Old 02-22-2023, 05:36 PM   #1611
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Originally Posted by Sealeyteamsix View Post
So, I've used the search function, gotten close, then no cigar lol. Curious if anyone has a pinout digram in order to make our own harness. I bought a new 54 pin engine harness plug and a k series engine harness with the hopes of creating my own but after 2 weeks of searching, I can't even find any diagrams or anything to help point me in the direction I'm trying to go. If anyone would be willing to message me any helpful links/diagrams/solutions, that would be greatly appreciated. I'm all about supporting Kpower and have gotten a bunch of their stuff, but would like to save a bit, and learn a bit, creating my own harness.
-Ty
Here's the factory diagram CLICK ME
What ECU are you using? Haltech like the Kpower kit? If so how will you sort out the jumper board?
captain awesome is offline   Reply With Quote
Old 02-22-2023, 11:35 PM   #1612
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
-Ty
I'm not really sure what you are doing yourself. Did you buy the jumper harness and jumper board and Haltech ECU, but you are trying to make a harness yourself instead of buying this? You said you bought a 54pin connector and a K series engine harness, right, so a used one or a universal one or a cheaper one that is for other cars, and you want to hack it up to make it work with the 54 pin connector, right? If that is the case then everything you need is in electric diagram Captain posted.
Old 02-23-2023, 09:08 AM   #1613
Sealeyteamsix
Sealeyteamsix's Avatar
Drives: Turbo K24 BRZ (in progress)
Yes I bought a haltech elite 1500 and will be pulling the trigger on the jumper board today or tomorrow. Just trying to build the engine harness myself. I will look into his diagram and attempt to make it this weekend. And thats exactly right, bought a "tucked" harness that I want to hack up to recreate that one you pictured.
Sealeyteamsix is offline   Reply With Quote
Old 02-23-2023, 12:50 PM   #1614
RedReplicant
Drives: None
If you're using their jumper board then you need to copy the KPower 54 pin exactly since it will not match stock pin for pin. I wrote down what some pins were when troubleshooting mine, but I don't have a full pinout anywhere. Your best bet is going to be begging KPower to send it to you or to map your adapter board output -> input -> haltech and build a 54 pin diagram from there.
I asked them for pinouts and they weren't supplied to me, so if you do get ahold of them please post them.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Irace86.2.0 (02-23-2023)
Old 02-23-2023, 05:29 PM   #1615
ML
ML's Avatar
Drives: 13 White MT FR-S
Here is what I ended up doing with the exhaust around the cd009 and mounts. Its still really tight and it may need a hammer in a few places. I just slipped it over the cut header so we will see how bad the exhaust leak is lol. Don't mind my damn fluxcore welds
The Following 5 Users Say Thank You to ML For This Useful Post:
captain awesome (02-23-2023), endless_pain (02-24-2023), funkjaw (02-24-2023), Irace86.2.0 (02-23-2023), RedReplicant (02-23-2023)
Old 02-23-2023, 08:02 PM   #1616
Irace86.2.0
You bought the 54 pin connector, and you will be reusing some of the clips from the stock FA20 harness like the TB sensor/actuator, or are you using a K24 TB?
The electrical wiring diagram is a bit of a bear; you will have to trace the lines through multiple pages back to the harness and ECM and compare with the jumper board. Ugh
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
captain awesome (02-24-2023), funkjaw (02-25-2023), RedReplicant (02-23-2023)
Old 02-25-2023, 03:22 PM   #1617
Sealeyteamsix
Yeah that was my plan was to reuse some of the BRZ connectors but it’s becoming more and more discouraging lol probably just end up paying them the money for theirs.
Old 02-26-2023, 02:30 AM   #1618
Irace86.2.0
Wiring is not for the faint of heart. It is a tedious process to sort through the wiring diagrams and cross reference everything with the jumper board for accuracy with the wiring diagrams. It would be far easiee doing a custom harness without using the stock harness, and it would be even easier without integrating CANBUS. Frankly for me, some things are better worth my time to buy the part and work some overtime. This is one of them. Good luck either way.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
funkjaw (02-28-2023), RedReplicant (02-26-2023)
Old 02-28-2023, 05:59 PM   #1619
RedReplicant
Drives: None
If anyone else was curious about the Ichiban 74mm Bosch to B Series (kpower flange) adapter, mine finally showed up from Thailand last week.
I haven't test fit it yet, but it seems like it'll work. Currently looking into another intake manifold to throttle body option that has cropped up though.
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (03-01-2023), funkjaw (03-01-2023), redlined600 (03-01-2023)
Old 03-01-2023, 08:57 AM   #1620
ML
ML's Avatar
So if anyone needs to get access to the oil pan I have successfully done that last night. You will need a engine support bar like the one below but the way I did it was have one hook and slid it from under the intake manifold there is a gap between the middle runners and the head. Just put on hook through there to support the engine from above.
Then basically unbolt the sway bar supports (that go from the chassis to the subframe) but leave the bolts that hold it to the chassis in, just loose. unbolt the lower control arm connections to the subframe, steering rack, on one side I found it easier to loosed the strut/knuckle bolts, and disconnect the tie rod from the knuckle, and the sway bar connections to the lower control arms. Then it was just unbolt the motor mounts from the bottom and drop the subframe out while moving the lower control arms out of the way. All said and done it took 3 hours to drop it, take the oil pan off, reseal it, and put the car back on the ground. Really not too bad
The Following 6 Users Say Thank You to ML For This Useful Post:
captain awesome (03-01-2023), endless_pain (03-01-2023), funkjaw (03-01-2023), Irace86.2.0 (03-01-2023), redlined600 (03-01-2023), RedReplicant (03-01-2023)
Old 03-02-2023, 12:26 PM   #1621
captain awesome
Wears Pants
How thick is the spacer vs the Kpower one?
The Following User Says Thank You to captain awesome For This Useful Post:
RedReplicant (03-02-2023)
Old 03-02-2023, 12:55 PM   #1622
RedReplicant
Drives: None
Throttle bodies from flange that goes against adapter gasket to outer edge of TB inlet:
BRZ 65mm: 69mm
Bosch 74mm: 57mm
KPower BRZ 65mm Adapter: 24mm + 1-2mm for gasket
KPower Bosch 74mm Adapter: 21mm + 1-2mm for gasket
Ichiban Engineering Bosch 74mm Adapter: 22mm + no gasket thickness since it uses an o ring instead of a flat gasket (also note that you also lose the flat 1-2mm gasket between the manifold and the adapter)
This kinda highlights how much shorter the stack height from the intake manifold to the intake tube adapter is for the Bosch vs BRZ TBs (and therefore more flex afforded by the coupler). Over half an inch more flex in the Bosch setup vs BRZ.
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
captain awesome (03-02-2023), funkjaw (03-03-2023)
Old 03-02-2023, 01:05 PM   #1623
captain awesome
Wears Pants
Fingers crossed this one fits well. I'd like to just rely on an o-ring seal instead of the Kpower stuff.
BRZ 65mm: 69mm
Bosch 74mm: 57mm
Old 03-02-2023, 01:10 PM   #1624
RedReplicant
Drives: None
I'll test fit it later today, just been lazy about going into the garage lately lol.
captain awesome (03-02-2023), funkjaw (03-03-2023), ML (03-02-2023)
Rigid Industries SR-Series Pro Light Bar on my BRZ Stang70Fastback Cosmetic Modification (Interior/Exterior/Lighting) 3 12-29-2019 04:13 PM
Airlift from industries finest J_Nasty Member's Car Journals 0 02-04-2017 02:59 PM
Carbox Industries - Introduction CarBox CANADIAN Sales 5 04-22-2014 02:22 PM
86 industries Duthebarber Northern California 70 03-28-2014 05:10 PM
Another 86 Industries another bad experience sikest User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-13-2014 02:00 AM
