, dpfarr
Old 09-17-2016, 08:58 AM   #1625
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by taiguy View Post
On my way back home from work and got the same engine light and traction light from a few hundred miles ago.
Pulling the DTCs I've got two:
P0171 System Too Lean Bank 1
C1201 (no description but part of the ABS module)
Under vacuum long term fuel trim is still around +15%
Sounds like a vacuum leak. Could be the bypass valve?
-Josh
Old 09-17-2016, 02:56 PM   #1626
taiguy
Drives: 2013 Black BRZ Limited
-Josh
Saw the previous post about it. It sprayed liberally around that area with starter fluid and no change in idle. Doesn't mean it's not there, but it wasn't readily apparent.
I guess I could go pay for a smoke test and see what comes out.
taiguy is offline   Reply With Quote
Old 09-17-2016, 07:37 PM   #1627
Yoshoobaroo
TRACKBREAD
The bypass valve can leak internally through the vacuum line that actuates it, I think. I don't actually have these so ignore me if that makes no sense, but I'm assuming the valve is actuated by a vacuum line?
-Josh
Old 09-17-2016, 09:04 PM   #1628
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
A couple weeks ago, after installing the Edelbrock, I was having a hell of a time getting all the air out of the system (and keeping it out)
Reference post http://www.ft86club.com/forums/showp...postcount=1556
I found that air was in fact, being pulled back into the system thru the overflow tube.
Reference post http://www.ft86club.com/forums/showp...postcount=1560
So I came up with a "rig" that eliminated that problem, air can go out but not come back in. No more little bubbles, no more big bubbles...no more air, period. IAT’s were stable, no more 55 degrees above ambient.
Reference http://www.ft86club.com/forums/showp...postcount=1573
I just wasn't happy with the "looks" of the curly Q "overflow tank" so I started looking for other options. I found that my Mityvac brake bleeder tank worked perfectly.
While experimenting with different setups, time I decided to measure the amount of fluid that would get expelled thru the overflow tube during normal operations on a now, completely air free and full system. So I hooked up the Mityvac tank with it lower than the surge tank output (and no suction tube inside yet) and by the end of the week, the system had expelled over 3.5 ounces that normally would have ended up on the ground.
I also measured the capacity of the Edelbrock supplied Surge tank and that turns out to be only just over 1 ounce....hmmmm?
I then added the suction tube to the underside of the overflow tank cap so it could now suck fluid back in as needed rather than pulling air back in and within 2 days all 3.5 ounces of fluid that it had previously expelled, was back in the system. So if 3.5 ounces of fluid left the system and 3.5 ounces was pulled back in, if not for the fluid, what would it have been? Answer, 3.5 ounces of fluid volume replaced by air floating around the system!
I finally settled on a location for the Mityvac overflow tank but it required a bit of modification. I spun the Surge tank around which required a fabricating a new mounting bracket, which was a piece of mild steel, 1/8” x 3/4” flat stock from Home Depot. Using a vice, a hammer and a drill...making it was pretty easy.
The Mityvac tank is just tie wrapped to my strut tower brace but it’s in a position that is higher than the Surge tank so fluid will always be available to the surge tank and any expelled air float uphill.
The clear 3/8"ID / 1/2"OD vinyl hose is also Home Depot stuff, like $8 for a 10 ft coil. The Mityvac tank (MVA6910 4.5 oz Fluid Reservoir Kit) was also <$8 online.
One side note, since the Mityvac inlet size is 1/4" and the vinyl hose is 3/8’, I just cut a small piece of hose from the kit, (not the longer suction hose, use the other little piece) to put on the inlet nipple then the 3/8 hose fit right over top of that.
Clamp it for good measure and voila, no more air in the system! All you have to do now is keep an eye on the overflow tank and never have to open and depressurize the intercooler system again. (hmmm…kind of like the car's cooling system....once it's burped and air free, just need to keep the overflow level good) Enjoy.
BirdTRD is offline   Reply With Quote
The Following 5 Users Say Thank You to BirdTRD For This Useful Post:
BigFatFlip (09-18-2016), Heist (09-17-2016), menikmati (09-17-2016), sw20kosh (09-19-2016), taiguy (09-20-2016)
Old 09-21-2016, 09:06 PM   #1629
Colin86
Drives: 86
What tune are you running? Do you have a delicious tuning Dbox?
Colin86 is offline   Reply With Quote
Old 09-22-2016, 01:04 AM   #1630
Wraithrider
Wraithrider's Avatar
Drives: 2015 Subaru BRZ Pearl White
The thread was looking for comments from completed installs .
Over 500 miles of daily driver very calm a true sleeper made a couple of pony cars look silly. Can easily over drive the setup. One track day you could feel the difference between my stock blue line and her E Force.
P0171 and C1201 twice now no pattern may have to check that valve.
Overall very pleased kit does what it says is worth the money and extra 100 lbs.
Wraithrider is offline   Reply With Quote
The Following 3 Users Say Thank You to Wraithrider For This Useful Post:
CallmeDave (03-29-2019), CSG Mike (09-22-2016), funwheeldrive (09-22-2016)
Old 09-22-2016, 10:47 AM   #1631
sickmint79
Drives: bmw
does anyone have on track times with the car driven relatively hard? i'm not looking for racecar bros who can really cook but more like experienced intermediate guys who are moving -
what's the oil get to and what's your oil cooler setup?
how does the intake temp track over time, does it heat soak in a 20/25/30 min session?
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 09-22-2016, 11:32 AM   #1632
caschnd1
Drives: 2013 Subaru BRZ
We've had the E Force supercharger installed in my wife's car for a couple months now. This kit is everything I hoped it would be. We are not looking to track the car. My wife just wanted some more usable power across the RPM range to improve the fun-factor of the car. After two months of daily driving in the Arizona heat, the car has been 100% reliable. She had no complaints at all about drivability (except that it was too loose with the stock wheels/tires so we had to improve that). She took the car on a short road trip last weekend (a couple hundred miles each way) and it performed flawlessly. My biggest worry was that the car would become more temperamental and daily drivability would suffer. But that has not been the case at all. I'm very satisfied with this setup.
-Craig
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl
caschnd1 is offline   Reply With Quote
The Following 7 Users Say Thank You to caschnd1 For This Useful Post:
Bonburner (09-22-2016), CallmeDave (03-29-2019), CSG Mike (09-22-2016), funwheeldrive (09-22-2016), GSpeed (09-22-2016), MrDinkleman (11-02-2016), sato (09-22-2016)
Old 09-22-2016, 12:48 PM   #1633
toast
Drives: 14 BSP Edelbrock BRZ
Which tune are you running?
Sent from my Nexus 6 using Tapatalk
toast is offline   Reply With Quote
Old 09-22-2016, 02:47 PM   #1634
caschnd1
I'm running the CARB tune from Edelbrock. The car was completely stock before the supercharger install and still retains the OEM exhaust.
-Craig
Old 09-22-2016, 06:15 PM   #1635
taiguy
Running the stock edelbrock carb tune. I do not have the delicious dbox.
Old 09-22-2016, 06:21 PM   #1636
taiguy
Spoke with Topher over at Edelbrock and he said that there's a newer configuration file that's been released since mine came out (mine is from May 2016) and to try that out.
The Following 2 Users Say Thank You to taiguy For This Useful Post:
Bonburner (09-22-2016), CSG Mike (09-22-2016)
Old 09-22-2016, 06:25 PM   #1637
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Interesting. Is this a new version of the CARB tune? How do you go about getting it?
Old 09-23-2016, 12:24 PM   #1638
FuzzyFunk
Drives: FRS Monogram
I just got the CARB tune by email yesterday. This should be the finalized one that was approved with the EO number. I texted CSG this week and will schedule a time next week hopefully to have them upload it for me and to test it out. Never uploaded a tune before and don't want to screw anything up :-P Gonna have the pros do it and can't say enough good things about the professionalism of CSG.
If you want the CARB tune send edelbrock your ecutek license key (dongle) ID and registration code to calibration@edelbrock.com
Hope this helps.
FuzzyFunk is offline   Reply With Quote
The Following 4 Users Say Thank You to FuzzyFunk For This Useful Post:
BigFatFlip (09-23-2016), CSG Mike (09-24-2016), menikmati (09-23-2016), shiumai (09-25-2016)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
