#141 | |
Drives: Some rust bucket
tires, suspension, driver skill, engine conditoin, etc, etc. you're not isolating the aero parts as the only variable that can affect those exit speeds. |
#142 |
LOL, sounds like you're from s2ki and saw my faux-type-S for sale thread and or pictures.
what was your handle on s2ki? i'm pretty sure i've seen you around in the cr thread. i rarely go to s2ki now since i don't own one. sold the car a while back and now im looking at either the FRS/BRZ as a new daily. gonna trade in the fit probably.
#143 | |
Drives: 2022 Halo White GR86
Will the S2K beat the FT86 on the track? Will the 40HP difference be too much of a disadvantage? Will the lower CG and weight distribution be an advantage? Beats me...I don't know but I'm excited to find out coming Spring. My second point was that CD is unfortunately an afterthought in the automotive industry as aesthetics are more important than engineering. Experimentals and exotics? We're already talking about apples and oranges and you show up with a coconut? I have a degree in aerospace engineering with emphasis on aerodynamics and computational fluid dynamics so I care about CD more than anyone here probably. As brought up before, FT86 is a lower budget car with different design goals from the S2000. It has competitive handling, speed, balance, and weight characteristics. I would say bringing drag into the discussion is pointless if one doesn't do the calculation of acceleration taking into account ALL the vehicle dynamics unless 6 months later someone does go race the two side by side for an actual bench test. Look at these numbers! They are all over the place. http://en.wikipedia.org/wiki/Automob...ag_coefficient Some people might see numbers, but I see well engineered cars like the Nissan GTR with a 0.26 CD. Sure it's relatively low, but not lower than a Honda Insight. The car's form factor and profile must be built around the interior mechanics because what is most important for an automobile is vehicle dynamics on the road rather than external forces and moments like an aircraft. The GTR doesn't need a CD of 0.15. Aerodynamics was sacrificed to build a better handling car, a car that can handle that large engine, and a better looking car.
#144 | ||
Handling junkie
s2ki handle is psychoazn Quote:
The tire variable, besides rolling resistance, is eliminated because lateral grip is not an issue, and the s2k doesn't have enough power to spin the tires at triple digit speeds. There's enough variance in rims without correlating data to effectively eliminate that. The section of track involves flooring it for 30+ seconds; everyone can do it, eliminating the driver variable. Power output of the given cars are more or less equalized. Great, you have a lot of theoretical knowledge. I have real world results. You're welcome to our data if you'd like to take a look. How about a zero-lift G37? I'm sure that was an afterthought. Aero matters. Last edited by Mike; 12-30-2011 at 04:35 AM. |
#145 | |
I could see that having the most aerodynamic vehicle may not be pleasing to most consumers' eyes, and that is why it's mostly an after thought. |
#146 |
Handling junkie
For someone with an aero background, I'm surprised you're not bring up frontal area. The number that truely matters is CdA (in which, again, the FT is superior), but is not commonly discussed.
Similarly, everyone is concerned with HP, no AUC. |
#147 | |||
![]() ![]() Quote:
#148 |
Handling junkie
The GT-R doesn't need a great CdA; the frontal area is tiny. It's smaller than a Prius (which we can assume is pretty aero optimized). Not sure what your point is. They don't need to focus on Cd alone, but aero is VERY well paid attention to.
I still maintain that the FT will likely have an aero advantage on the S2k. Do you know what the single biggest on-track performance modification you can make on a s2k is besides horsepower or tires? It's a wing. |
#149 | |
Drives: '06 AM V8V Coupe
Considering that drag can sap >100hp at typical track speeds I think it's pretty important to reduce drag. Things like wings increase drag to make handling better, but the body of the car itself need not be as big of a compromise, when it typically is due to styling/space concerns. A good example of this is perhaps the wheels of a car. Enclosing the wheels with bodywork (like the old Honda Insight) causes a pretty good reduction in drag, but no one does this. Similarly, a cover over the spokes of the wheel helps a bit but no one does this since it looks funny. I think if you had fan blade like spokes (or attachments) it's possible to even reduce the drag, and it would also provide brake cooling, but the point is when it comes to wheels people want what looks cool. |
#150 | |
#151 | |
Handling junkie
Decreasing drag on a production car is typically not within an enthusiast's budget, beyond taping off gaps. The key here, is that the BRZ/FRZ/FT's body will be fundamentally aerodynamically superior to the s2000, and aero is a MAJOR factor in performance with the s2000. The s2k, for whatever reason, generates a net downforce in the front, stock, and generates lift in the rear. If the FT doesn't do that, or does that even to a lesser degree, the car will already have a nice advantage. Even if the same wing is used on both the FT and S2k, if the FT's body glides through the air smoother, then it will still have less net drag. If it happens to generate less lift from the factory, then we won't need as much wing, which further exacerbates my speculated aero advantage. As for covering the wheels, race teams generally don't because 1. brakes need the cooling and 2. the tires/wheels usually stick out a bit. You can go to the other extreme and look at hypermiling competitions, where the wheels will always be covered, because brake cooling and maximizing grip via whatever means available are no longer issues. |
#152 | |
Handling junkie
- Front has downforce, while the rear lifts - A planted rear minimizes variance in toe from load change (a s2k quirk; helps the car rotate on entry, but it also is what causes that legendary "snap oversteer" magazines love to talk about) - A single exhaust opens up a massive gap in the rear where the OEM dual mufflers were - Transmission tunnel goes very far down the car's underbody. - Windshield is very upright, and the top makes a "bubble". The Spoon style top extends out the rake of the rear windows, making the car more aerodynamic, but at the cost of even MORE lift (which, again, is easily mitigated via wing). Based on Wikipedia numbers, the GT-R is 6.08 / .27 = 22.5185185 ft², while the Prius is 6.24 / .25 = 24.96ft². |
#153 | |
Drives: honda civic si 08
Please tell me how in the world you got 260 whp from bolt ons and tune with a k20, in the real world a k20 with bolt ons and tune will realistically be more around 200whp. To hit 260 you would need to bore the motor out to 2.2 liters, have some aggressive cams, bolt ons, and a tune. Honestly motors like the k20 are some of the worst for bolt ons cause you see virtually no gains for the money put in. The fr-s won't be any different. It's just a small 2 liter NA motor. |
#154 | |
Handling junkie
Not at all unrealistic considering I get that from an exhaust and tune on my s2k (albeit, 2.2). Ultimately, AUC of the 2.0 and 2.2 on the s2ks are more or less equal, regardless of peak hp. |
| Thinking of Buying either MR-2 Spyder or an AP1 S2000 | FT///R86 | Other Vehicles & General Automotive Discussions | 33 | 12-29-2011 12:53 AM |
| S2000 or MX-5 | balance | Other Vehicles & General Automotive Discussions | 10 | 11-01-2011 02:01 AM |
| S2000 from hell | CyberFormula | Other Vehicles & General Automotive Discussions | 13 | 07-09-2010 09:05 PM |
| The Real S2000 Successor | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 10 | 02-12-2010 01:21 AM |
| Honda S2000 Mugen Hard Top Headliner | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 3 | 01-15-2010 01:43 PM |
