Old 06-17-2015, 10:02 PM   #1597
cjd
cjd's Avatar
Drives: 2017 BRZ
I am looking for less understeer this weekend (I believe that's within reach, I've been running a slightly conservative setting as I gain confidence) and rear rates are higher than front (10k/12k)
So many variables. Tires, alignment, general settings, valving, ... I suppose I may change my tune as I continue to get used to the car but...
Old 06-17-2015, 10:25 PM   #1598
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Originally Posted by Thrustin View Post
Try disabling/removing the rear sway bar. I have Fortune Auto 500s with 9k/9k springs. Even with no rear bar, I have no problem rotating. It did good job of taming the beast though. And, no bar saves weight.
Your wheels are too wide for STX.
What class would my wheel set up be in? Or is it unrealistic to keep this set up? I'm not looking to be the fastest or anything, just for fun and for track one day!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 06-18-2015, 11:04 AM   #1599
EN2_Squirrel
EN2_Squirrel's Avatar
Did some relearning this past weekend after my recent deployment (10months). Was happy with car. Couldnt figure out why understeer in sweepers oversteer everywhere else. I think it is probably the driver. I am on feals. 7k/6k. -2.5 camber front -2 rear, 0 toe all round.
Sent from my SM-G900V using Tapatalk
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 06-18-2015, 11:36 AM   #1600
cjd
cjd's Avatar
Drives: 2017 BRZ
IIRC tuning suspension for transitions (which is where a heavier front rate likely comes from) will cause a little push in sweepers.
I know I have been the cause of oversteer moments in my car so far, but I'll be tuning a little more in this weekend (weather depending... More rain predicted, I may get good at wet racing this year if it keeps up.) So, while I can't say with much certainty, I'd guess setup is the push, driver is the oversteer.
Now someone gets to show me how I'm wrong
Old 06-18-2015, 01:18 PM   #1601
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Have any rake?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 06-18-2015, 03:21 PM   #1602
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
You may want to play with your rake/ride height to fix the sweeper push.
2superblus is offline   Reply With Quote
Old 06-18-2015, 04:28 PM   #1603
FRS Johnny
FRS Johnny's Avatar
Hey I think I was out there with you!
Old 06-18-2015, 05:01 PM   #1604
EN2_Squirrel
Did i mess with your damping to correct that car that I felt wasnt drivable
Old 06-18-2015, 05:05 PM   #1605
EN2_Squirrel
Originally Posted by Thorpedo View Post
Have any rake?
Yah to the rear. will be corrected somehow screwed that up when setting ride height. I blame the beer measurements. getting some time off soon will be corrected. even if it is hurting/helping(though I imagine hurting) the handling i dont like the look just sitting there.
Old 06-18-2015, 06:43 PM   #1606
FRS Johnny
FRS Johnny's Avatar
Yupp. At the end of the day it was 10 clicks front and 3 clicks rear. Felt a lot better than the first setting.
Old 06-19-2015, 12:52 PM   #1607
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Not sure what class you'd be in with those wheels. If you're just trying to have some fun, don't worry about. Find out what class you belong in and have a good time.
Thrustin is offline   Reply With Quote
Old 06-19-2015, 01:25 PM   #1608
EN2_Squirrel
Street prepared.
Old 06-19-2015, 09:56 PM   #1609
ksconekiller
Drives: Subaru BRZ
Street prepared.
That's technically true, but I would ask your class competitors if they're okay with you running what you have for now. Based on the tires you have, I doubt if anyone with a properly equipped car will care.
ksconekiller is offline   Reply With Quote
Old 06-20-2015, 06:44 PM   #1610
RedBRZ80
Drives: 2013 Red BRZ
My set up is fortune auto coils. 8/9k spring rates. wheels are 18x9.5, tires are dunlop dz101 regular street tires 245/40/18. Went to auto cross this past weekend. I tried an even setting of damping of 6/7 clicks from full soft, and it over steered way too much. Ended up with 10 clicks front and 3 clicks rear at the end of the day. It was better but still was twitchy and oversteered a bit.. I know my tires aren't that great, but does anyone have any recommendations on how to get the car a bit more neutral?
You basically get dumped into SM. Maybe use the 18x9.5 for street and pick up some 17x9s for autocross?
RedBRZ80 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
