Old 09-16-2021, 12:11 PM   #1541
Koba
Drives: 2020 BRZ
Oil Cooler
For those of you that track, which oil cooler are you using and where/how did you mount it. Pictures and as much info/input as possible is greatly appreciated.
So far, I am thinking of deleting the windshield washer reservoir and mounting the cooler there, may replace the stock crash beam in favour of a custom "bash bar" to help with mounting and possibly better air flow.
Thank you! (this a track only car).
Koba is offline   Reply With Quote
Old 09-23-2021, 03:56 PM   #1542
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by sly View Post
70,000 miles and running perfectly. Anyone know where to find another Cosworth Aluminum badge? The one the front of my car has faded.
https://www.rallysportdirect.com/par...aluminum-badge
Also, at what point should I consider changing the Supercharger oil? Anyone have the viscosity and capacity?
you use 75W/80 synthetic gear oil and it doesn't take much about 150ml as you fill up to the bottom of the threads in the oil plug in the front cover
eaton say the oil is generally good for 100K miles but if you think the gears are rattling then probably worth changing it
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
botbs (02-04-2022), sly (09-24-2021)
Old 10-26-2021, 04:47 AM   #1543
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have one badge in new condition. Never installed it in my car, because I am badgeless. If interested send me a message.
The Following User Says Thank You to nikitopo For This Useful Post:
weederr33 (10-26-2021)
Old 02-02-2022, 06:24 AM   #1544
Seba
Drives: BRZ Cosworth SC MY16
Hello there,
haven't been here for a while but I want to ensure that everything is ok with me and my supercharged BRZ. It's winter time, so my car is in a garage since mid November , permanently connected to a Ctek battery charger. In a few weeks it will have it's sixth birthday, and still has less than 20 kkm on odo and less than 10 thousand kilometers with Cosworth supecharger. I have a present for it : a smaller supecharger pulley, belt and new air filter. I mostly use my BRZ on highways, and during a hot summer, oil temp raises to 115'C (240'F) when driving 160-180 km/h. Maybe I need an oil cooler?
Best regards
Seb
Seba is offline   Reply With Quote
The Following User Says Thank You to Seba For This Useful Post:
weederr33 (02-03-2022)
Old 02-02-2022, 07:46 AM   #1545
tomm.brz
Drives: brz 2017 hksv2
yes, go for the cooler
Old 02-03-2022, 12:43 PM   #1546
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
I have just over 70,000 miles on the car and 50,000 miles (80k km) on the supercharger. I have had the smaller pulley installed the entire time and have installed the Crosstrek OEM oil cooler. I also have a Mishimoto oil catch can. These are my only two aftermarket upgrades...
This car is my daily driver and the performance and reliability are perfect. I have driven it in the snow, on long trips and frequent stop an go traffic. For me, this supercharger has performed flawlessly.
For maintenance, I change the oil, air filter, rotate the tires and empty the catch can and replaced the belt once. I also spray off the mass air flow sensor when I do an oil change. The only problem I ever had out of the car was it wouldn't start one time. One of my coolant hoses back near the firewall had slipped down and was resting on the wire which runs to the starter. It had unplugged this wire and so the car wouldn't start. I wire wrapped the coolant hose so it couldn't fall down again and the problem has never reoccurred.
I get around 29-30 mpg real mileage as calculated from the odometer. It's been through 3 sets of tires and these latest are by far the best for me. I run Michelin Pilot Sport A/S 3+ tires. They outperform the Pilot Sport 4S which I had on before this and have lasted much longer... Plus are cheaper.
This car has such an amazingly smooth power band. It's so linear that it feels almost like an electric car. Cosworth did an amazing job and made this car what it was supposed to be. It's just a shame that they don't make them anymore because they really had something here....
sly is offline   Reply With Quote
The Following 3 Users Say Thank You to sly For This Useful Post:
botbs (02-04-2022), Brz-123 (07-05-2022), weederr33 (02-03-2022)
Old 04-05-2022, 08:21 PM   #1547
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Hi All,
Anyone experienced blue smoke in the exhaust after tracking the car? The track I went has some elevation change and two other NA BRZ/86 has similar issue after 2 sessions as well. Two mechanics at site suspect that it is the PCV issue.
I have a catch can already but we think the oil somehow suck back in to the engine (due to the g force?) but not 100% sure. The blue smoke on my car is relatively less than the other two 86/brz. After driving on the hwy under 4k rpm for 30 min, all the blue smokes are gone and things are back to normal.
Any suggestions on how to prevent this?
Do we need this for our supercharger?
https://jacksonracing.com/product/pcv-valve/
https://www.ft86motorsports.com/suba...lications.html
https://www..com/forums/showpost.php?p=1894829&postcount=754
Not sure how to tag Matt@Cosworth here, can someone help?
Thanks!
botbs is offline   Reply With Quote
Old 04-06-2022, 08:10 AM   #1548
tomm.brz
Yes you should upgrade the pcv
that jackson valve looks good and very cheap, i d take it
The Following User Says Thank You to tomm.brz For This Useful Post:
botbs (04-06-2022)
Old 04-06-2022, 06:29 PM   #1549
botbs
botbs's Avatar
Did you upgrade the STI PCV? I heard the size is a bit diff, I guess just have to change the hose?
Thanks
Old 04-06-2022, 11:00 PM   #1550
tomm.brz
the wrx sti PCV is compatibile and yes i have that
but i would prefer to have also that Jackson racing one way valve too, seems more robust
botbs (04-06-2022)
Old 08-18-2022, 06:34 AM   #1551
kaisersalsek
Drives: GT86 TRD
Originally Posted by botbs View Post
Hi All,
Thanks!
Haha - came here to see if anyone else was having this! It only happens very briefly for me on a cold start after being on track, and happened after two morning sessions last time. The tracks I've been on so far have elevation changes too (next one is flat, will be interesting to see if that makes a difference). I guess it's reassuring to know it's not just me lol - will check out the PCV valves linked here.
kaisersalsek is offline   Reply With Quote
The Following User Says Thank You to kaisersalsek For This Useful Post:
botbs (08-18-2022)
Old 08-18-2022, 11:01 PM   #1552
botbs
botbs's Avatar
I changed the PCV and it worked all the blue smoke are gone. Also make sure not to overfill engine oil
The Following User Says Thank You to botbs For This Useful Post:
nikitopo (08-19-2022)
Old 02-15-2023, 01:30 PM   #1553
Zombiecidal
Zombiecidal's Avatar
Drives: 2018 BRZ Ts
this kit looks amazing, i want to SC my car but i only want the best and this looks like the one to get. Anyone looking to sell their Cosworth kit?!
Zombiecidal is offline   Reply With Quote
Old 02-15-2023, 03:04 PM   #1554
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Good luck finding the kit! They were rare even when Cosworth was still producing them simply due to their outlandish price. Still, it was an amazing kit and super reliable when I had it on my FR-S and the Cosworth calibrations needed minimal tweaking. Sadly, by this point if you can find one, the only support you will get is from a parts bin (if you gotta fix the kit) and a different tuner who may or may not have tuned a Cossie kit before.
MS, CSCS, TSAC-F, CPT
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
