#141 | |
NW Region Moderator
Drives: FR-S No More
| The Following User Says Thank You to DarrenDriven For This Useful Post: | ill86 (08-27-2012) |
#142 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
Fwiw, i ended up ordering the h-tech. I'll post pics after install.
"The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 08-27-2012 at 07:21 PM. |
#143 | |
Drives: WR blue
just to make sure.is that true that the KW weight more than the stock?if so,y changing it?
#144 |
Conedancer
Drives: 2013 Subaru BRZ SWP
adjustability..
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#145 |
Drives: 2013 FRS
where can we source Espilar springs for a 10-15mm drop?
#146 |
I'm about to buy a set of KWs
subscribed |
#147 |
NW Region Moderator
Added new topic about KW v3 coilovers...
http://www.ft86club.com/forums/showthread.php?t=16068
#148 |
NW Region Moderator
I emailed Megan about the minimum and maximum lowering amounts, and they replied that there are far more important specs to worry about (true) and that they didn't even bother to measure the two heights. Strikes me as a little strange, but we'll just have to wait for a consumer to report back to us.
#149 |
Drives: WRB MT-BRZ LMTD
How much would it typically cost to lower your cars and what kind of work is involved?
Need to have a professional do it?
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#150 | |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
I just looked at the rates and wondered how this picture. ![]() would look anything like a 1" inch drop more like 15mm at the most, and the 4.7 rear rate makes me wonder if this will get more tail happy than it already is?
#151 |
NW Region Moderator
Added retail pricing for the Race Comp Yellows ($349)
#152 |
Drives: Whiteout FR-S
I got my Tein H Techs in and in the instructions it says -25mm front and -20mm rear. I was hoping they were the new spec...
#153 |
Drives: iG FR-S
I called Tein. He was confused and told me the rate was what was listed online. Although the spring and literature recieved was 3/4.6 -25/-20.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#154 |
why are most companies running such stiff rear coils???? Its almost hard to find a soft rear aftermarket coil, for those of us not trying to drift but rather keep the rubber from slipping? I drove the TRD coils this weekend and the rear was way too stiff. ride height ok, compliance-none
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 04:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 11:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 09:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 02:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 01:52 PM |
