Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 12-02-2020, 01:47 PM   #141
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Yes, the FA24 is going to feel better all around, no doubt. The linearity of it will make it feel... not very fast in some way, as is the nature of linear powered sports cars (I actually like the way it feels). But since I like the way the current gen feels, the new gen will probably feel incredible in comparison.
Some additional points I noticed when I did my data plot some time back.
1. Power for 22 BRZ is equivalent with power for 17 BRZ at approximately 3200 and 4200 RPM respectively. In other words, acceleration in the 22 at 3200 RPM will feel equivalent to that of the 17 at 4200 RPM where it starts to take off. Obviously, we can all agree that this will be a much better daily driver.
2. Peak power that's achieved in the 17 at 7000 RPM is achieved by about 6000 RPM in the 22.
Dzmitry is offline   Reply With Quote
The Following 4 Users Say Thank You to Dzmitry For This Useful Post:
Blighty (12-03-2020), Ohio Enthusiast (12-02-2020), Tcoat (12-02-2020), ZDan (12-02-2020)
Old 12-03-2020, 05:12 AM   #142
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by ZDan View Post
FWIW here's my effort at plotting my '17's dyno results (178rwhp on Dynojet) vs. the dyno plot shown on the '22 BRZ dash scaled by the same rwhp/hp factor of 178/205 = 0.87:
Thank-you for plotting that out, great job!
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
ZDan (12-03-2020)
Old 12-03-2020, 05:15 AM   #143
Blighty
This was an interesting pov.
The Following 4 Users Say Thank You to Blighty For This Useful Post:
Dirty Harry (12-03-2020), Red-86 (12-03-2020), The Red One (12-04-2020), ZDan (12-03-2020)
Old 12-03-2020, 08:01 AM   #144
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, they should feel similar. Flat torque up to near peak hp is a good feeling. My 2.9 Cayman had a torque curve that had a broad peak centered on the midrange and fell off more noticeably with higher rpm though power still climbed. This felt *boring*, I wasn't even sure if I should continue revving past 6500ish. Don't have my dyno plot handy, but it looked similar in shape to this curve for the Cayman R:
Ah, found it, leaving Cayman R plot above so people know how boring that car's output characteristics are too. 2.9 Cayman dyno below...
What this means is that the '22 will pull harder from 45mph *in 4th gear* (3300rpm assuming same trans ratios but taller 4.1 diff) vs. the current model *in 3rd gear* (4200rpm). That's something! And of course you can still leave it in 3rd and accelerate faster still
2.9 Cayman dyno:
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Blighty (12-04-2020), Dzmitry (12-03-2020), Ohio Enthusiast (12-04-2020)
Old 12-04-2020, 10:16 AM   #145
alex87f
Meow
alex87f's Avatar
Drives: Focus ST mk4
You're confusing engine torque and wheel torque. The torque @3200rpm should indeed be similar to a first-gen car at around 4200rpm, but you'll still be in a gear with a lower reduction ratio, and have less wheel torque.
So yes, it has more torque, but no, MY22 4th gear acceleration =/= MY20 3rd gear acceleration
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Tcoat (12-04-2020)
Old 12-04-2020, 10:41 AM   #146
We don't even know the individual gear or final drive ratios for the 22 yet. Yes it can be assumed that they will be the same and can be compared but all the numbers could be very different once we have the actual ratios.
Old 12-04-2020, 12:43 PM   #147
chipmunk
Drives: _
Gosh, why did I watch this video!? I had never noticed the front license plate mount, incoherent fascia lines, etc. before! Now I can't unsee them! Duck wing was the only thing that bothered me before.
Hopefully they'll change a few things before mass production after looking at public response. Or maybe a tS version or 2026 facelift might solve them!
chipmunk is offline   Reply With Quote
The Following User Says Thank You to chipmunk For This Useful Post:
DarkSunrise (12-04-2020)
Old 12-04-2020, 01:25 PM   #148
Ultramaroon
not playing cards
Ultramaroon's Avatar
Meh. I figured they would ruin it. Now even more, when I look at my '13...
NoHaveMSG (12-04-2020), Tcoat (12-04-2020)
Old 12-04-2020, 02:09 PM   #149
ZDan
ZDan's Avatar
Drives: '23 BRZ
At 45mph, the '22 in 4th, even with a taller 4.1 final drive, will out-pull the current model in 3rd. But not for long as the earlier model is coming out of the torque dip...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Ohio Enthusiast (12-04-2020), Tcoat (12-04-2020)
Old 12-04-2020, 03:41 PM   #150
ermax
ermax's Avatar
No no they didn't.
I knew this was a waste of time.
The original static image on the dash in the 2017+ followed the same shape (including dip) of actual dynos from stock engines. Do you really find it that far of a stretch that they used an actual dyno chart as the base for the static image or do you think the whole chart just coincidentally follows the shape of real dyno charts of our engine? And going off that, do you really think it's a stretch they followed the same technique when creating the static image on the new car? The peak torque on the new static image is at least inline with the specs that Subaru has released.
Old 12-04-2020, 03:51 PM   #151
Did you read further or just assume?
What they did not do was take the mule and throw it on a dyno and go "close enough".
I have not once disputed that graphic as accurate. For a lab tested engine under ideal circumstances and atmosphere as per ISO testing standards.
I get to watch the pretty line follow the printed graph on my 2020. It does the same thing no matter what the weather conditions. That is not real world data since the car does NOT perform the same in 90 degree humid weather and 30 degree dry.
What I have tried to get across is that it is not representative of what is at the wheels. We have zero clue how much of that will put to the ground. Those two numbers mean nothing to me till I see how the car uses them.
Old 12-04-2020, 03:54 PM   #152
ermax
ermax's Avatar
It is a 10% drop for a fraction of a second when accelerating through it.
Maybe a fraction of a second in 1st but where it's really annoying is on the highway (~65mph) when you want to pass. In 6th there is no power, dropping to 5th puts you in the dip and dropping to 4th or 3rd turns it into a boy racer feeling pass. In 5th or 6th the dip last much longer than a fraction of a second.
Casual driving at low speeds in city traffic the low end torque is perfect. The dip doesn't bother me at all in those conditions. I spend 90% of my time on the interstate running between 65mph - 95mph so that is where it's annoying. Obviously none of this is an issue in racing conditions where you can keep it above the dip.
E85 cures it enough that it doesn't really bother me anymore.
The Following User Says Thank You to ermax For This Useful Post:
Blighty (12-05-2020)
Old 12-04-2020, 04:02 PM   #153
ermax
ermax's Avatar
Literally everyone knows the graph on the dash isn't live data. You do realize no one is this thread suggested otherwise right?
Old 12-04-2020, 04:27 PM   #154
You do realize that the whole thread was based on exactly that belief!
How to get that classic high-pitch 4cyl sound from brz? yEEt42069 Engine, Exhaust, Transmission 45 04-08-2020 11:51 AM
i just realized... 2016 turbo 4cyl CAMARO vs FRS/BRZ Shinchu FR-S / BRZ vs.... 98 09-28-2015 03:18 PM
COMPLETE OEM engine harness! Great for tuck Nizz300Ft86 Audio/Visual, Electronics, Infotainment, NAV 2 03-13-2014 12:23 PM
COMPLETE OEM engine harness! Great for tuck Nizz300Ft86 Engine, Exhaust, Bolt-Ons 0 11-25-2013 05:19 PM
MPG of a 600hp 4cyl. Engine chuttney1 Off-Topic Lounge [WARNING: NO POLITICS] 11 03-15-2012 09:06 PM
