Old 06-05-2014, 04:26 AM   #1555
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Originally Posted by fooddude View Post
@CSG Mike:
Obviously, race pads aren't used on the street because of excess noise and dust... but, how long do race pads last you on the streets compared to hybrid/street/track pads and also pure street pads?
If race pads wear out a lot quicker..then why do you run them on the street? ...unless of course, the wear difference between race & street pads is minimal..?
or is it because you own a shop and have all the pads you can ever want, hehe
edit:
"I wanna be like Mike" ...so should I use Club Racers, XP10, 999, etc for the DD too?? haha
Employ gratuitous amounts of engine braking.
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
fooddude (06-05-2014)
Old 06-05-2014, 05:23 AM   #1556
@CSG Mike:
edit:
My S2000 has actually seen exactly 2 sessions on track in last ~18 months, but has definitely had some canyon time.
I've run through maybe 3-4mm of pad of those last 18 months (~25k miles)
Old 06-05-2014, 09:52 AM   #1557
ZDan
ZDan's Avatar
Drives: '23 BRZ
Coefficient of friction is at maximum, so the number isn't really something you should be looking at.
Why not? If you want more braking for a given level of pedal effort, higher coefficient will give you that. That said, I would go by reports from users over published numbers from pad manufacturers.
A race pad will ALWAYS have more bite than a street pad, even at cold temps.
What?! This is not true for a many track pads, I would guess MOST of them. That's the primary reason serious track pads aren't recommended for the street, little to no cold bite. There are some that are OK, though, perhaps more now than in the past. I haven't had any issues with Carbotech XP8 and XP10 in this regard, but they definitely don't have anything like the cold bite that Hawk HP+ do.
Old 06-05-2014, 09:56 AM   #1558
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Fizz View Post
Hi guys, can you recommend a street pad which has the highest coefficient of friction, whilst still offering great cold bite.
For reference, this is going onto the rear brakes of a daily driven car, therefore cold bite is important since the rear pads will take longer to get up to proper working temp compared to fronts.
I can live with a little more dust and noise.
HP+, but don't just run them in the back, that will give you rear brake bias, which is unstable. ABS will help, but still IMO it's a bad idea. Match the front and rear pads.
In some cases rears can heat up *quicker* anyway. Smaller pads, smaller rotors, less airflow.
Old 06-05-2014, 03:32 PM   #1559
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
So what you're saying is that race/track pads actually last a long time for DD use??
Should I just use Club Racers then for a DD if I plan to track every month or so? (instead of swapping track to dd pads all the time)
fooddude is offline   Reply With Quote
Old 06-05-2014, 03:54 PM   #1560
wparsons
wparsons's Avatar
Depends on how you drive them. A track pad will wear faster at temperatures outside it's optimal range (both too hot and too cold), so if they're never heating up you'll wear them faster than if you were heating them up into their happy range.
It's not like they're going to wear out in a week though, so you're probably safe.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 06-05-2014, 06:11 PM   #1561
gramicci101
Off Topic
I've seen a few references to this, but nothing definitive.
Do coilovers have to be rebuilt every so often? If so, is it based on time or usage? Are struts the same?
Old 06-05-2014, 07:13 PM   #1562
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by gramicci101 View Post
I've seen a few references to this, but nothing definitive. Do coilovers have to be rebuilt every so often? If so, is it based on time or usage? Are struts the same?
Yes, not sure how long the rebuild period is, but it may be variable upon manufacturer. Fairly certain it's based off edit: usage not time*. Don't know about struts.
*courtesy of dem pros
The Following User Says Thank You to cdrazic93 For This Useful Post:
gramicci101 (06-05-2014)
Old 06-05-2014, 08:18 PM   #1563
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Can anyone provide some feedback on the PMU B-Spec pads? I'm able to get hold of a set locally for discounted rate...so I'm tempted to try them. Cold bite? Noise issues?
Fizz is offline   Reply With Quote
Old 06-05-2014, 09:48 PM   #1564
BrandonB
Drives: 2014 Whiteout Monogram Frs
how are bilstein b14 coilover compared to swift/b8 combo? I want it to handle like stock but better if that makes sense and also ride close to stock
BrandonB is offline   Reply With Quote
Old 06-06-2014, 01:02 AM   #1565
That's because it's not coefficient of friction... it's *peak* coefficient of friction.
Old 06-06-2014, 01:34 AM   #1566
Reasonably long yes, but keep in mind that it will probably wear your pads and rotors faster than street pads.
If you're going a month, I'd recommend you swap pads, unless you can deal with dust or want the additional bite (like i do).
fooddude (06-06-2014)
Old 06-06-2014, 01:35 AM   #1567
Yes.
It's based on usage.
Old 06-06-2014, 07:39 AM   #1568
ZDan
ZDan's Avatar
Drives: '23 BRZ
I know. Which reinforces the point that track pads generally have less bite when cold, sometimes dangerously so. But you said:
This is just not true. Some race pads have next to no bite when cold If someone is looking for cold bite on the street, he shouldn't be looking at serious track/race pads.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
