#141 | |
Drives: '13 Firestorm Base AT
Did you get to keep the old one? they're good money to recycle, contain some heavy metal. Platinum I think.
#142 |
Drives: e92 M3
This is about the fifth FRS I've read about with engine failure due to a manufacturing defect. (Note that not all FRS/BRZ owners are members of this forum, so there is a high possibility that there are more.) It's getting a little ridiculous. Looks like I'm not buying an FRS anytime soon.
#143 |
Drives: 2013 Scion FRS "Raven"
Looks like what happens to the TC motors. They use the same rocker are design. What happens is the rocker pops off the lifter causing damage to the lifter. Then it takes out the head. The frs only have a valve spring rate of 30lbs so if your boost you start to lose pressure. The oil leak was from the rocker arm hitting and breaking the valve cover. Have heard of several cars in japan having this problem and They are looking into ways to solve the problem. For now they are upgrading spring rates to help this issue until a true fix is found
#144 | |
http://www.ft86club.com/forums/showthread.php?t=10766 100 failures, 36,000 units sold, so that's a failure rate of < 0.3% If that scares you away I wonder if you'll be driving anything at all... every car has catastrophic failures. Most of these are getting covered under warranty so even if you are that unlucky 1/333 you'll be out of a car for awhile until it gets fixed. And you're not accounting for usage, the repeat failures are almost all heavily tracked and several are modified. Sit on any car forum long enough and there's stuff that'll scare just about anyone away if you treat it like the sky is falling. |
#145 |
it's 'the forum effect'. makes people think they need a bunch of shit they have no real use for and that every problem anyone else has will be theirs in due time. gotta love it.
| The Following User Says Thank You to jamesm For This Useful Post: | strat61caster (10-07-2013) |
#146 | ||
#147 |
Oh, and if anyone is interested, here's a video of what it sounds like. Perhaps this could help somehow maybe down the road if they tell me what went wrong for diagnosis reasons?
OP, did yours even sound like this at all before it died, like did you have any time to hear it? [ame="https://www.youtube.com/watch?v=jHUuQ-b-25E"]Scion FR-S bad motor noises, lifter noise, no CEL - YouTube[/ame] Sorry for the poor video. Framerate glitches are from my dumb phone. |
| The Following User Says Thank You to zohare For This Useful Post: | 20valvewynn83 (10-07-2013) |
#148 |
Drives: 2013 FRS/01 Tacoma
#149 |
Wow great info! Thanks for this. I was curious what exactly was going wrong. Not sure obviously, but it's a good explanation. I am honestly expecting them to either rebuild the heads, or send it off as is since it's still sealed up and there's no holes in the block... -.- and put a new FA in. I'm very much hoping for the latter. I don't particularly like the idea of a dealer mechanic opening up an FA. Not to badmouth them, this isn't quite like Porsche, but still, I think they're very underqualified. Hell, if the dealer can't diagnose the issue and is calling out a Toyota engineer to look at it and decide what to do, why the hell should they be rebuilding it out of a book? Ya know? No offense to any Toyota techs here... just saying. I would prefer a sealed case/heads. But if it does need to be pulled apart... Ported heads? hm. Just thinking here.[/QUOTE]
FYI Toyota doesn't send out engineers they are field reps and they do that for any major problem that deals with warranty issues FRS or not. This engine is so easy to work on so don't flatter yourself by thinking Subaru tech's are some how more capable. As a tech I have already diagnosed electrical problems with no issues. Just saying majority of the technician are highly trained in the FRS and other cars. |
#150 | |
Thanks. That is actually confidence inspiring. Heard back today- Local dealer, (not really, I'm out of town for work ,but where the car sits-) got the criteria for diagnostic stuff they need to complete first before Toyota makes any sort of decision. So we'll see I guess. They said probably Wed I should know something. I by NO MEANS think a Subie tech as more capable. I think Toyota techs are just fine, but as a whole? In Nashville. I don't think they've had an FR-S in for this failure before. They made spark plug pull sound like a 10 minute ordeal... We'll see. Don't let my forum nonsense and frustration with paying $400 a month for a car I can't drive translate to "I don't think you're a tech worth anything." I actually would really like to work for toyota one day. It's a long term goal of mine. Lexus or Toyota, industrial design specifically.
| The Following User Says Thank You to zohare For This Useful Post: | 20valvewynn83 (10-08-2013) |
#151 | |
That is actually confidence inspiring. Heard back today- Local dealer, (not really, I'm out of town for work ,but where the car sits-) got the criteria for diagnostic stuff they need to complete first before Toyota makes any sort of decision. So we'll see I guess. They said probably Wed I should know something. I by NO MEANS think a Subie tech as more capable. I think Toyota techs are just fine, but as a whole? In Nashville. I don't think they've had an FR-S in for this failure before. They made spark plug pull sound like a 10 minute ordeal... We'll see. Don't let my forum nonsense and frustration with paying $400 a month for a car I can't drive translate to "I don't think you're a tech worth anything." I actually would really like to work for toyota one day. It's a long term goal of mine. Lexus or Toyota, industrial design specifically.[/QUOTE]Trust me dude I know how you feel. I had my trans replaced and that took about a month, I had the short block replaced, the fuel pump replaced, the steering wheel replaced, window seal replaced, somebody backed up into my door and it was in the shop for a month and on top of that o had a body kit bonded to the car and that took a month or more. This thing has been down for maybe 4+ months in the past year and a half. |
#152 |
Dude.... That sucks. Steering wheel? Yeah mine's been hit three times already, only one was bad and guy left a note. Luckily, the rental place my insurance used had a Camry haha. I had a lot of fun in that thing believe it or not. But that was a door fender and hood, so that took a while. Oh, and a wheel. Can't compete with 4 months though. Oh, and my spoiler is literally falling off, and the clear (if they even used any?!) is peeling. Used the dealer recommended body shop... won't be doing that again... |
| 2014 Subaru BRZ - Minor and Major Mechanical Changes | WingsofWar | BRZ First-Gen (2012+) — General Topics | 53 | 12-28-2012 11:43 AM |
| Gearbox: Cable Link or Mechanical Link? | Marrk | BRZ First-Gen (2012+) — General Topics | 42 | 07-02-2012 12:45 AM |
| Dragster + hillclimb predictably ends in epic failure. | old greg | Other Vehicles & General Automotive Discussions | 2 | 03-31-2012 11:48 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 01:25 PM |
| A pessimist's take on sales success / failure | Mess11 | Scion FR-S / Toyota 86 GT86 General Forum | 137 | 11-24-2011 02:10 PM |
