Old 07-12-2013, 07:14 PM   #141
Yruyur
Yruyur's Avatar
Finally took the scratch protector cover off the analyzer screen. Looks much better.
Sent from a Motorola DynaTAC 8000X
Old 07-13-2013, 02:10 AM   #142
JiB
JiB's Avatar
Drives: GT86
Didnt like how ugly the display was so made it more subtle
making a nicer plate to cover the plastic, but the main leg work was done today
JiB is offline   Reply With Quote
Old 07-13-2013, 08:21 AM   #143
Yruyur
Yruyur's Avatar
Wtf thats awesome!! Any details?
Old 07-13-2013, 08:24 AM   #144
Visconti
Drives: 05 STi
OH MY
Best install ever.
John
Visconti is offline   Reply With Quote
Old 07-13-2013, 09:44 AM   #145
JiB
JiB's Avatar
Drives: GT86
it looks exactly like what it is heheh, being a jeweller helped but its just measuring the screen display, 16.5mm x 48.8mm, using dividers to scribe the outline where you want it. then cut it out, file flat and smooth rough edges, the use heavy duty tape to stick it on the inside.
Use this link to get into your center console
http://www.ft86club.com/forums/showthread.php?t=13583
Old 07-13-2013, 09:50 AM   #146
charged86
charged86's Avatar
That is so bad ass
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-15-2013, 10:19 PM   #147
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Had a fuel leak last night after a few WOT runs. I had already tightened the worm drive hose clamp with a flathead screwdriver until it couldnt move, so I (over)tightened it even further with a ratchet and made the screw go into the worm drive. No leaks now but the clamp doesnt look safe. Probably going to go out over the weekend and buy a T clamp to replace it.
There's one reason that I can see for why peeps are getting leaks even though the clamp was fastened all the way - the hose that came with the kit has a much thinner side wall (not counting the outer sheath) with a larger inner diameter. See pic attached. This makes it harder for the new hose to get a good seal against the metal pipe. @Visconti, @Rich@ViscontiTuning, this could be an improvement for future revisions of the kit.
enouf is offline   Reply With Quote
Old 07-15-2013, 10:28 PM   #148
Sensisnow
Drives: 05 TSX & 13 BRZ
I had over tightened mine as well, which pinched the line and created a gap that allowed fuel to spray everywhere. I picked up a few new clamps from the auto parts store and haven't had an issue since then. I wish I had a picture of the original clamp, but I already pitched it. After I removed it, it was more of an oblong shape though, so it was obvious that it wasn't doing its job.
Here is the clamp I ended up using. http://www.autozone.com/autozone/acc...uestid=2341435
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 07-15-2013, 10:42 PM   #149
Yruyur
Yruyur's Avatar
I ended up putting a second clamp on to be sure.
Old 07-15-2013, 10:56 PM   #150
Sensisnow
I've been thinking about doing the same thing. I pop my hood and look at that fuel line before I even pull out of my garage anymore. I haven't seen any leaks in the past few days, but fuel leaks are no joke, so I'd rather be safe than sorry. I'm an insurance agent, so I know that insurance would cover damages if something went wrong, but I also know that the insurance company would go after Subaru first, so they would likely find the modification and then put the fault on the owner. It's one thing to remove mods when you go to the dealer, but if your car is a pile of ashes, there's nothing you can do.
2013 DGM BRZ
Old 07-16-2013, 06:27 AM   #151
JiB
JiB's Avatar
Drives: GT86
I went for a drive just then and smelt more fuel than normal. Both clamps were dripping fuel like 2 drips per sec. So u guus reckon the hoses are fine but the clamps are causing the issues? Or should I replace the hose aswell?
Old 07-16-2013, 09:15 AM   #152
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Every once and a while I get a whiff of e85 and I keep pulling over and checking but see no leaks. I wish there was a leak so it could stop messing with my head.
post_break is offline   Reply With Quote
Old 07-16-2013, 11:57 AM   #153
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
When I buy this, I will install the display in my glove compartment. Since this instrument is critical for flex fuel opps, I will also pull power and ground from the same source the ECU gets power and ground. Then if a short occurs, it also depowers the ECU causing engine shut down instead of "boom."
John
jdcorbitt3 is offline   Reply With Quote
Old 07-16-2013, 12:38 PM   #154
Yruyur
Yruyur's Avatar
Im just hoping it doesnt really go boom but just defaults to a safe number and would throw a cel. New feature?
campaign: ban jv, diy, e85, fuel leak, kit, laughing to the bank, oh lord jesus its a fire, visconti, viscontifried, viscontinued
Flex fuel testing Dynotronics1 Southwest 5 06-22-2013 03:27 PM
FA20CLUB Flex Fuel Kit Ready FA20Club.com Engine, Exhaust, Transmission 16 05-22-2013 11:04 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Cheap flex fuel? nix Engine, Exhaust, Transmission 1 05-11-2013 04:05 AM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
