on this again...)
Btw, the final product will be made out of aluminum... I'll probably paint it Beatrush gold to break up all the polished parts... I feel if I polish it, it will be too much bling in one area.
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 06-05-2017, 11:06 AM   #16728
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
this is the amount that should be cut based on the manual
and yes, they are screwed which i had problems with since i couldnt remove the cover of the glove compartment.. i already removed the center console, radio, a/c controls but it seems that i have to go all the way until the steering wheel part? so once i was able to screw the upper left and bottom right from the back, i installed everything back and probably have a shop screw the other corners instead
EDIT:
here is the actual pic of what was cut at the back
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 06-05-2017, 09:55 PM   #16729
arxm
on my accord i was planning on doing springs and koni yellow's which is what ill probably end up doing on this when the shocks go, Thanks for the insight
Old 06-05-2017, 10:22 PM   #16730
NOI
NOI's Avatar
I embarrassed it.
Had some fun on the back roads to the freeway, playing chase with a 3 series...cool dude. Anyway, I was feeling pretty proud of myself and the car. He took a right at the dragway entrance, and I kept going.
A few moments later I saw some very interesting daytime running lights in my rear view, and they were advancing fast. The car was like a dried blood red...and it passed me like I was standing still on a tight bend.
Nothing better to humble you quick like a brand new Acura NSX. Man that thing was fast n loud!
