#1611 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
Nothing says put up or shut up like a real world test.
TO THE TRACK!
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
#1612 | |||
Drives: Blue Subarus
![]() Quote:
![]() I'll stop dragging this out anymore...I have my opinions based on what other tuners are seeing with a similar setup, so my best option is to go with another tuner and come back to compare.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
#1613 | |
The Frozen North
#1614 | |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
The loss in power could hinge on much more. Is the motor healthy? All we did at my shop was change head gaskets. No inspection of the block, no compression test, no leak down test. You can perform 1/4 mile runs on my Mustang dyno. Possibly Manns dyno can do that too. Not looking for R/T, 60ft, 1/8th mile or anything else other than trap speed. If you use another tuner, make sure the car gets measured on the same dyno (Mann). Otherwise its the same thing all over again. More pure speculation. |
#1615 | |
ACN 91 is NOT 91 pump sold anywhere else in the USA. It is up to 15% ethanol (sugar cane based), it is oxygenated, it is low sulfur and it is mixed with all kinds of chemicals (known to the State of California to cause cancer). If you have never experienced ACN 91 you are lucky. My own LGT lost 40whp (on a stock turbo) between NYC and Cali. Only difference was the fuel. It is that bad. Yes, we replaced the head gaskets. Because they were blown. Was something else damaged when the head gaskets blew? Why did the head gaskets blow? We did not even resurface the heads, just new gaskets. PM did not want anything else done. The car does not need to race against anyone. But I agree, a recorded trap speed would be nice. It would be nice to have before and after trap speeds too. |
#1616 | |
I did not 'specifically requested only 15 psi'. I'm tired of repeating myself. Bill and I thought it would hit those #s on 15psi, Bill was worried it would exceed my goal and they wanted to lower the WG spring, but couldn't open the EWG so decided to start with WG pressure. The EBCS is still installed AFAIK, it just wasn't used.
#1617 |
Not looking to start a pissing match, but I was present when you made the request for 15psi/spring pressure at my shop on my dyno. You were not worried (then) about max power numbers, you wanted reliability.
I was not present at Mann and all I know is what I am told about that day. I was told you made the same request. That higher boost levels were frowned upon (by the customer) due to your previuous experience with higher boost levels (blown head gasket). Your car is the first FA20 I have seen with 9:1 compression. I believe it is the first Bill has seen too. There very well may be more power to be had from the current set up. AFAIK Bll has offered to re-visit the car and spend more time on the tune. Using the EBCS will allow higher boost levels, which in turn will require more fuel. |
#1618 | |
You did tell me the heads were sent out for inspection, that was at least what you told me a couple times when I called for an update. You said they came back fine... What?! Why did you install the EBCS and make sure it was good to go before Bill started on the car? If I had asked for just WG pressure I don't see why you would've been hooking up the EBCS after it was already strapped to the dyno, before Bill started.
#1619 |
Imfamous Performance I think you're forgetting I'm not from the US. Our fuel is as bad or worse that what is in California. I'll leave it here now because you two obviously have had some miss communication going on.
The Frozen North
#1620 | |
#1621 | |
Inspected means looked at. There was no visible damage. But there was no valve cut done and there was no resurfacing of the heads. I recommended a valve cut and a resurface, as I always do. If it were my car, I would. But I must follow the customers wishes. As I recall the EBCS was installed at the beginning of the day, prior to discovering the blown head gaskets. When you came back in (at night) and we discussed the plans/goals after determining that there was a mechanical issue the plans changed. As I stated, I was not at Mann and have no first hand knowledge of the conversations there. But if there was a concern, was it not brought to Bill or Garys attention then and there? |
#1622 | |
#1623 | |
We have tested my Mustang against the local Dyno Jet. Same cars on the same days. My Mustang is always 20% lower. So, if the Z06 made 451 on my dyno it would be approx 541 on the local dynojet. |
#1624 |
Much title. Wow.
I flashed the latest and greatest from Delicious tuning this morning, and Wow.
The car feels as though I unloaded 200 lbs from the trunk. Much more free feeling, Outstanding throttle response and the AFR's are steady and consistent. From my personal stand point, Especially for distance customers such as myself, the Full blown turbo kit, with Delicious tune, is the best a guy can do for adding safe, reliable power with quality. This is my personal experience, and I am extremely pleased with how both parties have taken care of myself and my car.
The Following 4 Users Say Thank You to Deadspool For This Useful Post: |
Tags |
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo |
AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 03:10 AM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
Full Blown Turbo Kit! | Unleashed | Engine, Exhaust, Bolt-Ons | 70 | 10-09-2013 09:46 AM |
WTB: Full Blown turbo kit (used) | whitefrs | Engine, Exhaust, Bolt-Ons | 12 | 03-29-2013 09:15 PM |
