Old 07-04-2015, 06:04 PM   #1555
RKirklin
Drives: Scion Frs Turbo
Hello group fellow avo owner.
Stage 2. 10psi on 93. No build thread but I might start 1. Also dynoed at 315hp.
RKirklin is offline   Reply With Quote
Old 07-07-2015, 03:09 PM   #1556
FIREISFUN135
FIREISFUN135's Avatar
Drives: 2013 BRZ DGM
What is the size of the rubber oil line that goes between the turbo oil outlet and the oil reservoir? Mine is cracked and leaking
2013 DGM BRZ <-current
2006 WRB STi <-sold
2004 ES1 Civic <-sold
FIREISFUN135 is offline   Reply With Quote
Old 07-08-2015, 06:57 PM   #1557
onzippy
Drives: 2014 FRS
Nice Bro... Post r' in the dyno thread too if you have a nice graph to share.
onzippy is offline   Reply With Quote
Old 07-08-2015, 07:47 PM   #1558
Astroboy
Astroboy's Avatar
Drives: None
I thought anything bypassing 300whp was in the danger zone for 93oct
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-08-2015, 08:09 PM   #1559
RKirklin
Could be. I just got it finished and it's not a daily driver. Have about 100 miles on the car after the dyno tune. But in that 100 miles the only problems I have had is very high engine bay heat.
Old 07-09-2015, 06:41 AM   #1560
kbogarto
Drives: 2013 BRZ limited WRB
How are you monitoring your engine bay heat? How much hotter than stock is it running?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 08-02-2015, 05:06 PM   #1561
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Looks like I'll be joining this "club" as of next week.
Is there a Facebook group for you guys?
Any tips or suggestions - I'll need to replace the gaskets, I read there's issues one the grimmspeed ones? Having a local shop install and tune on ecutek, will have a spec2+ Clutch going in as well.
I'll post pictures after the install
bryan767 is offline   Reply With Quote
Old 08-03-2015, 01:25 PM   #1562
protpibe
protpibe's Avatar
Originally Posted by JD86 View Post
A few of you have asked about the "stage 4" turbo... This is it. I believe they use the stage 3 turbo as a base. So billet wheel and then it looks to be a modified housing with a bigger wastegate opening.
@AVOturboworld
What's the cost on the Stage 4 turbocharger? Also, will it bolt directly into an existing AVO install
Old 08-03-2015, 01:27 PM   #1563
protpibe
protpibe's Avatar
Originally Posted by onzippy View Post
I cut about an inch from the horizontal tube that goes to the BOV and put it all back together with my t bolt clamp and cable ties to the vertical member to keep it clear of the pulleys.
That tube was bottomed out on the BOV and angling it towards the left when fitted. You can see in the picture how that would keep some static pressure trying to push the main tube off the turbo. I hadn't noticed that angle on the BOV before.
I hope it works out as well for me as it did for you. Good tip.
@Sportsguy83 and his scare tactics made me check it Tuesday... I was definitely in the danger zone...
The BOV hose length should be revised on the kits being sold.
Took about 1" off of the BOV hose and everything seemed to slide into place much better.
Old 08-03-2015, 03:04 PM   #1564
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Originally Posted by protpibe View Post
@AVOturboworld
It will bolt to the existing manifold and any other parts that are not replaced. A "basic" stage 4 would be the larger turbo and intercooler/intercooler hose, plus other bits (you'll need a new windshield washer tank to fit with the larger intercooler).
Cost really depends on how far you are going + what you already have.
AVOturboworld is offline   Reply With Quote
Old 08-03-2015, 10:25 PM   #1565
Astroboy
Astroboy's Avatar
Drives: None
@protpibe did you ever rebuild your motor
Old 08-03-2015, 11:50 PM   #1566
protpibe
protpibe's Avatar
Just got a new long block out of another car. had it up and running that weekend
@AVOturboworld
Let's just say turbocharger only. Do you have a cost on that?
Old 08-04-2015, 04:05 PM   #1567
CxG
Drives: Pearl White '13 ZN6
So I've been going through the forced induction forums for days now trying to decide on which kit will best suit my needs and have almost entirely settled on the AVO stage 1 kit but have some questions/concerns.
1) can this kit be tuned to pass an OBD II NY state inspection?
2) does anyone know of an oil cooler kit or oil cooler radiator combo that fits well alongside this kit without a mounting position that limits my ability to have/use fog lights or an aftermarket bumper (was looking at the robispec oil cooler/radiator but it seems some people have fitment issues with the intercooler?) and will function in a place like NY an environment that sees both 0 and 100 degree weather (i know those are close to the extremes but it happens)
3) does anyone know the boost limitations on the stock N/A engine with a 2.5" exhaust. I'm currently on the TRD D-tip exhaust and would rather keep it (love the tone and the ability to not get exhaust tickets because OEM goodness)
4) would the down pipe and catted front pipe exhaust pieces used effect gains in any dramatic or noticeable way (been looking at the AVO ceramic coated overpipe and catted front pipe vs the motiv overpipe and thats a $300+ difference that can be used for almost anything else)
5) has anyone developed a foolproof method of an exhaust leak free install?
6) a list of sensors/gauges needed to safely run and monitor a boosted set up (oil temp gauge, afm, boost meter, oil pressure, ect?)
Any information would be greatly appreciated (whether answered or linked through to the right content). I don't plan on boosting until late spring / early summer but would really like to get all my ducks in a row you know.
CxG is offline   Reply With Quote
Old 08-04-2015, 06:32 PM   #1568
Astroboy
Astroboy's Avatar
Drives: None
Which injectors would one recommend for 300-350 hp? Preferably something cheap but reliable.. Also which flex fuel is everyone here running? I'm thinking about raising the boost
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
