#1569 |
Drives: silver 2013 scion frs
correction to my measurements. i actually have 18x8 et 35 oz superleggera wheel. i was looking at 245 35 18 tires im skeptical. also is there a place i can order custom centercaps?
#1570 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
Not sure on center caps.
![]() "The best track modification you can ever make is between the steering wheel and seat." - CSH |
#1571 |
Drives: BRZ Limited, WRB, 6 MT
Going a bit crazy on the tire/wheel combo's. Thinking seriously of 18' wheels. I like the RFP1's in 18x8 +45, with PSS 245/35/18 or the Raijins 18.5 +45, same tires. I also like the Rota Torques, staggered 18x8.5/9.5, square 18x8. For my WRB, Gold/Sports Bronze. DD, but maybe a school or track day (again), not looking to drop the suspension right away. Thoughts? Tire Rack says either Enkei's will fit fine. Plan to check out the Rota's at Wheel Dude.
#1572 | |
Drives: iG FR-S
Your call, bro. Are you looking for opinions on wheel choice? If so, I'd go Enkei over Rota. For DD either would work fine. 245 on an 8 or 8.5 is good.
The Following User Says Thank You to ill86 For This Useful Post: | GoSharks (07-11-2013) |
#1573 |
#1574 |
Drives: iG FR-S
No problem
#1575 |
Will this fit? (width, offset and tire size Qs)
Will stock mk4 supra wheels with 275/40-17 drag radial fit with the project kicks adapters? Or my other option is ap1 s2k wheels with 255/60-16 drag radials. Reason I'm looking at these options is that buddies have them available for me to use rater than buying a wheel and tires setup. The supra is 50 offset and the s2k is 65
#1576 | |
Drives: iG FR-S
Wheel width (also double check offset) Just rears or all four?
#1577 |
7.5" wide and they're +63 offset. I plan to run a 1" spacer due to the high offset. Just the rears yeah, no need for drag radials on the front lol
#1578 |
Drives: Argento FR-S
17x9 +20 with 215/45 17 fit?
This is your first performance car?
#1579 | |
Drives: iG FR-S
With 275 it should fit fine Rear only drag radials... Yeah yeah :-)
#1580 |
Drives: iG FR-S
It will fit but poke... 25mm - 30mm front.
215 on a 9" wheel is obviously a stretch fit. (will work fine)
![]() "The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 07-16-2013 at 08:38 PM. Reason: error |
#1581 |
Drives: Gray.
I've been getting biased opinions and I need to expand my question to a bigger party.
18x9 +33 offset. 255/35 tire. Stock suspension. Will it rub in the front? I want to keep the front full, as in chunky and full of meat. |
#1582 |
1337
Drives: 2013 BRZ WRB S/C
Stock suspension, no shouldn't have issues, at least none at the suspension side of things. If you lower you might have some issues at the fender. It's going to poke a lot at stock height. Mexi-flush for sure.
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
