Old 08-10-2023, 10:00 PM   #1611
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by Kaotic Lazagna View Post
Well, couldn't improve my time. So challenge failed. Lol
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
Kaotic Lazagna (08-10-2023), NoHaveMSG (08-11-2023)
Old 08-11-2023, 10:45 AM   #1612
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I tried using no ABS when the GT7 first came out, and way too hard on the controller. But then again, I had that adaptive triggers on, and felt that it was holding the triggers down when I have already released them.
I mean, as far as ABS (and to a degree stability & traction control) go, when you have basically zero feedback from the car (as opposed to were this real life) it's fair to use it somewhat. IRL you'd get a sense of when the brakes were about to lock up, or when the front tires are going to wash out into understeer.
etc etc etc
But most of us don't have super fancy (and expensive) set ups at home so we don't feel any of that.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post:
Kaotic Lazagna (08-11-2023), NoHaveMSG (08-11-2023)
Old 08-11-2023, 11:39 AM   #1613
spcmafia
spcmafia's Avatar
The only thing that I've found better with a direct drive wheel is that is easier to correct for mistakes. I would have to give props to Logitech and the G29 because for the money, the feel of the road is basically the same as I am now getting with the Fanatec wheel. Then again, FFB on GT7 is pretty mid.
I do miss the pedals on the Logitech controller, the brake pedal had a lot less travel.
The Following User Says Thank You to spcmafia For This Useful Post:
Old 08-11-2023, 01:02 PM   #1614
StraightOuttaCanadaEh
Wes
This is my main complaint with console racers and wheels. As far as I could tell, there was 0 FFB and road feel on consoles. So for example, in Assetto and iRacing, you can feel every crack in the road itself (not just rumble strips) through the steering wheel, every bump unsettling the steering wheel. When I had a wheel with the previous playstation and whatever the previous GT game was (GT6? Prologue? GT Sport?), the steering wheel was completely flat and lifeless on the road and subtly weighed up in the corners and vibrated over rumble strips, with none of the granular detail of the pavement itself. Is this still the case with GT7?
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 08-11-2023, 02:37 PM   #1615
spcmafia
spcmafia's Avatar
Gran Turismo 7
It has gotten better, I can't speak for belt driven wheels with TFF because the G29 didn't have it and I made the jump to Fanatec straight from that.
There are certain sections of the road where I really have to hold a firm grip on the D.D wheel, whereas with the G29 it was pretty flat. Bumps and rumble strips are more or less the same on either. I haven't found a night and day difference.
Where the D.D wheel shines is simulating the feel of oversteering and understeering, which is why so much easier to correct the car. I believe is what it has helped me of not losing so much time as I was when using the G29.
NoHaveMSG can probably offer a way better insight since he has been using Direct Drive the longest, I think.
Edit; whereas enthusiasts tend to lean towards a DD system, I have read great reviews on the G923 when it comes to TFF.
Old 08-11-2023, 05:35 PM   #1616
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's miles better. The biggest issue I had with belted wheels is they start to develop this dead zone over time. The FFB in DD is far more nuanced, I can actually feel front brake lockup, but I still mostly use audio que for that as it is more noticeable. The FFB is GT7 is mild though, ACC is worlds better even on console.
Old 08-11-2023, 05:52 PM   #1617
WolfpackS2k
Yeah that is a major gripe for me. I use the G29 and if the car starts to get away from me via oversteer, it's often impossible for me to "catch up" and correct it. I literally cannot turn the wheel fast enough to save the car.
Old 08-12-2023, 01:32 AM   #1618
spike021
spike021's Avatar
I've been playing again a bit this week and I forgot how bad some of the braking zone gear recommendations are. There are some braking zones where you can pretty easily power through a gear or two higher than it says to use. I'm not sure if they chose a low gear expecting beginners, or it's based on a single car or single tune setup or what. It's confusing. I remember this being an issue around launch too, surprised it hasn't been fixed.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 08-12-2023, 02:13 AM   #1619
Kaotic Lazagna
Drives: GR Corolla
I think it's an estimate based on the specific car and tune/set up. It's really just a suggestion. hahaha. I think it's a good starting point, especially if you're not particularly familiar with the track. Get a slower base time, and then gradually find the braking point and speed for the corners of the track. That's what I do for tracks I refuse to race on, but must when the time comes. hahaha
Old 08-16-2023, 05:30 PM   #1620
Kaotic Lazagna
Drives: GR Corolla
So I get hit 3 times, with one knocking me into the wall, yet it's my SE rating that goes down? WTF!?
Old 08-16-2023, 09:10 PM   #1621
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I stopped worrying about SA and Driver rating. Too much stupid stuff happens during online races. Rarely do I think, "that was a nice clean fight" with anyone anymore.
Old 08-16-2023, 09:33 PM   #1622
Kaotic Lazagna
Drives: GR Corolla
Yeah, it's just annoying how none of it was my fault. I'd understand if I bumped someone.
Old 08-18-2023, 12:29 PM   #1623
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The GR2 TT at Suzuka is pretty fun. Was surprised I was quickest in the Lexus.
Old 08-18-2023, 12:31 PM   #1624
spcmafia
spcmafia's Avatar
It is actually, very fun. My favorite track of all time. I thought the NSX would be a good pick and I was absolutely milking it. I'll try my luck with one of the GTRs.
gran turismo, gran turismo 7
Gran Turismo 5 GT Off-Topic Lounge [WARNING: NO POLITICS] 24 06-16-2019 06:53 AM
FT-86 in Gran Turismo 5 AaronCompNetSys Scion FR-S / Toyota 86 GT86 General Forum 207 01-21-2014 11:32 AM
Gran Turismo 5 Thread SuperGTS Off-Topic Lounge [WARNING: NO POLITICS] 7 10-30-2013 02:14 AM
Gran Turismo 6 - Box Art!! RevoG Scion FR-S / Toyota 86 GT86 General Forum 26 05-15-2013 12:53 AM
Gran Turismo 5 JLMtm Scion FR-S / Toyota 86 GT86 General Forum 3 11-03-2012 05:06 AM
