Old 04-20-2014, 01:44 AM   #1597
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
FT-86 SpeedFactory Catted UEL Header
Tenchi is offline
Old 04-20-2014, 01:45 AM   #1598
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by FRSBRZGT86FAN View Post
Lol
Sent from my SGH-T999L using Tapatalk
Defiantly not legal due to noise laws. :/
ZOMFGAARON is offline
Old 04-20-2014, 01:46 AM   #1599
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
FRSBRZGT86FAN is offline
Old 04-20-2014, 07:48 PM   #1600
pnig
pnig's Avatar
Drives: 2013 Whiteout Scion FR-S
Got my header installed after a painful ordeal. It was a nightmare, but it had nothing to do with the FT86SF header. The fine gentlemen who installed my overpipe and frontpipe for me decided they were going to crossthread the left nut that goes onto the stock header where it mates to the overpipe. It was bad. Very bad. It looks like they forced it all the way down. There were no threads left and it was smooth, and they welded the nut onto the flange. It took 6 hours for me to cut through the shitty weld and the nut with a dremel. If any of you have been down there, you know there isn't much clearance to fit much of anything. I managed to get the job done without cutting into anything else, but as a result I sneezed metal shavings for a day and a half.
I got the new header installed, only to end up finding an exhaust leak at the overpipe/frontpipe mate that wasn't there before. I tried to seal it with high-temp RTV, and it helped for a day. The leak has come back. I have an appointment to get the car tuned on Wednesday morning, and will have the leak fixed then.
So far my impressions of the FT86SF header are great. It sounds fantastic and I feel like it cleared up that torque dip nicely. More info later this week.
pnig is offline
The Following 2 Users Say Thank You to pnig For This Useful Post:
enjoyminutemaid (04-21-2014), FT-86 SpeedFactory (04-20-2014)
Old 04-21-2014, 01:25 PM   #1601
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Got a chance to meet up with @Sypher over the weekend to check out the headers. I'm quite impressed with how they looked and sounded and my fears of it being too loud have been quelled somewhat after taking a ride with him. A "warm" start was slightly louder than I expected, but was ok. He (and his fiance, who I'd take it as the better judge of the two lol) did mention though that cold starts were very loud, as I would expect. We both had the Nameless over/frontpipe combo, and both agreed that it seems like most of the noise was coming from that. @leicaboss hope that helps...
BigFatFlip is offline
The Following User Says Thank You to BigFatFlip For This Useful Post:
leicaboss (04-21-2014)
Old 04-21-2014, 03:35 PM   #1602
akahenry
akahenry's Avatar
Drives: '18 STi
How's the rumble on the setup? I want a rumbly yet SOMEWHAT quiet (nothing extremely raspy and obnoxiously loud) setup exhaust note. Somewhat to a stock hatchback 08-14 rumble.
akahenry is offline
Old 04-21-2014, 03:52 PM   #1603
BigFatFlip
BigFatFlip's Avatar
I hear ya, I'm in the same boat. Rumble was good and subdued between 2-3k rpm, which is what I was really curious about, since this is what I will be hearing 90% of the time DD, very similar to my previous 06 wrx wagon. Does definitely get louder as your get on it around 4-5k rpm, then, oddly starts to sounds EL again at around 5.5-6k rpm, which is kinda cool. As far as I can tell, based on what I've seen on videos and in person, rasp and noise depends on what you have down stream, ie overpipe/frontpipe, cat back, etc. I believe FT86SF did a video earlier with the headers and stock everything else, and it was significantly more quiet, just with some rumble.
akahenry (04-21-2014)
Old 04-21-2014, 07:28 PM   #1604
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Been following this thread for a while.
Just curious, anyone pass any sort of state emissions test with this header?
dem00n is offline
Old 04-21-2014, 07:31 PM   #1605
FRSBRZGT86FAN
In PA at least it would probably only pass for the first couple years before any "sniffer tests" occur and then would need to run the secondary cat to meet emissions spec
Old 04-21-2014, 07:35 PM   #1606
dem00n
dem00n's Avatar
Drives: Scion FRS
Each state is different, in New York a new car has two years before emissions testing starts.
Even then, i'm still curious for people passing with this header and an aftermarket/stock 2nd cat as well.
There's not a lot of info on this forum about passing emissions with a full exhaust system, but yet again there aren't many states that require it.
I'm not a big fan of changing whole exhausts over night just to pass a test...
dem00n is offline
Old 04-21-2014, 07:39 PM   #1607
brianhj
Drives: 2017 Camaro 1SS
jesus christ what a nightmare
edit: did they tell you they did any of that stuff or did you only find out when you went to install the header?
brianhj is offline
Old 04-21-2014, 07:40 PM   #1608
FRSBRZGT86FAN
I did say "Pa at least" I know each state is different
Old 04-21-2014, 07:46 PM   #1609
dem00n
dem00n's Avatar
Drives: Scion FRS
Shall i educate you on European and Japanese emissions as well?
dem00n is offline
Old 04-21-2014, 07:49 PM   #1610
FRSBRZGT86FAN
Do it bro
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
