Old 07-19-2017, 07:26 PM   #15849
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Originally Posted by tacos View Post
cant view the photos, obv 17x9's, but what offset wouldnt clear?
i want 17x9 but its hard to find information on what fits
245/40 clears the strut by a few mm on rota rt5 with +42 offset
OrangeGuitar is offline   Reply With Quote
Old 07-20-2017, 12:32 AM   #15850
justinco
justinco's Avatar
Drives: 2022 GR86
Installed a new Blitz NUR-Spec VSR dual exit exhaust. But damn, this thing is super quiet :|
justinco is offline   Reply With Quote
Old 07-20-2017, 02:19 AM   #15851
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Originally Posted by qqzj View Post
Where did you get the sticker near the bottom of the door? Anything similar but not identical?
Also why did you swap the 2017 front bumper? It seems the fog light is gone? Thanks.
PROSTRIPE R76010
Not sure where I got it but, they are still available.
Original front bumper was suffering from serious urban assault / Twisted Sisters road rash and a dime size chunk of plastic was missing on lower part of bumper that was partially hidden by a glob of touch up paint and a generic baysonr lower lip. I've had the car almost 5 years now and normally that's about when I get the urge to trade up but, decided to do a 2.0 on the exterior to update the look, put some more miles on the ODO and wear out the tires a few more times!
The '17 fog light bezel is no longer a perfectly round hole so I guess light fixtures don't stand out like before. They are in there ...OLM combo fog and DRL LED.
Extreme86 is offline   Reply With Quote
Old 07-20-2017, 02:56 AM   #15852
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
That looks pretty sweet.
What's that jack/lift setup you have there?
BRZyJ is offline   Reply With Quote
Old 07-20-2017, 05:28 AM   #15853
Harjotdhanota
Drives: 2017 BRZ Limited
@justinco made a video about it
Harjotdhanota is offline   Reply With Quote
Old 07-21-2017, 02:34 PM   #15854
norcalpb
norcalpb's Avatar
Retrofitted vanity led lights from a Audi B7 A4.
Old 07-21-2017, 03:08 PM   #15855
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Originally Posted by Extreme86 View Post
I cringe when I see cars parked over those concrete barriers.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 07-22-2017, 11:55 PM   #15856
Chris from Cali
Chris from Cali's Avatar
Drives: BRZ PP, Golf R, V60 Polestar
Drove the family to breakfast in the "Silver Bullet" - what my daughter calls it!
Chris from Cali is offline   Reply With Quote
Old 07-23-2017, 04:39 PM   #15857
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Me, too. At least he seems to have cleared that one. I used to hear that gruesome sound regularly, but I finally learned to stop WAY back from the concrete curb, and I mean so I can walk between it and the car. Trust me, your butt won't stick out -- there's still lots of room behind the car. Remember how teensy our cars really are!
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 07-23-2017, 09:42 PM   #15858
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Fixed my OBDII port today. Easy fix once you get the OBDII plug out to a place where you can work on it. (unless you're a contortionist with perfect eyesight and patience) Pulled it out thru the opening where the climate controls were mounted. After it was repaired, I hooked up a 3 foot, low profile OBDII extension cable routed over to the passenger side so I don't have to mess with the OEM connection again.
BirdTRD is offline   Reply With Quote
Old 07-23-2017, 09:57 PM   #15859
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
Originally Posted by kpheez View Post
Installed these last Saturday, just in time for 86fest LOL.
Eibach R1 Coilovers + F&R Sway bars + LCA
Enkei RPF1,17x9 +35 on Falken Azenis 255/40/17, btw these wheels does not clear the front Brembo Calipers. 5mm spacer was not enough...needed 8mm
https://www.dropbox.com/s/r77tofnfjl..._1576.JPG?dl=0
Would this mean your effective offset is 27?
Last Lemming Alive is offline   Reply With Quote
Old 07-24-2017, 09:34 AM   #15860
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Yes. Just need them on the front though.
trippinbillies40 is offline   Reply With Quote
Old 07-24-2017, 11:47 AM   #15861
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Kenwood DDX917WS installed.
Old 07-24-2017, 12:34 PM   #15862
johan
Drives: '14 981CS, '99 NB1
very curious to see how this works out for you. I've had my eye on this HU for quite some time. Do all of the steering wheel controls work?
johan is offline   Reply With Quote
