Old 03-24-2014, 09:58 PM   #1597
steve99
Originally Posted by shiv@vishnu View Post
I would definitely revise the ignition map judging by the logs. Assuming you can't run higher grade fuel, the first step would be retard 1 degree under load between 5k-6k rpm. And retard 1.5 degrees above 6k and try again. And the re-test. You probably wont need to retard more than that.
Thanks
I try that and log again
Shiv@Openflash (03-24-2014)
Old 03-25-2014, 03:08 AM   #1598
Nardi330
Nardi330's Avatar
Drives: 86
hi Shiv, should i also do the same as @steve99 mentioned that i have similar issue here.
here is my log:
http://www.datazap.me/u/nardi330/22-...2-12&solo=2-12
i'm running Perrin drop in filter, Perrin Over pipe, Perrin front pipe with high flow cat and Perrin catback. Would i be better to switch to stage 2 EL rom?
thanks.
Nardi330 is offline   Reply With Quote
Old 03-25-2014, 08:38 AM   #1599
uncivilised
Drives: 86 GT
my first log
http://www.datazap.me/u/uncivilised/...&data=1-7-8-11
first fill up for e85, filled 42 litres.
60km so far
stock car using stg2 el e85 tune
Am i on the right track so far? i realise ill need to drive more for the tune to settle. i notice the kc learned drops to 3 at around 6500rpm and iam is pegged at 1.
also if i flash to e85 stage 2 EL and still use a stock header, then later i add my 4-1 catless EL header (im waiting for them to be ceramic coated), will the tune adjust automatically to the header or will i need to reflash?
uncivilised is offline   Reply With Quote
Old 03-25-2014, 09:43 AM   #1600
01s0uljah
Drives: SWP Subaru BRZ Sport-Tech 6AT
Just got the OFT and tried loading the Stage 1 tunes the tablet but it says:
The file selected is not compliant
I'm using the OTS 1.58 release..
I also wiped the tunes that came with it.. :\
01s0uljah is offline   Reply With Quote
Old 03-25-2014, 01:23 PM   #1601
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
It sounds like you are trying to a load a ROM with a different CAL ID than your original. So if your original ROM is say, a A01C make sure you load a tune with the suffix A01C.
Any reason you didn't use the OTS tunes that it came pre-loaded with?
-shiv
Old 03-25-2014, 01:57 PM   #1602
DarkSunrise
DarkSunrise's Avatar
-shiv
Shiv,
I'm thinking about buying an OFT to go along with the Nameless 4-2-1 EL header that was just released. Is there an OFT map that would work for this header? In other words, do you have a shelf map that would work for a catless EL header?
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 03-25-2014, 01:58 PM   #1603
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by DarkSunrise View Post
Shiv,
Thanks!
Yes indeed. Just use our Stage 2 EL map
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
DarkSunrise (03-25-2014)
Old 03-25-2014, 01:58 PM   #1604
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Shiv,
Thanks!
Stage2 EL for 91+ or e85 comes preloaded right on the tablet
Luckrider is offline   Reply With Quote
The Following 2 Users Say Thank You to Luckrider For This Useful Post:
DarkSunrise (03-25-2014), Shiv@Openflash (03-25-2014)
Old 03-25-2014, 02:42 PM   #1605
gramicci101
Off Topic
Newb question: is an OFT stage 1 (eventually stage 2) 91+ map something I can set and forget? I'm not going to use E85 or add forced induction, so I'm not going to get esoteric with it. Once flashed, I'd prefer to leave it alone and let it do its thing.
Old 03-25-2014, 02:43 PM   #1606
Shiv@Openflash
Drives: 2013 FRS
That is the whole idea behind the the OTS maps.
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
Blu-by-U (03-25-2014), DC2R (04-01-2014), gramicci101 (03-25-2014), Rockstar Lifestyle (03-26-2014)
Old 03-25-2014, 02:45 PM   #1607
gramicci101
Off Topic
Wonderful. Once I get to my next base I will buy one. I'm in transit right now, so I'll have to wait. Thanks for the quick response.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 03-25-2014, 04:04 PM   #1608
01s0uljah
-shiv
I didn't do my research and erased the ones it came with so I could load new ones in. I jumped the gun
I was able to get the stage 1 tune on and can instantly notice a difference. I'm new to the whole Open Flash Scene.. I'm running a completely stock Auto BRZ with a K/N air filter.. I'm guessing I should be running only Stage 1?
What would happen if I ran stage 2 on a stock car?
Old 03-25-2014, 04:50 PM   #1609
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Got my tablet in... Came pre-loaded with all I needed to cover my mods... Flashed the Stage2 UEL tune running on 94 oct and so far the car is running awesome... I am sure as I put more miles on the tune it will adapt even more. For now, its already running smoother then the OEM tune and this truly is how the car should be.
Migero86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Migero86 For This Useful Post:
Garrett@Openflash (03-25-2014), Shiv@Openflash (03-25-2014)
Old 03-25-2014, 04:57 PM   #1610
Shiv@Openflash
Drives: 2013 FRS
Glad to hear it! On a stock car, definitely run a Stage 1 map as Stage 2 will likely make the car run a bit rich.
Shiv
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
