Old 01-13-2013, 02:43 PM   #141
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by 2forme View Post
Volumetric Efficiency. Basically the engines ability to breathe efficiently.
My bad, got lost on acronyms.
Old 01-13-2013, 02:52 PM   #142
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Well, also it goes pretty rich over 6000, check the AFR graph.
uspspro is offline   Reply With Quote
Old 01-13-2013, 02:58 PM   #143
2forme
better rich than boom. LOL
Old 01-13-2013, 03:17 PM   #144
sw20kosh
Drives: 2013 Black FR-S
He is building up 1 less psi than Perrin due to the elevation. 1 psi means a lot in terms of HP. For example the 10 psi pulley is 3 psi over the "stock" 7 psi pulley and makes 40 more HP. By this you can see how much 1 psi more would give him at least.
One advantage of turbo systems is the wastegate will compensate for altitude. Meaning if you set the wastegate for 7 psi it will always keep the boost at 7 psi regardless of altitude. The turbo will be spinning faster to make that boost though and you may have a tiny bit more lag.
If Perrin develops a wastegated system for this SC, the same can be achieved. The wastegate will vent the pressurized air when it reaches the set psi. Skatery, I would seriously look into this option!
Another thing is the timing is obviously being pulled in the upper rpms as skatery confirmed is due to the tune being conservative due to his fuel up there.
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
2forme (01-13-2013), Opposed (01-13-2013), Pete (01-13-2013)
Old 01-13-2013, 03:50 PM   #145
2forme
Absolutely. Toss on a smaller pulley and you can have low-mid range torque too..
Old 01-13-2013, 04:00 PM   #146
skatery1989
Drives: BRZ Limited
Smaller pulley is going to be on in two weeks. Still waiting to see on the wastegate
skatery1989 is offline   Reply With Quote
Old 01-13-2013, 04:01 PM   #147
2forme
What is your target PSI with the smaller pulley?
Old 01-13-2013, 04:09 PM   #148
skatery1989
Drives: BRZ Limited
Hoping for 9 I think Jeff saw 10 on his car. This is the smalls pulley I can go with without changing the belt. I will eventually try to reach the 15psi the supercharger can make but not right now.
The Following 2 Users Say Thank You to skatery1989 For This Useful Post:
2forme (01-13-2013), Sportsguy83 (01-13-2013)
Old 01-13-2013, 06:33 PM   #149
gmookher
For those of you who have never done FI at altitude, the math is simple, if @skatery1989 lives at 5000 feet, on a supercharger the loss will be about 5%HP on low side, even more as temps increase. I may be wrong here on the exact percentage, it may be 4% or 6% but lets just say there abouts per 1000
why? cause fuel is metered according to MAP, not altitude or boost
VE is never ideal % at altitude, volumetric efficiency is a ratio (or percentage) of what quantity of fuel and air actually enters the cylinder during induction to the actual capacity of the cylinder under static conditions, ie ideal sea level and ideal temps. motors rarely see ideal. 3% is ideal loss. its more in real life.
I think its closer Approx. .5 psi boost per 1000' of atmospheric pressure is lost due to elevation. Boost plus atmospheric pressure is called absolute pressure. 14.7 psi at sea level +10 psi boost = 24.7 absolute psi.
if his atmos pressure at 5000 feet is 12.2psi, his absolute will be 22.2psi
if he is loosing 2.5psi due to altitude at 5000 feet, his MAP is lower, unless he spins his SC faster he cant compensate to make more power; but he can end up with too much MAP at sea level if Perrin and Vortech arent careful in dialin in and system setup.
At higher altitudes, air is less dense, and thus boost is decreased.
the goal should not be to have him make the same HP at 5000 feet as sea level, physics will make you have a bad day if you play that game
He's gotta be putting down over 220-225whp at sea level, as my guess, conservatively on 91 oct
on 92 -93 at sea level I suspect 240whp
Yes, yes indeed, but its not my place to tell you this, no one would believe me anyways.. just lets wait for the dyno curve of THAT setup..at sea level, an its gonna knock your socks off,
-but wait theres more-
if the pulley gets you hot and bothered, the stuff I hear about thats being tested will surely make you shoot your load. This kit just keeps getting better.
and better
and better
makes me feel like I have donated my car to "science, and explorations of new frontiers for humankind"
http://www.wallaceracing.com/braking-hp.php
gmookher is offline   Reply With Quote
Old 01-13-2013, 07:04 PM   #150
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
SCCA T4 - FRS
Old 01-13-2013, 07:09 PM   #151
gmookher
'splain that please?
Old 01-13-2013, 07:12 PM   #152
2forme
Gem, theres nothing new there, but now you're talking the already expensive price of the kit and then the cost of another pulley, just to get the advertised power of the basic kit. Lol
Old 01-13-2013, 07:55 PM   #153
Sportsguy83
Drives: Limited BRZ
Yep! He is something!
Old 01-13-2013, 07:59 PM   #154
2forme
Well the cost factor doesn't apply to him, because he's getting it for like half price... which would make a good value in his case.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
OrbitalEllipses (01-13-2013), Sportsguy83 (01-13-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Vortech Supercharger Kits @Pure Automotive Performance Pure Automotive Forced Induction 25 01-16-2013 12:48 AM
Circuit Motorsports - SEMA 2012 Interview - Vortech Supercharger! Circuit Motorsports Forced Induction 6 11-06-2012 02:30 PM
