Old 05-06-2014, 03:45 AM   #1527
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by sales@delicioustuning.com View Post
A small bit to mention here and forgive me if I am wrong...but Canadian gas is in no way comparable to California gas, even at the same octane level. What is it up there, 91 or 93? Our 91 here in CA does not perform the same as a 91 in any other state. It's much worse here. Food for thought.
Sincerely,
Zach
91,93,94 here. However most widely available is 91 for sure.
Old 05-06-2014, 06:58 AM   #1528
Dipstik-sportech
Dipstik-sportech's Avatar
91 octane only up where I am and ask any tuner who's done both and they'll say that they're comparable in octane, we've actually been asked if it's 89 lol though the Canadian is slightly worse due to winter blends.
Both our cars were tuned by the same person with the same engines and turbos and made near as makes no difference the same power. Now a larger turbo was installed and at the same psi he makes less power.....? Am I the only one who doesn't understand what is going on?
The Frozen North
Old 05-06-2014, 08:28 AM   #1529
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Why did you go with 9:1? You could have made more power on a stock bottom end.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-06-2014, 09:04 AM   #1530
Dipstik-sportech
That's what I don't get. He's making less power than people with stock engines and smaller turbos.
I went built because our gas is crap and I wanted the safety factor with larger numbers
The Frozen North
Old 05-06-2014, 09:06 AM   #1531
Reaper
Reaper's Avatar
Drives: violent
That's why I almost put new rods in with factory pistons. That an e85.
Old 05-06-2014, 11:40 AM   #1532
xwd
I've thought about that myself since the rods seem to be the real issue. Or get some JE 13.5:1 pistons.
The Following User Says Thank You to xwd For This Useful Post:
Sportsguy83 (05-06-2014)
Old 05-06-2014, 11:42 AM   #1533
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thought abut that too, but since we can also get custom comp. ratio I'd just get custom 12.5:1 like stock and call it a day.
Old 05-06-2014, 12:38 PM   #1534
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The Frozen North
It could be a great many factors weighing in here. For one, given the same conditions and just changing compression, the lower compression motor will always make less power. That said, his motor is actually slightly lower compression than yours at 9:1 vs 9.5:1. Not sure if that is really such a huge factor with such a minute change. Where they both may be 91 octane, CA 91 performs much closer to an 89 from every other state here in the US. Not only that, your turbo is actually the larger of the two if we're looking at wheel size here. Your PTE5858 uses a 58mm inducer vs his 51, and 58mm turbine wheel vs his 54. I don't know where this larger turbo statement came from. Moral of the story here is there are far too many fine details to consider and no reason at all to point fingers. If pmccut wants to make more power now he is more than welcome to come back and we'll swap in the larger injectors. When Bill says the larger injectors sacrifice a bit of drivability, that's the perfectionist side of him talking. You or I would likely not notice a hit in that area at all, and instead be enjoying all the extra power to be gained.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
SmsAlSuwaidi (05-06-2014)
Old 05-06-2014, 12:52 PM   #1535
Dipstik-sportech
The larger turbo statement came from him starting with him starting with a gt28 and stepping up to a 3076 to which he made no more power on the same psi. He was tuned on the same fuel he had when it was done the first time so that's not the issue unless he did in fact get 89 instead of 91. What I don't get is y go back to the stock injectors? Y not go to say the 550s and not run them at 100%? Your drivability should be near stock anyway because you don't cruise on the ports. I have 1000's and with the speed density tune my drivability is fine. Just help me to understand the logic behind running stockers at 100% vs 550' at say 75%? Would it not give you more head room and a greater margin of safety?
The Frozen North
Old 05-06-2014, 12:54 PM   #1536
Dipstik-sportech
Originally Posted by pmccut View Post
I never imagined the car would make less power at the same boost level
Does that statement not tell you he's not happy with the power levels?
The Frozen North
Old 05-06-2014, 12:58 PM   #1537
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Soooo, I can smell coolant in my engine bay, but my exhaust is clean as a whistle.
Almost smells as though it is coming from the radiator. But its not consistent.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 05-06-2014, 12:59 PM   #1538
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Water lines going to the turbo ?
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
blackfireball5 (05-06-2014)
Old 05-06-2014, 01:00 PM   #1539
Dipstik-sportech
Is your overflow over full? Could be burping out and getting on the exhaust. Is it loosing coolant or do u just smell it?
The Frozen North
Old 05-06-2014, 01:02 PM   #1540
SmsAlSuwaidi
Boosted
The Frozen North
Sent from my IBrick
The Following 4 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Deadspool (05-06-2014), Dipstik-sportech (05-06-2014), Ironsquid (05-06-2014), Sportsguy83 (05-06-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
