Old 05-26-2016, 10:58 AM   #141
MAPerformance
Drives: Asphalt FRS
In theory it should. I haven't used that one before, but we just installed a universal Grimmspeed one a few weeks ago that worked very well the the Delicious Tuning kit.
http://www.maperformance.com/product...itments-057032
Originally Posted by sosick View Post
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
sosick (05-26-2016)
Old 05-26-2016, 05:48 PM   #142
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
I suppose ill have more questions for p and l. And ill look into the grimmspeed one. A part number would be nice!
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 05-27-2016, 07:04 AM   #143
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yes totally depends if you want manual or electronic!!
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
sosick (05-27-2016)
Old 05-27-2016, 08:41 AM   #144
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Excuse my ignorance but using a manual boost controller would allow you to make more boost but wouldn't the tune have to be adjusted/redone to properly operate the vehicle at whatever psi you would like? Like fuel pump or injectors would have to be working at a different rate at 10psi vs 16psi right?
MooKz is offline   Reply With Quote
Old 05-27-2016, 11:17 AM   #145
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Ideally, yes. Some shops I've seen run the same timing at all PSI levels. It is not ideal, and I will always recommend using an electronic boost controller so each map can be fully optimized per set boost level.
However compensations can be made via custom mapping in Ecutek to adjust things like timing based off detected manifold pressure (boost level).
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
sosick (05-27-2016)
Old 05-27-2016, 02:39 PM   #146
sosick
fastest frs in sbg
sosick's Avatar
Contacted p&l today. They advised me to get the 4 bar and they have hoa ebc in stock. All i need now is clutch. Mishimoto fans and 1100cc fic injectors ordered. Anything else i need for my 5558 turbo setup?
2014 firestorm frs
Old 05-27-2016, 03:41 PM   #147
MAPerformance
Drives: Asphalt FRS
Did you order the fuel pump?
Old 05-27-2016, 04:36 PM   #148
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Big injectors for the power your going for lol
Old 05-27-2016, 04:39 PM   #149
MAPerformance
Drives: Asphalt FRS
Maybe just do the DW700's?
SoCal80six (05-28-2016)
Old 05-27-2016, 06:27 PM   #150
sosick
fastest frs in sbg
sosick's Avatar
The kit i ordered on amazon was ur turbo kit with a 5558 turbo and the fuel pump came with it
2014 firestorm frs
Old 05-27-2016, 06:28 PM   #151
sosick
fastest frs in sbg
sosick's Avatar
Wanted to do flex fuel, seems like most ppl runs these with e85
2014 firestorm frs
Old 05-27-2016, 06:33 PM   #152
sosick
fastest frs in sbg
sosick's Avatar
2014 firestorm frs
Old 05-28-2016, 04:58 PM   #153
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Might want to look into getting their extra 1.5 qt oil pan. Makes life so much easier I can picture trying to tap into stock oil pan being a huge headache ahah.
Old 05-28-2016, 05:00 PM   #154
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Definitely don't think there's any need for bigger especially for a stock block.
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 09:14 PM
MAPerformance Turbo Kit Officially Released! MAPerformance Forced Induction 633 07-26-2014 10:42 PM
AVO stage1 turbo kits now at MAPerformance! MAPerformance Forced Induction 37 01-13-2014 09:53 AM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
