Old 09-12-2013, 08:45 PM   #16045
Yruyur
Yruyur's Avatar
Was he not able to set up a meeting with you? I know he told me he was coming down Sunday or Monday on his way through to New Mexico.
Either way though I appreciate if anyone else is willing to.
Thank you
Not sure I didnt know he was coming through. I just figured id check here too.
Sent from a Motorola DynaTAC 8000X
Old 09-12-2013, 08:56 PM   #16046
Jstunna
Drives: Firestorm - FRS
Guys they are here!!!! My s tech springs!! Yay!!!
Jstunna is offline   Reply With Quote
Old 09-12-2013, 09:04 PM   #16047
Cross
It's the Mad Cow
Cross's Avatar
Oh I had just sent you a PM regarding it sorry.
Either way again thank you
Congrats, they are not that hard to do but having two guys makes it a lot fast especially in back. The fronts you can do without removing everything I just unbolted the brake line and ABS line from the strut and I was able to do everything with them still in the car. Just made it a little quicker.
Old 09-12-2013, 09:26 PM   #16048
Jstunna
Nice I want to do them tonight but idk never done anything like this b4
Old 09-12-2013, 09:35 PM   #16049
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
I believe a few of you are running the Perren Lightweight Crank Pulley I am thinking about picking one up and a Light Weight Flywheel. I normally lean towards just doing the flywheel as Harmonic Dampeners are never a bad thing to have.
Wouldn't mind some thoughts, the more I drive the FR-S the more I notice just how slowly it rev's and drops with the clutch disengaged.
On my stock crank Pulley are a couple of small holes drilled just part way through that are balancing holes. I'm assuming that the crank was balanced with the flywheel, clutch & crank pulley bolted together. To do things totally correct I would assume that the engine should be disassembled, bolt the new parts on the crank and have it all balanced.
If it were a race car I'd probably do all of that but for an every day street driver, I'm thinking the balancing holes were very small so the degree of original balancing needed was minimal. I'll be installing my aluminum pulley soon. I see it as an easy and cheap alternative to a light weight flywheel.
I had a car with a lightweight flywheel years ago and it did rev a bunch quicker which was nice but the down side was it made clutch engagement difficult. I really had to use a lot of revs to keep the engine from stalling because of the lack of the flywheel effect. Hopefully the pulley will allow it to rev quicker for downshifts without messing up the standing start clutch engagement.
40flash is offline   Reply With Quote
Old 09-12-2013, 10:20 PM   #16050
captain_jack
captain_jack's Avatar
So on the way home today i saw a hot lava with black wheels and hidsin the construction zone going westbound in far right lane. I tried to nod but no luck on a look back. Then as i went to get off on Ina rd i saw yet another twin, this time a white brz goin west as well in the fast lane waved at it too... Anyone here?
sent from your mom
Old 09-12-2013, 10:40 PM   #16051
jeffsides
AZ FRS 86
jeffsides's Avatar
Updated list 9-12-13. Let me know if I'm missing anything.
Sunday Sept 15th, show up as early as 8:00am
Text me for address and info 480-414-1334
Or e-mail arizona86club@yahoo.com
See you all there!!!
Just a count for tech day on who is planning on attending and projects to complete.
Projects
1. Bonks86 - headlight painting
2. Redsuns03 - pulleys, snorkel
3. Yruyur - caliper painting / springs
4. dsrttigr - vinyl
5. Jstunna - springs
6. Sakeller - headlight painting
7. Kaisuke - exhaust
8. 40flash - tail light work
9. FR-Shadow - swap springs
Guests/hangout
1. Jstunna
2. 448hpsti
3. SpyderMS
4. KIMMMIdrvr
5. Rpg1031
6. Nelsmar
7. Chrisbfrs
8. FR-Shadow
9. Fst86frs
10.ninjin
11. Bugeyedwagon
12. Knightsaber
13. Bigedb
14. Supermassive
15. Pug
Sent from ARIZONA86 HQ
@AZFRS86
Old 09-13-2013, 12:01 AM   #16052
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Does anyone with a raven want carbon fiber mirrors?
Straight swap plus 20 bucks and they are yours.
FR-Shadow is offline   Reply With Quote
Old 09-13-2013, 12:41 AM   #16053
redsuns03
Just a teaser. From Windows And Wheels Detailing
Sent from my SGH-T999 using Tapatalk 4
Old 09-13-2013, 12:51 AM   #16054
captain_jack
Interested but wanna see them. I will be up in phoenix next sat. If i want em.
sent from your mom
Old 09-13-2013, 01:13 AM   #16055
EZWood
BAMF
EZWood's Avatar
Its not a huge difference. Not enough to effect clutch engagement.
Old 09-13-2013, 01:47 AM   #16056
40flash
John 1:12
40flash's Avatar
I didn't think the pulley would affect clutch engagement. I was suggesting a light weight flywheel might depending on how light it was.
Old 09-13-2013, 04:07 AM   #16057
BugeyedWagon
Suby Specialist
BugeyedWagon's Avatar
Perrin's lightweight crank pulley provides a noticeable difference. Mine has been on the car a couple thousand miles without issue.
The real difference is the free revving and perceived improved acceleration. For the money, it's a fairly inexpensive mod that provides a noticeable improvement in drivability.
Old 09-13-2013, 04:26 AM   #16058
Supermassive
Supermassive's Avatar
Seeing as how I have a lightweight pulley and flywheel, I can let you drive mine sometime and you can see how it feels. I have 18k miles on the car and I think the pulley went on around mile 300 with no issues yet. The engine revs much faster, and drops revs just as fast, shifting can be a chore as I still get miss shifts going from 1st to second on occasion (embarrassing).
There is no added vibration or noise as far as I can tell, of course I'm so used to how my car feels at this point I doubt I would notice it either way. I am so glad the weather is cooling off soon, i need to do some work to the car, find some rattles that are bugging the crap out of me, replace pads and fluids, and reroute my air lines for my turbo. I also need to clean my air filter which I am dreading since I have to remove my front bumper to get at it. I'll use that opportunity to do some deep cleaning and tighten up all the clamps on my IC piping just in case.
Supermassive is offline   Reply With Quote
