Old 11-15-2014, 06:26 PM   #1653
lamune
Drives: 14 WRB BRZ Limited MT
After reading SVXdc's posts, I decided to go back and make sure everything was wired properly.
Here's what I did..
OJ = SWC | Blue = AMP ON
Remove the SWC pin and wire from the 6 pin connector
Cut the SWC wire so I can use the pin with the Ca-FI AMP ON wire
Use the SWC pin (now connected to the AMP ON) in the 10 pin connector
On Subarus, you should remove (or don't use) the BLUE lead on the antenna adapter.
So I didn't do anything to my antenna lead wire.
After that, I reconnected everything and went and with the car.
Don't forget to tape up and cap off any exposed wires!
Build:
"AWW YEA" < RIP
lamune is offline   Reply With Quote
Old 11-18-2014, 10:02 AM   #1654
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
For those looking for large storage for music, today's your day... [ame="http://www.amazon.com/PNY-Turbo-256GB-Flash-Drive/dp/B00JN1TOHM/ref=br_lf_m_10330159011_1_15_ttl?ie=UTF8&m=ATVPDKI KX0DER&s=pc&pf_rd_p=1974132702&pf_rd_s=center-3&pf_rd_t=101&pf_rd_i=10330159011&pf_rd_m=ATVPDKIK X0DER&pf_rd_r=17P2JXSAHSA3W9YXBBS7"]Amazon.com: PNY Turbo 256GB USB 3.0 Flash Drive - P-FD256TBOP-GE: Computers & Accessories[/ame]
Deathalo is offline   Reply With Quote
Old 11-18-2014, 10:44 AM   #1655
Deathalo
Originally Posted by Narcoden View Post
Outstanding SVXdc! Thanks for your posts. My Dashlinq has been to China and they say everything is normal with it. They are sending it back with a new wiring harness to try again. They are monitoring this thread as they directed me to your post.
Hi Ca-Fi guys!
Old 11-20-2014, 11:24 AM   #1656
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I hope this thing will get an updated ROM with Lollipop dropping now/soon.
Has anyone tried the Eonon HU's? They are like $300 on eBay.
Old 11-20-2014, 12:48 PM   #1657
DrewM
Since the Ca-Fi never got KitKat I doubt it will see Lollipop.
I'm on the fence, part of me just wants to wait and see if we see more Android head units come out (Google supposedly has some more car-infotainment friendly options), part of me wants to just say screw it and pick it up.
You can get more info on the Eonon's here - http://www.eonon.com/Car-DVD-Players...d-Car-DVD.html
DrewM is offline   Reply With Quote
Old 11-20-2014, 12:49 PM   #1658
B-R-Z
B-R-Z's Avatar
I've seen their site, I meant from a perspective of people who have tried it. Durability is a concern with a unit that cheap.
Old 11-21-2014, 10:36 AM   #1659
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
OK, what am I doing wrong? I sent my unit back to China, they said it's working fine and mailed it back. I just received it with a new wiring harness. I wired it up like SVXdc's post suggests (I'm pretty sure this is how I had it before I sent it back) and it still will only turn on the factory amp when I turn the headlights on?!?!
Here is my wiring:
Can anyone help? Thank you!
Narcoden is offline   Reply With Quote
Old 11-21-2014, 12:06 PM   #1660
Narcoden
Narcoden's Avatar
OK, to prove it isn't my car, I took this to the bench and recorded a video. With +12v on wires #2 (ACC) and #9 (+12V power) and the ground connected to wire #1 (ground). I applied +12v to the #10 (dimmer) wire and recorded the voltage on wire #11 (amp). You can see it only turns on when headlights are turned on.
Ca-Fi claims they tested this on the bench and had +12v on that wire.
I'm ready to file a claim with my credit card if they don't fix this quickly. I don't have much time left with the 60 day protection they offer. I'll still be out the $70+ it cost to send it back. They have not reimbursed me like I was told yet.
[ame="https://www.youtube.com/watch?v=v042BBuLZaM"]102 0207 - YouTube[/ame]
Old 11-21-2014, 07:54 PM   #1661
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Originally Posted by SVXdc View Post
Cutting to the chase: Subaru and FR-S owners need to extract the SWC wire from the Dashlinq4's 6-pin harness connector (see pic above). I think that GT86 models (i.e., outside North America) do not have a factory wire at that pin position, but on any cars that do you would need to extract CA-Fi's wire with those cars too.
Thanks for the info...
I haven't had any issues for the last few months since i installed the HU until today. I was killing time this morning, messing around in the HU, and decided to open the SWC app... bad idea. Once I did that the HU decided it wanted to read whatever was going over that SWC wire.
Ended up just opening up the dash and cutting the wire, problem fixed. Thanks.
Pwolf is offline   Reply With Quote
Old 11-22-2014, 01:38 AM   #1662
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
What I can see in your picture looks good. From your video it definitely appears that their amp turn-on output is not operating correctly.
I recommend that you look closely at CA-Fi's harness, and compare it to the pin-out sticker on the HU and to the WRX/STi pin-out table I posted. Determine whether CA-Fi built their harness correctly (aside from the idiosyncrasies I mention in my earlier posts in this Dashlinq4 thread).
[I really need to post BRZ, FR-S, & GT86 specific versions of the pin-outs on this forum]
Also, try measuring the voltage on the Dashlinq4's 'dimmer' lead (with you not connecting it to anything outside of the HU). It should always read zero volts.
Just to be thorough, I suggest that you also test the Dashlinq4's power antenna lead. Does it turn on and off at the appropriate times? Some HUs simply turn it on the entire time the HU is on (like the amp trigger output should do), rather than shutting it off when you switch out of radio (AM/FM) mode.
I've found that some Subaru HUs leave the power antenna and amp trigger outputs on whenever +12V ACC is on (even when you switch off the HU). That is the case with the oldest BRZ FA601US (and I'm guessing the later models too).
SVXdc is offline   Reply With Quote
Old 11-22-2014, 01:40 AM   #1663
SVXdc
SVXdc's Avatar
Interesting that the HU apparently wasn't sending power out the SWC lead until you opened that app.
What exactly happened in your car when you did that?
Old 11-22-2014, 01:50 AM   #1664
Pwolf
Pwolf's Avatar
When I opened the app, it was reporting that button 1 was being pressed repeatedly. By default this was set to "volume up" and proceeded to increase the volume of my radio. Had to continually lower the volume while I tried to fix it in-app. I eventually changed the binding to "volume down" so I didn't have to mess with the knob anymore.
I don't necessarily think it wasn't sending power, just the HU wasn't doing anything with it all this time. I'm still running on an older firmware (no issues and rooted for Google Play customizations I'd like to keep).
When I turned my headlights on, it changed to button 4 (i think). I ended up changing everything to volume down and headed home to get my tools.
Old 11-22-2014, 01:31 PM   #1665
mynameis940
mynameis940's Avatar
Drives: WRX
Anyone else having this problem? I have a 2015 frs and it has the auto headlight switch. If I have it on and the headlights are on because it's dark and I turn off the car and get out the doors won't lock nor will the headlights turn off unless I wait a minute open the door close it again then half the time it will lock if not I have to repeat. I'm not sure how the head unit could affect that but it never did it until I put this head unit in.
mynameis940 is offline   Reply With Quote
Old 11-23-2014, 11:25 PM   #1666
B-R-Z
B-R-Z's Avatar
Is this unit good in everyone's opinion? I might ask the gf for it for Xmas. Any pros/con's would be helpful. Thanks!
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
