Old 03-28-2016, 02:38 PM   #1653
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Happening intensifies!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (05-16-2016), GTHachiRoku (03-30-2016)
Old 03-28-2016, 03:33 PM   #1654
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by DocWalt View Post
Sure, though that's somewhat rare with 200TW tires. I just don't see where Maxxis says how to treat them "properly". If they include some care instructions with the tires would you mind posting them up?
I'm VERY excited to hear your review on these things. From the initial impressions I've heard they should be the hot ticket for your use.
I'm not sure about the Maxxis but I've read special care instructions on a set of Nitto NT01s a friend of mine got and they basically said it was preferred to keep them stored at indoor temperatures but if they need to be stored in below freezing temperatures, it's important to let them come back up to temperature slowly/naturally. Basically, if they are stored in freezing, don't bring them inside to warm them up quickly because that will damage the rubber. I'm guessing it's probably similar for these Maxxis tires.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
DocWalt (03-28-2016)
Old 03-28-2016, 03:53 PM   #1655
13Firestorm_SoCal_86
13Firestorm_SoCal_86's Avatar
Drives: 2013 86
This seems like a pretty reasonably priced set of tires. interested in your impressions of them on the street/track.
Originally Posted by ATL BRZ View Post
New track tires ordered!
13Firestorm_SoCal_86 is offline   Reply With Quote
The Following User Says Thank You to 13Firestorm_SoCal_86 For This Useful Post:
ATL BRZ (03-28-2016)
Old 03-28-2016, 06:01 PM   #1656
redlined600
redlined600's Avatar
Drives: Fr-s
I'm curious house those will look on 9" wheels. I'm wondering if they'd be better on 10" wide wheels.
Old 03-29-2016, 02:01 PM   #1657
ATL BRZ
ATL BRZ's Avatar
The below picture (courtesty of @CSG Mike ) shows a 255 VR1 on a 17x9 TWS T66-F CSG spec, vs a 255 RE71R on a 17x9.5 TE37SL.
They will look pretty good. Meaty but not too meaty.
The Following User Says Thank You to ATL BRZ For This Useful Post:
redlined600 (03-29-2016)
Old 03-29-2016, 02:36 PM   #1658
I think they'll look perfectly fine on a 10" wheel.
ATL BRZ (03-29-2016)
Old 04-01-2016, 06:21 PM   #1659
ATL BRZ
ATL BRZ's Avatar
New 255/40/17 Maxxis Victra VR-1s have arrived along with the Velox flat-bottom panels!!
Compared to my worn out 245/40/17 Bridgestone RE-11A's
nisti (04-01-2016)
Old 04-03-2016, 05:54 AM   #1660
Siolfer
Can't wait for your review as the Mach Awesome 17x9's with these VR 1's are the exact set i'll be ordering come soon. The VR 1's appear to have already sold out in this size too temporarily.
Post weight per corner when you get the chance please?
Siolfer is offline   Reply With Quote
Old 04-07-2016, 03:41 AM   #1661
qwerty66
Drives: frs
Any pictures of the flat bottom pieces installed?
qwerty66 is offline   Reply With Quote
Old 04-07-2016, 09:21 AM   #1662
ATL BRZ
ATL BRZ's Avatar
Soon.
qwerty66 (04-07-2016)
Old 04-07-2016, 09:24 AM   #1663
ATL BRZ
ATL BRZ's Avatar
Prepped for a little emergency surgery tomorrow. My Mishittymoto low-temp "racing" thermostat decided to fail and stay closed, severely overheating the car within a couple minutes while cruising home. This happened when I was 1 mile from the house and I was able to limp the car home before anything catastrophic happened. Making lemonade with these lemons and swapping back to the stock thermostat. Lesson learned.
Old 04-07-2016, 09:57 AM   #1664
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
Oh dear oh dear, glad to see you managed to stop anything catastrophic happening. How old is the Mishimoto thermostat?
secret.squirrel is offline   Reply With Quote
Old 04-07-2016, 10:06 AM   #1665
ajc209
Drives: GT86 Cosworth
You could try the Cosworth one.
ajc209 is offline   Reply With Quote
Old 04-07-2016, 10:15 AM   #1666
ATL BRZ
ATL BRZ's Avatar
I installed it early January 2015 along with the radiator and hoses. I put it through four track weekends early last year and this entire past summer and winter without any major issues other than it running a little too cold on the highway when it was cold outside. I could remedy that by leaving the car in 5th gear and not taking 6th.
Not going to mess with thermostats anymore after re-installing the OEM. Nobody has issues with the OEM and aftermarket seem to have a 50% failure rate among long-time Subaru installers.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
