#141 |
Drives: 2017 BRZ (Sold), 2023 GR86
Photos from Ridge Motorsports Park 4/05
The Following 4 Users Say Thank You to mistople For This Useful Post: |
#142 |
Track day at RMP 4/19/19 - 2:07
I had another great day at Turn2's season opener event at the ridge on Friday!
The day ranged from damp to wet and back to a damp/drying track for the latter part of the day. Great for learning how to handle changing conditions. I noticed in particular how the car reacted as the rain actually started to affect the limits of the car. Typically I find myself going out on a wet track and it stays wet. In that case, its relatively easy to adapt and know the limits right away. Under changing conditions, I found that I had to be much more aware of how the car felt corner by corner. Useful experience. I wasn't able to go faster than a 2:07.xx given the conditions and what are probably slower tires than last year. Although I can tell I'm a net faster driver, the confidence in the car's grip was just much lower than the day I set my pb of 2:05. That said, lap times are just a lap time and I can feel the improvement as a driver, so I'm happy in any case. There were some amazing open wheel cars and a handful of GT3s and GTSs out there as well. Nothing like a couple million dollars worth of german engineering to make you feel inadequate ![]() Hope to see some out you out at RPM and PR in May! [ame]https://www.youtube.com/watch?v=kpQvWt35Dt4&[/ame] |
The Following User Says Thank You to mistople For This Useful Post: | pillbox (07-15-2019) |
#143 |
AiM Solo 2 DL + JDL Ultra Quiet Front Pipe
AiM Solo 2 DL
I picked up an AiM Solo 2 DL to start logging and analyzing data at the track. I'm super excited to pick my laps apart and compare to other 86s with similar setups. I'll be honest—the quality of the hardware isn't anything to write home about. The software that comes with it is of extremely poor quality. But I don't know of a better option that has the same adoption and quality at this price point. I'll get to try it out this Saturday. Will report back with my thoughts. ![]() ![]() JDL Ultra Quiet Front Pipe I also decided to finally complete my exhaust setup with a JDL Ultra Quiet Front Pipe. Should be a nice pairing with the JRSC! ![]() ![]() ![]() ![]() |
#144 |
Turns out the JDL UQFP doesn't fit the Perrin catback. Ugh.
I swore the donut gasket at the rear flange was the correct option, but it basically only sits up against the entrance to the midpipe without actually fitting inside. Back under the car I go to return it to stock. Anybody in the market for a UQFP? Will be listing shortly. Last edited by mistople; 05-24-2019 at 02:48 PM. |
#145 | |
Senior Misanthrope
#146 | |
In other news, I picked up a set of 5 lap old RE71Rs from @rice_classic last weekend. Should be a fun step up from the SX2s when the time comes! |
#147 |
Drives: Black BRZ
What is the timeline like for the JRSC install? Looking forward to the numbers you put down and also your driving impressions.
Many say the JRSC is a bit underwhelming and I suspect it's because it makes power higher up and the torque down low isn't as strong as a turbo or perhaps even the Edelbrock. |
#148 | |
I don't expect mind blowing power down low. That said, pairing it with the A350 probably gets better results than most. Since my car is optimized for track driving, I don't have a huge need for walls of power below 5k. |
#149 |
Drives: '13 Scion FR-S & '17 Toyota 86
The Following User Says Thank You to eastendraceshop For This Useful Post: | mistople (05-31-2019) |
#150 | |
Drives: Black BRZ
Sounds good. IIRC, you have CSG Spec Teins, correct? I'm wondering if you have a review posted for them anywhere? Really curious to hear your feedback with respect to how you perceived body roll, turn-in, change in direction, etc. after you put them on. Other things like build quality, daily comfort on full soft and responsiveness on stiffest setting would be really helpful. I'm curious about going with something like this as opposed to saving for a bit longer and going all out on a set of JRZs or something. |
#151 | |
Drives: Nevermorange FRS
SCCA T4 - FRS
#152 | |
![]() Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | mistople (06-01-2019) |
#153 | |
![]() I did end up starting the install got about halfway through today. The NA -> FI conversion for the JR oil cooler is a bit confusing given the lack of documentation on the process. That said, I deconstructed the front of the car, ripped out all the stock intake bits, mounted the supercharger, and mounted the intercooler once I could disassemble my existing oil cooler setup. Should wrap it up tomorrow! |
The Following User Says Thank You to mistople For This Useful Post: | jflogerzi (06-01-2019) |
#154 |
Something looks different here...
The Following 4 Users Say Thank You to mistople For This Useful Post: | NoHaveMSG (06-03-2019), Racecomp Engineering (06-11-2019), tehShirt (06-03-2019), weederr33 (06-03-2019) |
2017 BRZ Performance Package DD Build | mjanmohammad | Member's Car Journals | 230 | 11-01-2023 12:31 PM |
QueenBRZ's 17' BRZ performance package DD / track build | QueenBRZ | Member's Car Journals | 125 | 06-29-2021 01:34 PM |
Spicy.Ricecake's 2017 CWP BRZ PP Build | spicyricecake | Member's Car Journals | 115 | 12-15-2019 07:42 PM |
Ohlins Road & Track - settings (clicks) for street/track/ax | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-27-2016 09:36 PM |
MVP Track Time 2014 Road Atlanta Track Dates | Feffman | Southeast | 2 | 03-27-2014 06:51 AM |
