#1611 | |
Drives: 2014 FR-S
#1612 | |
Grip>Drift
Drives: FRS
I'm about 40lbs heavier than I was 2 seasons ago. So either I need a faster car or to get back to the gym.
The Following User Says Thank You to BlaineWasHere For This Useful Post: | tahdizzle (06-29-2015) |
#1613 | |
Drives: 2013 FR-S Whiteout MT
Don't really want to spend more money on wheels and tires. I'd rather just use one. I mean I'm not trying to set the fastest times or anything. Just looking to have fun. Plus autox won't be the only driving I do so I think it should be ok if I just go to the practice events for fun.
When in doubt, throttle out!
#1614 | |
Drives: 2014 FR-S
Mark |
The Following 2 Users Say Thank You to markw For This Useful Post: | EN2_Squirrel (06-22-2015), FRS Johnny (06-22-2015) |
#1615 |
Drives: 2014 Raven Black FR-S
does this rule out an aftermarket racing steering wheel minus the airbag?
#1616 |
Drives: 2017 BRZ
#1617 |
Drives: monogram raven
So this wknd we had a 2 day event. We have a former national champ solo driver in my region and what did he show up in, his new 10 series. Saturday was his first autocross in the car and thankfully he wasn't in stx bc all he's had time to do is swap wheels and tires. Rpf1s and star specs, BUT they were stock size. All day Sat he's beating my times by close to 10 seconds and yesterday it was around 5-6 seconds. Only posting to reinforce the fact that driver mod is the best mod. My plan? Beg him to co-drive a few events!
#1618 |
Drives: 2017 BRZ
I've yet to find a past champ that isn't thrilled to ride and help. I doubt you'll have to beg, just ask nicely.
The Following User Says Thank You to cjd For This Useful Post: | RTR (06-29-2015) |
#1619 |
Drives: Ultramarine FR-S
Has anyone raised their rev limit to get a few more MPH in 2nd? If so what has been found to be a safe amount to raise it if any? Thanks.
#1620 |
Drives: Subaru BRZ Limited M/T
I've gone up to 7800. No issues so far. Most of the local courses here are pretty tight, usually don't get up to 7800. Although the last course was so tight you could stay in first for the first half of the course. There I hit the rev limit. The nice soft limit.
#1621 |
Grip>Drift
Drives: FRS
The courses I run these days use a lot of third gear so I'm shifting anyway so I don't know if I need the revs.
I would not want to run a AutoX stuck in first or not even fast enough to top out 2nd. Eww.
#1622 |
Oh we can still, come close, to topping out in 2nd. One of those driver skill things. This course was more technical than most. Some were still hitting third in the the slalom. The top car time, was an ASP 911. He had a tall first gear and it worked great for him on this course. Hoosiers of course. It had a LOT of transitions and tight sections that kept the corner workers very busy.
Lot of fun Sent from my iPhone using Tapatalk |
#1623 |
Grip>Drift
Drives: FRS
One skill I've been working really hard to get better at is my 2-3 and 3-2 shifts because every national level course I've run is to fast at some or multiple points for 2nd gear. It's been paying off so far.
#1624 |
Practice makes perfect. I have the AT, so shifting is easy, BUT, this is the only spot I have issue with the AT. It would be better I think to have the paddles fixed on the column. Plus you have to hit 4000 rpm BEFORE you are able to downshift. So until you can master this skill, you end up slowing down too much. If you hit it right on, you can gain a half a second. Shifting 2-3-2 is easy, 2-1 is what needs to mastered, for me.
Otherwise I do good. And I have fun. Heel/toe technique helps immensely. I bought pedal covers so I could set up for heel/toe. It worked. Sent from my iPhone using Tapatalk |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
