Doborder, orthojoe
Old 08-20-2013, 09:12 AM   #141
Skyllz
Drives: Something fun.
Originally Posted by regal View Post
Just drive it like grandma in her Subaru and you'll be fine.
I bought a sports car and I cant have fun with it... fuck me right.
I'm driving this until November, then it's in storage for the winter, if nothing comes up on the OEM side of things(ECM update) i'll probably get a header/tune or keep it stock and trade it in on a new WRX when they come out... Time will tell.
Skyllz is offline   Reply With Quote
Old 08-20-2013, 10:12 AM   #142
regal
Exact same here, don't drive it like a sports as changing di seals is a major pain, I think a header+tune will turn into a must do for these cars. Still better than a WRX to me, all cars have quirks we just need to find solutions instead of waiting on Toyota or turning a blind eye in denial.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 08-25-2013, 06:33 PM   #143
SilverCard
SilverCard's Avatar
Drives: 2002 EP3
Hahaha the foul language makes the video more appealing! Good writeup!
SilverCard is offline   Reply With Quote
Old 11-01-2013, 12:47 AM   #144
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Thank you so much
TouchMyHonda is offline   Reply With Quote
Old 11-01-2013, 01:39 PM   #145
empower-auto
Kouki-Monster
empower-auto's Avatar
Do you also live in Toyota City?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-02-2013, 11:26 AM   #146
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Changing my direct injectors due to a failure, I have a BRZ.
Does anyone know if there is any issue using Toyota injectors in my BRZ as I can get them loads cheaper.
My Injectors are "Mark 2"
Subaru part no. = 16611JB020
Toyota part no. = SU00304461
Any feedback would be great
ahaghshenas is offline   Reply With Quote
Old 11-02-2013, 11:37 AM   #147
Mikem53
Drives: FR-S 6MT
Same injectors .. Different part number.. Just be sure the mark 2 is the same for all..
Mikem53 is offline   Reply With Quote
Old 11-02-2013, 11:46 AM   #148
ahaghshenas
Drives: Subaru BRZ
Good to know, havent actually properly looked at each injector just assumed there all the same.
Old 11-04-2013, 12:27 AM   #149
Dezoris
Dezoris's Avatar
They will be all the same, and yes critical to make sure you order all the same number.
Old 11-16-2013, 04:49 PM   #150
Dan@AWD
Drives: 2013 Argento FR-S
Has anyone ever thrown a P0301 code (cylinder 1 misfire) and had a bad DI seal?
What symptoms did everyone experience with a complete DI seal failure?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 11-17-2013, 02:43 PM   #151
Dezoris
Dezoris's Avatar
if you have constant misfires on one cyl. check your coil if thats bad I would pull the injector for inspection.
Old 11-17-2013, 05:45 PM   #152
Dan@AWD
I currently have a bad misfire and popping from my exhaust.
I have done the following. Changed coil on #1, pulled plugs (looked fine comparing 1 & 3 plugs), swapped injectors on 1 & 3. No matter what I do same P0301 code. I'm lost. Cylinder 1 is passenger front correct?
Old 11-18-2013, 01:02 PM   #153
Dezoris
Dezoris's Avatar
You already swapped the direct injectors on 1 and 3? Did you do compression tests?
if you did I would only suggest replacing the opposing cylinder coil and DI. You have a stable flash or you on oem ecu tuning?
Old 11-26-2013, 08:58 PM   #154
aCab
aCab's Avatar
Drives: FR-S & S2k
Did I miss a complete parts number list? Just had warranty work denied on my DI seals, so I have to do them myself. Anyone have an SST tool I can borrow? I'll pay shipping.
Bilstein Damptronic Prototypes | Other silly bits
aCab is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 07:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 01:35 PM
Direct Injector Failure Poll track_warrior Issues | Warranty | Recalls / TSB 553 01-12-2017 07:12 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 10:31 AM
