#1611 | |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Sway bar sizes used
Thanks Last edited by Brzzee; 06-11-2014 at 02:31 PM. Reason: Clarification |
#1612 | |
Both work well. If you're able to run a little more camber up front then the Whiteline bars may suit you better. If you're limited in camber, the stiffer front of our RCE bars I think is a better choice (and IIRC a tiny bit lighter). - Andy |
#1613 | ||
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
When I wear through my stock rubber, I plan on switching to MPSS 225/45r17 on the stock wheels (I want wider tires, but I cannot afford new wheels currently). I also am considering installing my SPC camber bolts to the lower slot and adjusting the front camber to between -2* and -2.5*. Unfortunately, top hats are still not financially feasible at this moment. My goal is to have easily accessible oversteer, but I do not want crazy oversteer, maybe half to two thirds of the oversteer as oem suspension is my ultimate goal once I have all the goodies I would like to have: sway bars, rear lca's, front top hats, etc. My question for you guys is: A) Does what I plan to do make sense? B) ignoring things like settings creep, will the SPC bolt have issues with catastrophic failure such as sheering or would I be better off with another option such as Eibach? (I would like to use what I already have and not spend any more than I currently have to until finances improve - I am still paying off the B8's and Tarmac springs ) C) Is there something else that is inexpensive that I am not thinking about that might help me out? Thanks in advance!
#1614 |
Off Topic
To piggyback off of @Turkish's question, is there any reason one couldn't use camber bolts in both upper and lower positions to get super extra camber?
#1615 | |
![]() Running two camber bolts makes me nervous. That said, many have done it and it's fine. - Andy |
#1616 |
Another option would be to slot the upper hole to add some more camber potential.
#1617 | |
Drives: 2012 Toyota 86
#1618 | |
Drives: Strangely.
I've heard the stock suspension described as 'bumpstop active' but is it actually that severe? I tend to think of bumpstops as only getting used when landing from a jump. Haha, everyone tells me that my alignment is conservative. But it's just how I like it. I can probably dig up a stock shock dyno too without much trouble. But if you've got a B6 or B8 dyno I'd be very grateful! |
#1619 | |
Serial Cone Killer
Sent from my SM-G900V using Tapatalk
#1620 |
Drives: 1990 BNR32 GTR
Holy crap. The information. It would take me weeks to read it all.
I'm trying to compete in STX class, and so far I've got a 19mm front Perrin Bar and a 16mm rear one. That combined with their poly endlinks. Rear sway bar is set to middle and the front set to the stiff hole. Something like 70% stiffer than stock. With that said, I'm on stock tires and coils. Upgrading to 17x9 rims with 245/255 RS3 v2's soon. I know Coils are the right way to go, but would RCE Yellows be the worst idea in the world?
#1621 | |
Drives: MT WRB BRZ Limited, 2007 911s
Depends what your goals are with the car. Are you just looking to have fun or be competitive? What kind of competition are you going to see in your events? I run a small local club so the RCE Yellows were not only very fun to drive with but pretty competitive (all three of the competitive STX twins have them). If I went to a more competitive event, the car would be totally outclassed (as would the driver ). Personally, I'm moving from yellows to Bilstein B8s/Tarmacs but the yellows were a huge improvement over stock and I would absolutely recommend them to anyone.And just as a side note, if you're already going 9 inch wide wheels, just go with 255. |
#1622 | |
![]() OEM dyno below. I don't have the B6 dyno. ![]() - Andy |
#1623 | |
If you're looking to compete locally, RCE Yellows are a good way to go and will improve handling. If you're looking to win nationals, you will need coilovers. - Andy |
#1624 |
Drives: 2013 Subaru BRZ
I'm building a drift car right now, and I'm looking at going with Bilstein HD's with coil sleeves on them, because I'd like something that handles well but is flexible in terms of valving and spring rates. I'll have extra weight up front because of an engine swap, and standard coilovers won't fit anyway because I'll be running nissan spindles to get the steering geometry I'd like.
I read in a motoiq article that on Ryan Tuerck's 2JZ-powered FRS, they're running KW's with 10k rates front and 7k rear. Doesn't the motion ratio of the rear coilover location mean that the 7k spring rate out back is effectively even softer, compared to a car with the rear shock mounted to the upright? It also mentions that they're using some sort of a custom rear bar, with the stock bar up front. Does it sound reasonable to assume that they're using relatively soft springs out back to allow the car to squat more and transfer weight to the back for more forward bite, while using a lot of rear bar to give it the transitional oversteer characteristics they want? With that in mind, would the rear bilstein B8's for this car be in the ballpark of being able to damp 400lb/in springs if I tried to duplicate such a setup? I was going to go with 550 lb/in springs up front, and the 3000GT bilstein strut inserts I'll be running are supposed to be able to handle rates like that. edit: also, what are my options for spherical bearing rear shock mounts? since the GR / ZC6 has multilink rear and the shock mounts don't adjust camber, it seems like there's not a ton of options for this. it'd be nice if there's such a product available at a reasonable price, I'd like to avoid having to design and fabricate something I can just buy.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
