Old 03-19-2014, 11:45 AM   #1541
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Tbor View Post
That makes perfect sense! Thank you, guess ill just have to wait for my OFH to come before i switch to stage 2.
One last question, I am completely stock, but want to run an e85 map.
Even tho stage 2 is designed for catless aftermarket headers, can i still run the stage 2 EL e85 map?
It has been shown that the EL e85 Stage 2 2 is safe with stock headers. I am running that way now.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Tbor (03-19-2014)
Old 03-19-2014, 03:58 PM   #1542
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
oft300 93 octane new log opinions please
http://www.datazap.me/u/cjsporl/oft3...7-8-9-10-11-12
cjsporl1996 is offline   Reply With Quote
Old 03-19-2014, 04:28 PM   #1543
amaciose
amaciose's Avatar
Is the main difference between Stg 1 and Stg 2 specific to stock vs. aftermarket or catted vs. catless? Speaking specifically about the FT86SF UEL header, would the Stg 2 tune run any different between the catted and catless version?
Sent from my SCH-I545 using Tapatalk
amaciose is offline   Reply With Quote
Old 03-19-2014, 06:57 PM   #1544
Kodename47
Kodename47's Avatar
Drives: UK GT86
Looking at the WOT pulls the AFRs look good and the IAM is steady at 1. I'm guessing you stopped the pulls early for safety? Have you looked at the map to see what you're actually targeting?
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
cjsporl1996 (03-20-2014)
Old 03-19-2014, 07:21 PM   #1545
phrosty
I asked Perrin directly for MAF tables for their small intake, and they delivered!
Here you guys go: 2.75" PERRIN intake MAF sensor scaling.
Now that we've got this, is it easy to integrate the values into a ROM? I'd appreciate if someone could write up a quick DIY or provide a link that doesn't confuse the issue with a whole custom scaling.
phrosty is offline   Reply With Quote
Old 03-19-2014, 08:32 PM   #1546
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Having received my OFT, installing software and reading my cars ROM. Since I won't get her out of garage yet, I was poking around in my Original.bin, found that I could compare .bin's and loaded the OTS stock bin. After running the comparison tool there seemed to be quite a bit of difference between the two bin files. Would I be correct to think that this wouldn't be caused by the transmission (MT vs. AT)?
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 03-19-2014, 08:41 PM   #1547
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Did original.bin and your comparison .bin file share the same Cal ID (i.e., ZA1JA01C)? If so you will see quite a few differences due to tuning changes. If they did not share the same ID, there will be many more differences since map locations (among other things) will be at different address locations.
If you are looking at the .bin file in a hex viewer you can see Cal ID (text format) at 0x8000.
Cheers,
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Blu-by-U (03-19-2014)
Old 03-19-2014, 08:42 PM   #1548
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
Just got mine today.. amazing!
I noticed the stock ROM calibration code was 00C and then it installed a 01C ROM.. is this ok?
After I noticed and drove for a bit.. I got home and downloaded the new 1.58 ROMS and took the 00C ROM and flashed that. I also did 1 tweak and set LC to 3600 RPM down from 5600 RPM).
The cold start and idle corrections are amazing!
What is the difference between the versions?
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 03-19-2014, 08:54 PM   #1549
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's fine. C denotes the type of ROM which is specific the ECU. The rest are release versions. A01 is one of the more recent.
IIRC: 700 > A00 > A01 > B01
So long as you're on A01 or B01 then you're on the latest ones.
@phrosty have you opened the MAF scaling map in RomRaider? As it's only a 2D map, I bet you'll work out how to import it. You should be able to C&P direct from excel etc
.: Stealth 86 :.
Kodename 47 DJ:
phrosty (03-19-2014)
Old 03-19-2014, 09:00 PM   #1550
pgeist
pgeist's Avatar
So what are the main benefits or drawbacks of using a B rom over an A rom.. any difference?
Old 03-19-2014, 09:02 PM   #1551
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Yes, they had the same ID. Am being very careful about my forward progression. I'd like to do some data logging before I change anything about the way she is tuned. Waiting for the snow to go.
Cheers,
Shiv
Old 03-19-2014, 09:15 PM   #1552
steve99
Make sure you have a copy of your original (unedited) ROM in case of problems
1. Open up your tune ROM in Romraider
2.select "intermediate" or above user level
3. select "mass air flow/engine load" folder on left hand side
4. select "MAF sensor scaling" table
5. copy in the volts and air flow values in as supplied by perrin
6. save
7. flash
Log and test
Old 03-20-2014, 01:09 AM   #1553
cjsporl1996
Question: does it matter if I use 92 octane on the oft300 93 octane tune. We don't always have 93 octane in my area it depends on the station.
Old 03-20-2014, 04:34 AM   #1554
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'd assume that the map isn't running on the ragged edge of knock on 93 so it's probably fine. Just keep the OFT in view with knock related parameters including IAM to know that the car is running ok.
.: Stealth 86 :.
Kodename 47 DJ:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
