#141 |
Off Topic
@switchlanez and several other people run them. The smallest that would fit is probably 16x7. They're very expensive. Mach V sells a 17x9 for $700 ea. They're on my list of wheels I want, but that is a lot of money.
#142 |
Drives: 86 GTS
#143 |
I'm bumping an older thread so I don't have to make a new one.
I'm looking at a set of these wheels 16x7 in size. If I buy these new I'm guessing I will need to switch over my TPMS sensors? Is that something a wheel shop can easily do while swapping in my new wheels? Also, does anyone know what type of lug nuts I would need? It's surprising I can't find many pictures of our cars with the 16 inch version of this wheel. The only place I can find pictures is off of Japanese websites. Does anyone on here have these wheels in 16x7???? |
#144 | |
Drives: 2015 BRZ
As for lugnuts you will need aftermarket tuner lugs. They are 60 degree taper conical shaped. |
| The Following User Says Thank You to Vital For This Useful Post: | funwheeldrive (09-11-2018) |
#145 | |
Drives: 2013 WRB BRZ
@funwheeldrive You only need aftermarket lug nuts if you want a different style/color
#146 | |
#147 | |
Drives: 2016 Oceanic, "base" model
Heres a thread of 16inch wheels. Specifically, post #485 has a pic of TWS. His first picture post is #214. There are more pics of 16" wheels as well. I have Enkei RPF1 in 16" Last edited by MrDinkleman; 09-13-2018 at 04:05 AM. |
#148 | |
#149 | |
Drives: C5, GT-86, '24 Colorado TrailBoss
Thanks I have been looking for more pics of the 16" setup Whats holding me back is I don't like the Offset is the same as stock. Meaning you will have $2500 wheels that would still need spacers to sit close to flush. If they came in 16x7 at a +30 offset even if it weighed 2lbs more that would be much better. My 20mm spacers weigh 2lbs so that's where I got the number. 16x7 +30 offset 12.5lbs would make them worth it Otherwise 16x7 +35 13.7lbs RPF1's more than half the price isn't a bad compromise and wouldn't look bad without spacers
#150 |
Drives: 2020 Toyota 86 GT 6M
![]() Mine came in today! Limited edition color gloss pearl gold in 18x8.5 |
#151 |
Drives: Black BRZ
#152 |
Will be bringing a wheel to a buddy's shop in a bit (forum member CrazyWookiee) to do a video review of the wheel on his youtube channel so he'll weigh everything and I'll link the vid onto here after
#153 | |
https://www.tws-forged.com/tws_t66-f.html has the weights for every size/bolt pattern/offset as well |
#154 |
| The Following User Says Thank You to saltywetman For This Useful Post: | CSG Mike (08-02-2021) |
| Wheels similar to Technic mesh wheels on bmw's | DYOLF26 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 04-26-2017 11:29 AM |
| FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) | kanundrum | Wheels and Tires | 19 | 10-11-2013 10:26 AM |
| Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! | Evasive Motorsports | Wheels and Tires | 4 | 07-29-2013 09:46 PM |
| 17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? | SteveH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-14-2013 11:26 PM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 11:08 PM |
