go_a_way1
Old 07-09-2014, 07:01 PM   #1625
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by 7thgear View Post
adjust the shocks is easier
but almost doubling the bar rate will have a more noticeable effect since it's the spring rate that determines weight transfer, the rebound adjustability of a koni merely controls it.
Sway is pretty each since it's just changing the end-link location.
Am I correct to paraphrase you that:
  • Sway adjustment for larger impact
  • Struts for fine-tuning?
nlowell is offline   Reply With Quote
Old 07-09-2014, 07:08 PM   #1626
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
given the sways and struts that you have, yes
but you could change your cars behavior quite radically with more advanced/custom dampers... but that's outside the scope of your current equipment.
Old 07-10-2014, 04:37 PM   #1627
mistressmotorsports
I like to focus more on the various parts of cornering when tuning shocks or bars. Generally, you can easily tune steady state cornering with bars. Shock settings are used more for transition into or out of corners. So, it's important to pay attention to what the car is doing in various parts of the corner when deciding what to adjust.
mistressmotorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to mistressmotorsports For This Useful Post:
CSG Mike (07-10-2014), ZionsWrath (07-21-2014)
Old 07-10-2014, 04:51 PM   #1628
DarkSunrise
DarkSunrise's Avatar
Originally Posted by formulagt View Post
About to go to my first track day with (hopefully) 1000 miles on the car, will be taking it easy and just learning the car itself since it's brand new and I'm brand new to the track. Will be attending Buttonwillow Open Test day with a friend whos a regular (he races in the GT86 Challenge thing) as well as a few other FRS buddies. Any suggestions or notes that aren't "common sense"? Planning to only do half the day so not sure how many laps I'll actually get in.
Most of it is actually common sense, but as a start, read this:
http://www.ft86club.com/forums/showthread.php?t=25485
The only thing I would add is, try to learn the flags in advance. And don't immediately hit your brakes if you see a red flag.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Old 07-10-2014, 04:51 PM   #1629
Racecomp Engineering
This. Playing with the shocks is going to do little or nothing for steady state cornering, but will be noticeable in transitions and entry/exit.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
DAEMANO (07-10-2014), ZionsWrath (07-21-2014)
Old 07-10-2014, 11:00 PM   #1630
D K
Stig's dark passenger
I have motorsport 3way's up front and stock shocks with lowering springs in the back.
The car is comical to drive.
D K is offline   Reply With Quote
The Following 2 Users Say Thank You to D K For This Useful Post:
Racecomp Engineering (07-11-2014), ZionsWrath (07-21-2014)
Old 07-13-2014, 08:57 PM   #1631
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Is there a cooling temp thread? Like a data collector.
Like;
track name/length
# of laps/hot laps
ambient temp that day
Radiator temp
oil temp
cooling setup
If we just compiled a buttload of this, it'll be a quick way for members to see which setups are cooling effectively and which arent for NA or FI.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 07-13-2014, 09:02 PM   #1632
dp1
driving smoother faster
Drives: Sold
Could a custom tune noticeably impact coolant/oil temps, if the tune is less than optimal?
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Old 07-13-2014, 09:52 PM   #1633
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
In theory, if you are running lean, the burn (or explosion) is hotter than a stoichiometric burn, which could definitely put more heat into a radiator than it was spec'ed to handle and thus, raise temperatures. But eventually you'd melt a valve or seat which is less than desirable. This less than desirable burn would make power for a short time, but not be good in the long run.
bimmer635csi is offline   Reply With Quote
The Following 2 Users Say Thank You to bimmer635csi For This Useful Post:
dp1 (07-13-2014), ZionsWrath (07-21-2014)
Old 07-13-2014, 10:11 PM   #1634
Like;
track name/length
# of laps/hot laps
Radiator temp
oil temp
cooling setup
No, but if you tell me what your setup is, I can probably give you an idea of if you have sufficient cooling or not.
AZP Installs (07-14-2014), ZionsWrath (07-21-2014)
Old 07-13-2014, 10:12 PM   #1635
Coolant, yes. Oil, marginally.
You'd need to have a really hot flame front, but yes. However, it's difficult to get that type of combustion without causing any other damage in the process over the long term.
Old 07-14-2014, 02:16 AM   #1636
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
At Lime Rock Park, where a modified circle track setup is good for .3-.5 since there's only a single left-hander, and it's the slowest corner on the track, you would probably want those 3-ways on the left. That would reduce the comicality a bit.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Old 07-14-2014, 03:12 AM   #1637
D K
I drove my car like this to Laguna and back this weekend and even though it was not optimal, the car actually handled pretty well.
The Following User Says Thank You to D K For This Useful Post:
Old 07-14-2014, 09:08 AM   #1638
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Like;
track name/length
# of laps/hot laps
Radiator temp
oil temp
cooling setup
On track I am running the following:
OEM setup w/re070 tires
AMB: 75-85 deg
Coolant: 215
Oil:260-275
OEM setup w/re070 tires and koyo rad
Coolant:199-205
Oil:260-275
We are going to try out an OTS oil cooler this coming week and will have some hard numbers after that.
Mike
AZP Installs is offline   Reply With Quote
The Following 5 Users Say Thank You to AZP Installs For This Useful Post:
cdrazic93 (07-14-2014), CSG Mike (07-15-2014), kavanagh (07-15-2014), solidONE (07-16-2014), ZionsWrath (07-21-2014)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
