Old 04-01-2014, 09:23 AM   #141
1Cor10:23
1Cor10:23's Avatar
Originally Posted by shiv@vishnu View Post
Fwiw, we will be offering the BPB at $300 to all our OFT customers who want to/can cash in $100 OFT dollars. We will also offer an OFT+BPB combo package as well. Prices to be released on wed
Curious, any idea of when they would be ready for shipment? Thanks!
Old 04-01-2014, 10:52 AM   #142
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Originally Posted by nelsmar View Post
As I have been asked by a number of individuals... I went ahead and emailed Perrin today asking if they want to work something out for me to borrow / purchase an intake to test along with these manifold spacers.
You will find the stock intake with a tune will make the same power as an aftermarket intake with a tune.
Crawford Performance is offline   Reply With Quote
Old 04-01-2014, 10:53 AM   #143
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
What if it's Perrin's 3" intake? I have one of those with a tune and was planning on getting the BPB with it.
JDogg is offline   Reply With Quote
Old 04-01-2014, 10:55 AM   #144
w00t692
Drives: 2008 Civic Si
Has there been any attempts to length tune intakes on this car? Or is it not feasible with engine bay space?
Length and diameter tuning as well as transitions there SHOULD be some power to be had...
w00t692 is offline   Reply With Quote
The Following User Says Thank You to w00t692 For This Useful Post:
TouchMyHonda (04-01-2014)
Old 04-01-2014, 10:58 AM   #145
Drives: 2008 STI
Sorry if I confused the original question. Our BPB will add power and torque to any existing mod on your car.
The Following User Says Thank You to Crawford Performance For This Useful Post:
JDogg (04-01-2014)
Old 04-01-2014, 10:59 AM   #146
JDogg
JDogg's Avatar
Nice, def can't wait!
The Following User Says Thank You to JDogg For This Useful Post:
Crawford Performance (04-01-2014)
Old 04-01-2014, 11:03 AM   #147
Drives: 2008 STI
The aftermarket intakes manipulate the maf sensor voltage, this is where the extra power comes from. Other than that there is not much to be had as the stock one works quite well. The aftermarket intakes are only beneficial if you are not going to tune the car.
hmong337 (04-01-2014)
Old 04-01-2014, 11:06 AM   #148
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Disappointed this won't fit with my strut tower bar, lol These raise the manifold 35mm, correct?
Propaganda is offline   Reply With Quote
Old 04-01-2014, 11:07 AM   #149
JDogg
JDogg's Avatar
It might fit if you take the cover off, that's what I plan on doing.
Old 04-01-2014, 11:09 AM   #150
Propaganda
I took it off and measured from the highest point... I still had about 30mm of clearance
Old 04-01-2014, 11:13 AM   #151
Drives: 2008 STI
You are going to trade looks for performance? Strut bars look kool but power is what these cars lack
The Following 6 Users Say Thank You to Crawford Performance For This Useful Post:
86-tundra (04-01-2014), DAN_BRZ (04-01-2014), FRSTRM (04-01-2014), hmong337 (04-01-2014), J.C. (04-01-2014), wparsons (04-01-2014)
Old 04-01-2014, 11:17 AM   #152
Propaganda
Can't deny that, haha. But the strut bar was a gift to me, so I'm a little attached to it I may eventually pull it or switch to a different brand, but for now I plan to hold off for a bit. On the bright side, It's a 3-piece, so I only need to replace the bar connecting the struts, and not the whole thing
Old 04-01-2014, 11:20 AM   #153
mid_life_crisis
Drives: FR-S 10 #103 AT
Probably not as helpful on an FI setup as NA as the dynamics of air being forced into an engine are different than when being drawn into an engine. I'm not an expert so don't ask me to elaborate: this is just what I remember from physics class and reading about motors.
Aftermarket intakes might be useful in the area where these blocks shine. Testing seems to be indicating that the factory intake becomes a limiting factor at high rpms. Even if the intake you select does not cheat the MAF sensor, if you have made mods that are moving more air at high rpms, a less restrictive intake should allow those mods to move even more air.
FI systems do away with the factory intake for two reasons;
1) It's big and in the way.
2) It's at its limit and FI needs access to a lot of air.
It's a decent system, but it was designed for an engine that was set up a certain way. It looks to be just enough to handle the factory engine. Once you start making other changes, you need to look at changing the intake too.
At least that's what I get from all the reading I've done.
Just changing the intake all by itself won't accomplish much, but changing it as a supporting mod for other mods makes sense.
EDIT: As Crawford pointed out further along, there is a third (probably #1) reason.
3) MAF sensor scaling on the stock intake is insufficient for a serious FI system.
Last edited by mid_life_crisis; 04-01-2014 at 11:38 AM. Reason: Additional information
Old 04-01-2014, 11:23 AM   #154
wparsons
wparsons's Avatar
^^ IMO, the only reason most FI kits ditch the factory airbox is because it's in the way and doesn't work with the plumbing they need to run.
The Innovate kit runs the stock airbox without issue at all.
flickr
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 10:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
