go_a_way1, MisterSheep
Old 01-26-2017, 07:52 PM   #15597
Originally Posted by arxm View Post
I doubt its gas, I use either petro or shell 91/94
No I meant not getting gas.
arxm (01-26-2017)
Old 01-26-2017, 08:44 PM   #15598
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Wouldn't it also be hard to start if it's dumping too much fuel into the cylinders, which it's likely to do when things are super cold?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
arxm (01-26-2017)
Old 01-26-2017, 11:24 PM   #15599
arxm
Drives: 2013 FR-S, 2023 BRZ
ah hmm yes it could be, I'm gonna try letting it prime for a little bit longer when i start from now on and see if it makes a difference, ill post here on any findings
if this wasn't a boxer i would say id take the plugs out and check for gas in the cylinders but thats not happening lol
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
The Following User Says Thank You to arxm For This Useful Post:
Tcoat (01-27-2017)
Old 01-27-2017, 02:36 AM   #15600
ToyotaFan84
ToyotaFan84's Avatar
Drives: 2016 FR-S
I bought the RS 2.0 17" black rims yesterday and picked up my TRD quick shifter as well. I was thinking of waiting until my first maintenance date to have both of them installed but I might just do it ASAP. Once it's done, my FR-S will be fully loaded with TRD parts. =D
ToyotaFan84 is offline   Reply With Quote
The Following User Says Thank You to ToyotaFan84 For This Useful Post:
wulfstan (03-02-2017)
Old 01-27-2017, 01:23 PM   #15601
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I'd recommend having someone else install the QS. It's a pain to get your hands in there.
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
ToyotaFan84 (01-30-2017)
Old 01-27-2017, 06:47 PM   #15602
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
I replaced the stock battery in my car, after just 22 months. I'm a little disappointed, though I do have 55K miles already. Much more crank 'em now
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
trvth is offline   Reply With Quote
Old 01-27-2017, 06:58 PM   #15603
Teseo
Drives: frs
I put on layaway a set of avid 1 av20 17x8 +35 matte black, im debating if buy RCE yellows + oem strut or buy flex z. Lets wait tax seasson sales
Old 01-28-2017, 12:12 AM   #15604
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Swapped the spacer on my Jackson Racing oil cooler for the TRD Sport Guage spacer. Looks good. Mrs. S-ho even helped.
MJones_RB (01-31-2017), wulfstan (03-02-2017)
Old 01-28-2017, 10:17 AM   #15605
Nothingman
Drives: 2013 Scion FRS
Last night, I Installed Gruppe-s UEL, Gruppe-s OP, and JDL Ultraquiet FP, with a q300 catback. OFT flash stg 2 UEL E85. The feel of this car has changed dramatically (for the better), for any of you who want more power but don't want to go FI...this is it!
Nothingman is offline   Reply With Quote
The Following 4 Users Say Thank You to Nothingman For This Useful Post:
86geek (01-28-2017), brzd (01-29-2017), carsebuco (01-28-2017), jcrAggie2020 (01-28-2017)
Old 01-28-2017, 09:15 PM   #15606
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Figuring out where I have to cut the plastic on the passenger side for my Guages. I really don't like cutting.
zeal86 (01-28-2017)
Old 01-28-2017, 11:18 PM   #15607
Sapphireho
Famous Potatoes
Sapphireho's Avatar
One step closer.
The Following 5 Users Say Thank You to Sapphireho For This Useful Post:
DandoX (01-29-2017), NyC Zn6 (01-29-2017), Overdrive (01-29-2017), wulfstan (03-02-2017), zeal86 (01-29-2017)
Old 01-29-2017, 05:02 PM   #15608
arxm
so I've been letting the car prime for a bit longer when I start it and so far so good, but i think its too early to come to any conclusions, ill keep trying!
Old 01-29-2017, 10:35 PM   #15609
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Installed Thinkware F50 dash cam. :
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 01-29-2017, 10:40 PM   #15610
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Did an oil change, my oil was pretty black after just 5k. I'm at 63k now. I spilt some oil on some wires to the right of the oil cap and it made a mess all the way down to the skid plate I also fucked up and let it run for about 3-4 mins with not enough oil in, got distracted and didn't check the oil level right away. After adding 1 more quart she's now a little more full than I like but still between the dots(just so).
I hate spilling oil, it will annoy me for some time to come.. Any tips on cleaning the engine bays nooks and crannies without a full disassembly?
DandoX is offline   Reply With Quote
