Old 02-20-2015, 05:06 PM   #1625
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
@Infamous Performance
How much would it cost for your shop to install the JR SC carb kit (JR-SCFA20-FT) in a 2014 FR-S? (I live very close)
Can the JR SC air intake be modified to use the TRD air intake? I wasn't sure if the TRD air intake needs to be removed in order to make room for the SC intercooler lines.
Would it pose an issue using the kit with the FT86Speedfactory catted UEL header?
Thanks in advance for answering the questions... you can also PM the answer as well if you like.
355rockit is offline   Reply With Quote
Old 02-20-2015, 05:53 PM   #1626
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
You can't use TRD air intake with JRSC. You can use your header however it won't be CARB legal-not sure if CARB tune would work with other than stock header-you are going to need it tuned. Flash and go from Delicious would likely to work. I have JRSC, stock header, oil cooler, DT flexfuel kit with flash and go tune running e85. If I need to go back to CARB tune I just run 91 few tanks change the MAF sensor and flash JR CARB legal tune back. Car is fun to drive. Plenty of power for me. I haven't been able to take to the track yet. Hopefully soon.
kasikuusi is offline   Reply With Quote
Old 02-20-2015, 06:33 PM   #1627
CSG David
CSG David's Avatar
I'll need to try out the FF kit on your JRSC soon.
Old 02-20-2015, 06:47 PM   #1628
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
Can I buy Delicious tuning now? and can I take it to a local shop around me and have them flash the delicious tuning?
914_WHITE_FRS is offline   Reply With Quote
Old 02-20-2015, 06:55 PM   #1629
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
Dave. Yea you need to. I'm out of town until end of the month. 😞 when I get back..😃
Old 02-20-2015, 08:56 PM   #1630
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Yes you can as long as the shop you are using (or yourself) have an EcuTek cable.
Infamous Performance is offline   Reply With Quote
Old 02-20-2015, 09:09 PM   #1631
If you have a CARB kit, you can use your exiting cable to flash the car yourself.
Old 02-20-2015, 09:28 PM   #1632
jflogerzi
jflogerzi's Avatar
How long will the stock header last on the track using the CARB tune?
Old 02-20-2015, 09:31 PM   #1633
Ours showed no significant sign of deterioration in about 22k miles of being boosted on the CARB tune.
Of course, they won't last forever; no catalytic converter does in any situation, but I suspect they should last just as long as on a NA car, given similar driving conditions, based on what we've seen.
Old 02-21-2015, 09:24 AM   #1634
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
How about some E85 fueled track videos @CSG Mike ?
Old 02-21-2015, 11:25 AM   #1635
fasteddy
Ours showed to significant sign of deterioration in about 22k miles of being boosted on the CARB tune.
Mike, can you elaborate on that please?
Thanks.
Pat
fasteddy is offline   Reply With Quote
Old 02-21-2015, 05:58 PM   #1636
M23
Drives: 86
22k miles is a lot. Good to hear the car works reliably well with the JRSC kit and CARB tune.
If anyone hits 60k miles without any problems related to the JRSC kit/tune, then it's basically good (if not better) as factory OEM reliability. 60k is the ultimate test.
M23 is offline   Reply With Quote
Old 02-21-2015, 07:40 PM   #1637
914_WHITE_FRS
yes I know someone who has a ecutek cable. I noticed at delicious tuning website says that for 150 dollars more it will be tuned. I dont know exactly what that means... like is it plug and play already and just upload the flash?
Old 02-21-2015, 10:05 PM   #1638
Soon.... soon....
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
