#141 |
Ran a trigger test. No cam signal. Either sensor is bad or the wiring is wrong. One wire checks to ground, the other 2 have 5v. Pretty sure one should have 12v so I suspect wiring problem. Fixing this will likely since my idle/start issues
#142 |
So the Hydra Nemesis doesn't use the cam sensor. So I checked cam timing (this is a massive fucking pain in the ass. 100% check this before installing your engine) it seemed to me to be misaligned so I got a new timing kit. Trick Flow, double chain
| The Following 3 Users Say Thank You to Ashikabi For This Useful Post: |
#143 |
FYI it's "possible" to remove and replace the oil pump without removing the oil pan. But you have to get at this bolt and remove/replace it without dropping it in the oil pan. I used a standard 10mm wrench, a brake bleeder wrench (the more enclosed ones, the head was at an angle) a wire noose(prevent the bolt from being lost if it fell, a couple screwdrivers and picks.
Get it out halfway then get the noose around it, remove the bolt. Do your shit before the motor is in. This was awful. Use a file or grinder to cut little notches in the flange on the bolt.(the girlfriend cut the notches in the head, not the flange) Move the oil pickup O-ring from the pump onto the male end of the pickup. Use tension on your wire and a screwdriver to work the screw into it's hole. Use a screwdriver to hold the bolt up in place while you use another screw driver(in the notches you cut) to turn the bolt. Once you are halfway in you can switch to the wrenches if you like. Use the picks to disengage the noose and remove the wire This was a huge fucking pain and the risk of dropping the bolt is pretty high. Again I highly recommend checking your cam timing/upgrading your chain while you can remove the oil pan
| The Following User Says Thank You to Ashikabi For This Useful Post: | M1K3 (06-12-2019) |
#144 |
I drove it again. New chain apparently made a huge difference. I've still got the same throttle body problem though: idle is very high and there is pretty intense suction on the throttle plate. Idle AFR is about 17. Maybe there is so much suction because of how fast the motor is turning? But how can it turn that fast with no air? When you get on the throttle the pedal is SIGNIFICANTLY stiffer when the motor is running until you get it cracked open a little then it frees up. But only when the motor is running. Also, when you first get on the throttle the RPM dips significantly as if that initial throttle opening is actually choking the motor. After being opened, the throttle plate doesn't really want to close again. But only while the car is running. How can I fix this guys?
#145 |
Drives: 2015 frs
Is your throttle position sensor adjustable. Its possible if its sending out the wrong signal, and the ecu is dumping in more fuel than it needs at idle. I would check tps, map, and maf or whatever your using any other signals that send info to the ecm to control fuel.
#146 | |
#147 |
Drives: 2015 frs
This is just me thinking outloud. I had a Honda swap with a miss wired tps, and it revved out at start up with closed throttle. Yours isn't as extreme but mine was wired in backwards so closed was full throttle. If you have a way to plug into the nemesis to view data that would be best or you could ohm out the sen. manually to test them. Just an idea. Good luck
#148 | |
#149 |
Drives: 2015 frs
That sounds good. Did you verify the vacuum line going to the nemesis is unobstructed, and has no holes? Pull it off at the computer for a second to test for vacuum signal
#150 |
#151 |
Drives: 2015 frs
Have you taken it in for a tune yet? Not sure what the base tune is like when you receive the unit. You may want to contact customer service for advice as well. I could see the fuel maps causing you some issues if they are off.
#152 |
I'm tuning myself. Base map is likely robbed from an LS3 and modified so it may very well be way off. Customer service is pretty sketchy
#153 | |
I Love custom Turbo kits
Drives: Limited BRZ
You could try contacting the shop, and see if they can help remotely (not with tuning software but what did they do hardware wise to correct the idle issues). Lookup KAB customs in FL.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Zer0 (06-12-2019) |
#154 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Sportsguy83 (06-12-2019) |
