09-05-2013, 09:17 PM | #15555 | |
Az to Nm to Az
It's a sleeper...I launch, it feels like it's asleep.
09-05-2013, 10:46 PM | #15556 | |
John 1:12
Drives: Pearl white BRZ Limited
I don't know what percentage of cars have windows that go up and down every time the door is opened but I do know that cars survived for a lot of years without this feature. The rubber seals are not a bank vault. They don't seal well enough to break the glass when you shut the door. Last edited by 40flash; 09-05-2013 at 11:12 PM. |
The Following User Says Thank You to 40flash For This Useful Post: | Ninjin (09-05-2013) |
09-05-2013, 10:47 PM | #15557 |
Drives: Monkey-butt red FR-S
It actually needs to enter into somewhat common usage to become a word.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
09-05-2013, 10:50 PM | #15558 | |
Drives: SWP BRZ 6MT
Sent from my GS4. Last edited by Ninjin; 09-05-2013 at 11:47 PM. |
09-05-2013, 10:57 PM | #15559 |
John 1:12
I'm confused by your comment. Are you thinking this permanently disables the buzzer or the automatic window system? If that is what you're thinking it doesn't. The switch is just for those times when you want the door open for whatever reason and don't want to listen to the door buzzer. Until you manually hit the switch everything operates just as it did from the factory. The rubber bumper you add to the door even shuts off the switch when you close the door so it's back to normal the next time you open the door.
09-05-2013, 11:00 PM | #15560 |
Az to Nm to Az
Hmmm...I'm wonder how particular their items are that it wasn't sealing up. We talking re-torque after an initial heat cycle? I mean most bolts have a torque pattern to ensure proper seating/sealing, but were talking 3 bolts? right? Per side....
09-05-2013, 11:02 PM | #15561 |
John 1:12
[QUOTE=redsuns03;1191421]This is a mod that would be great before HIN for me. Lol.[/QUOTE
If you don't have time to do the mod before HIN you could pull open the panel behind the door switch and just unplug the wire off of the switch. The switch is normally closed. It opens to shut off the light when you close the door. Unplugging the wire would keep it from chimming during the show with your door open. Would take you two minutes at the show. Last edited by 40flash; 09-05-2013 at 11:15 PM. |
The Following User Says Thank You to 40flash For This Useful Post: | redsuns03 (09-05-2013) |
09-05-2013, 11:02 PM | #15562 | |
Az to Nm to Az
Well I used it and then Ninjin used it...it's becoming common. I will then write to Merriam-Webster and ask for an inclusion!
09-05-2013, 11:03 PM | #15563 | |
Drives: SWP BRZ 6MT
Apparently its a Subaru thing. Sent from my GS4. |
The Following User Says Thank You to Ninjin For This Useful Post: | redsuns03 (09-05-2013) |
09-05-2013, 11:06 PM | #15564 |
Az to Nm to Az
Figures...It would've been fine if it were a "Toyota" thing!
09-05-2013, 11:16 PM | #15565 |
John 1:12
09-05-2013, 11:22 PM | #15566 |
Drives: 2013 frs 6spd asphalt
So I spotted two frs's and one brz at chandler fashion mall parking lot today! Awesomeness! I ordered my full exhaust and pulley and intake from vivid! Should be in tomorrow and install hopefully Monday! Ordered all their own parts and have black exhaust tips. Think that will look good with a color matched rocket bunny kit with the wing and wheels? And why can't we upload pics from the app anymore?!?
09-05-2013, 11:33 PM | #15567 |
Drives: 2014 BRZ - Crystal Black Silica
I've been using the imgur app to upload pics, then posting them in Tapatalk using their link. Kind of a shitty workaround but it gets rid of dual-pics when attached, and the imgur pics are likely higher quality.
The Following User Says Thank You to SpyderMS For This Useful Post: | Ninjin (09-05-2013) |
09-05-2013, 11:55 PM | #15568 |
AZ FRS 86
Sunday Sept 15th, show up as early as 8:00am
Text me for address and info 480-414-1334 See you all there!!! Just a count for tech day on who is planning on attending and projects to complete. Projects 1. Bonks86 - headlight painting 2. Redsuns03 - pulleys, snorkel 3. Yruyur - caliper painting 4. dsrttigr - vinyl 5. Guests/hangout 1. Jstunna 2. 448hpsti 3. SpyderMS 4. KIMMMIdrvr 5. Rpg1031 6. Nelsmar 7. Chrisbfrs 8. FR-Shadow 9. Fst86frs 10.ninjin 11. 12. 13. 14. 15. Sent from ARIZONA86 HQ
@AZFRS86
Tags |
arizona, fr-s, mesa, phoenix, scion, tucson, we need a subforum |
Similar Threads | ||||
Arizona Bill 'could' criminalize Internet Trolls | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 18 | 12-30-2013 02:54 PM |
Accessories page for Canadian BRZ owners | percyng | CANADA | 1 | 06-15-2012 07:27 PM |
FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
