Old 06-23-2015, 03:36 PM   #1541
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by protpibe View Post
Yeah good call, I forgot I'm running SD lol
pls disregard my previous no-care attitude towards that inlet pipe if you're using your MAF haha
I was actually about to add the caveat about don't care if running SD, didn't add it because most AVO owners run MAF. But, I will go back and make the distinction.
Old 06-24-2015, 03:10 PM   #1542
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by JD86 View Post
I was having the inlet hose come off repeatedly to the point the fan belt ate a hole in it and I had to replace it. When I did the replacement we made a few changes. We trimmed the BOV pipe as this was pushing the alignment out. I swapped the standard clamp out for a T bolt clamp. Lastly I put a couple of cable ties around the inlet hose and one of the hoses to the left (looking at the front of the car). I'm pretty sure it was the intercooler hose, but can't visualize it right this second...
Anyway end result is that the intake hose hasn't come off since and that was some eight months ago. Total cost of fix - 1 T bolt clamp, 2 cable ties, half an hour stuffing around.
Did you trim the 4-5 inch tube which connects the bpv to the intake tube?
Astroboy is offline   Reply With Quote
Old 06-27-2015, 02:19 PM   #1543
onzippy
Drives: 2014 FRS
I cut about an inch from the horizontal tube that goes to the BOV and put it all back together with my t bolt clamp and cable ties to the vertical member to keep it clear of the pulleys.
That tube was bottomed out on the BOV and angling it towards the left when fitted. You can see in the picture how that would keep some static pressure trying to push the main tube off the turbo. I hadn't noticed that angle on the BOV before.
I hope it works out as well for me as it did for you. Good tip.
@Sportsguy83 and his scare tactics made me check it Tuesday... I was definitely in the danger zone...
onzippy is offline   Reply With Quote
The Following 3 Users Say Thank You to onzippy For This Useful Post:
kbogarto (06-27-2015), protpibe (08-03-2015), Sportsguy83 (06-28-2015)
Old 06-27-2015, 02:21 PM   #1544
Astroboy
Astroboy's Avatar
Drives: None
What did you use to cut it? A dremel?
Sent from my LG-D850 using Tapatalk
Old 06-27-2015, 02:25 PM   #1545
onzippy
Drives: 2014 FRS
Wrapped with some blue tape to get a good circle all the way around.
Marked with silver sharpy.
Cut it with hacksaw. It made a very clean cut.
Old 06-27-2015, 05:15 PM   #1546
M1K3
M1K3's Avatar
Drives: vrooom...
For me I cut the silicone with an X-Acto knife, it made really clean cuts too.
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
Astroboy (09-03-2015)
Old 06-28-2015, 02:33 AM   #1547
Skorov
Skorov's Avatar
Drives: 86 GTS White
A trick I learned recently:
Put a hose clamp around the hose as a cutting guide. Use a scalpel or another very sharp knife to cut around, having the knife always touching the clamp. Straight cut every time!
Skorov is offline   Reply With Quote
The Following User Says Thank You to Skorov For This Useful Post:
Brzzee (07-07-2015)
Old 06-28-2015, 07:04 AM   #1548
JD86
Drives: 2013 Toyota 86 GT
As above, cut the BOV hose, doesn't need to take much off, maybe an inch or so... Cable tie around the intake hose to turbo hose. No problems since.
JD86 is offline   Reply With Quote
The Following 3 Users Say Thank You to JD86 For This Useful Post:
Astroboy (09-03-2015), onzippy (06-29-2015), protpibe (08-03-2015)
Old 06-30-2015, 07:47 AM   #1549
JD86
A few of you have asked about the "stage 4" turbo... This is it. I believe they use the stage 3 turbo as a base. So billet wheel and then it looks to be a modified housing with a bigger wastegate opening.
The Following 5 Users Say Thank You to JD86 For This Useful Post:
Astroboy (06-30-2015), Draco_PR23 (06-30-2015), M1K3 (06-30-2015), protpibe (07-01-2015), Sportsguy83 (07-07-2015)
Old 06-30-2015, 07:37 PM   #1550
solus
Drives: 2014 Scion FRS (Ultramarine)
I'm on E85 and should be over 300hp with stock fuel system at 8psi.
solus is offline   Reply With Quote
Old 06-30-2015, 07:44 PM   #1551
onzippy
Drives: 2014 FRS
Was that a drunk post? I'm on Jim Bean 80 proof so this should be one.
The Following User Says Thank You to onzippy For This Useful Post:
JD86 (07-01-2015)
Old 07-02-2015, 11:23 PM   #1552
Astroboy
Astroboy's Avatar
Drives: None
Finally got the avo oil cooler installed and I love it
Old 07-03-2015, 02:46 AM   #1553
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@JustBoostin
Old 07-03-2015, 09:02 PM   #1554
Astroboy
Astroboy's Avatar
Drives: None
What percent is your engine load at idle? Does it easily go to 90-100 percent while mildly accelerating on first gear?
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
