#1583 | |
Drives: FR-S Whiteout
http://datazap.me/u/solidone/z7-kc1i...3608-3918-3925 Not 100% sure why it happens.
Intent > Content
cowardice is the mother of cruelty. |
#1584 |
You're beta testing Shiv's new tune, you should be giving him feedback.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#1585 | ||
Drives: 2013 SSM BRZ
-You're right, I've only driven 150+ km on this tune so far. How long should I be driving on a fresh flash before I should datalog more accurately? -I still had 15% of Shell 91 left in the tank, but I filled up with Petro 94. I'll try to look for Husky 94 for my next fill up. Here's my 2nd gear pull log: http://datazap.me/u/fl4tbxr/sept-2-2...0?log=0&data=1 -Oh, I didn't realize they're still in beta. I thought they were done, but just not updated on the official OFT downloads page. I will email Shiv my logs and see if he can give my feedback. (I figured the forums would have a quicker response)
________________________________
instagram - @FL4TBXR |
#1586 | |
Usually your ok after 150 km Try doing two or three light throttle runs ( say arround 10% not critical but just light strwad throttle) from 2000 to 6500 or so. Second gear just let the rpm build slowly at light steady throttle. This should kep ecu in closed loop learning mode and speed up fuel trim learning, and also reset your iam to 1 |
#1587 |
Drives: Scion FRS
http://www.datazap.me/u/nobunnyhere8...l?log=0&data=1
Still waiting on a reply from shiv been a while but I know he is busy.. Could someone let me know if this 3rd gear pull looks to be going lean and has some knocks in places they shouldn't ? This is the BETA 3.0 stage 2+ 91 tune from Shiv. On my last tunes the MAF was not properly showing but shiv helped fix that issue with the new 3.0 , not much of a power or torque difference but definitely more efficiency feels with the tune.. |
#1588 | |
Drives: UK GT86
It is pulling timing in a couple of places but noticably up top. Are you running the correct hardware for a 2+ tune as that typically occurs when there is a lack of VE (restriction) if it's not simply too advanced.
.: Stealth 86 :.
#1589 | |
Drives: Scion FRS
Right now my set up is Skunk 2 EL Catless headers, Stock OP, MXP catless front pipe, stock mid pipe with a axleback exhaust . My intake box is stock but I did cut and modify the inlet of it to allow more air that I saw be done on youtube (rookie mistake). Also running 91 premium gas from Techron Chevron. |
#1590 | |
Drives: Toyota GT86
But wouldn't it make sense that the point where it occurs is after it already switched to OL. I.e. I would assume Tactrix would still log the ECU as being in CL during the timers count down. If that is the case it would already be in OL as AFR command spikes up. Also, still, where does it get 14.7 from?
I'll keep an eye out for it in the future, but not think that much about it otherwise. If it reoccurs often on a level that it's a problem I'll try reducing the timers and see if it makes a difference. I flashed my increased timing by the way and it soaked it up so well that I'm going to add more. ![]() 8th of 8 pulls back to back: http://datazap.me/u/tor/tor-232-pull...zoom=3973-4080
#1591 | |
After the reset, it felt to be running a bit smoother at idle and noticed the IAM was steady at 1.00 for my entire drive today, which I was happy to see. Here are 2 logs from today: (Did some 2nd gear slow pulls + a 3rd gear pull to redline) Log 1: http://datazap.me/u/fl4tbxr/sept-3-2...0&data=1-12-13 Log 2: http://datazap.me/u/fl4tbxr/sept-3-2...0&data=1-12-13
#1592 | |
Intent > Content
#1593 |
Drives: Toyota GT86
I tried and it is thoroughly disappointing!
![]() ![]() Okay, the difference is also not that big. I'm up at a max of 31.17 at load 1.2 @6000 rpm. You don't see that in the log as I have 1 deg Timing Compensation per Cylinder A+B throughout up to 6400 and thereafter increasing to max 3.16. That and the rich mixture up top seems to let it accept that much timing ![]() I suppose this will be okay for the track. Tried to simulate as much as I responsibly could on backroads too: http://datazap.me/u/tor/tor-232?log=...zoom=3288-5406 And my usual autobahn pulls: ![]() The 5th gear is difficult for it (it's uphill too), but still less than -2 FLKC. Notice in 6th as it accelerates from 5500 to 5600 (uphill, no more punch), it doesn't knock at all. So that makes me want to try out this next on top of the other changes: ![]() This is within 0.35 to 0.7 deg of E85 timing between 5200 to 6000 rpm at load 1.2! I doubt this will be suitable for the track. But I want to see how far I can push it and have a 1 pull hero tune ready if I want to get it dynoed. Or maybe I will be surprised at it will work out, or I can maybe try to make changes to TCPC if it knocks.With the extra-extra timing I will already extend the top area back to 6800 rpm. The MY17 stock tune seems to use this table a bit more actively than older: Hopefully these changes should provide some actual messurable improvement.
#1594 |
Drives: Scion FRS
if my car is pulling time on my pulls, how would I correct that?? also just out of curiosity are these OTS tunes maximized with the amount of power gains you can get out of your car?
#1595 | |
I dont think anyone knows 100% how the ecu works down to these levels. I just see a lot of wrx guys that alter these timers, just worth a try What you are saying is correct, if ecu works the way you think |
#1596 |
Drives: 2015 STi
Hey all as of 1:30pm EST (September 4th) for the next couple hours datazap is going to be down as I move everything over to AWS. So in the mean time go drink some beer and do some grilling.
Sorry for the inconvenience but there were some issues popping up on the server I had been using and needed to do this ASAP. Moving forward there shouldn't be any more downtime!! Also just FYI i'm working on a Windows and OSX datazap app with some cool new features. So stay tuned!
2016 340i xDrive / 6MT / M Sport
www.datazap.me - free shareable interactive datalog viewer |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
