Old 05-21-2017, 09:32 AM   #141
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@DustinS absolutely right... What a BITCH it is to get the transmission bracing out!!!
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
CxG (05-22-2017), DustinS (06-16-2017), ILLSMOQ (05-21-2017), wooly35 (06-15-2017)
Old 06-14-2017, 10:51 AM   #142
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Any updates on your project? All this oil pan talk lately has got me rethinking my GTO pan...curious on how your sikky pan will work out.
ILLSMOQ is offline   Reply With Quote
Old 06-15-2017, 06:07 PM   #143
wooly35
Drives: 2014 Scion FR-S LS3
Originally Posted by Sportsguy83 View Post
Installed the Holley cables and they fit nicely with the headers.
did you have a problem with the driver side header flange hitting the motor mount with this kit? I bought the same headers and I had to modify my flange to clear Vorshlags motor mount.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
DustinS (06-20-2017)
Old 06-15-2017, 07:03 PM   #144
Sportsguy83
Drives: Limited BRZ
Nothing much new to report unfortunately, the shop has been very busy.
Old 06-15-2017, 07:05 PM   #145
Sportsguy83
Drives: Limited BRZ
One of the flanges can't remember which side, does hit the motor mount. Will need to address it at the time.
Edit: It does not hit the mount.
Old 06-24-2017, 09:57 PM   #146
Sportsguy83
Drives: Limited BRZ
Getting there...
The Following 6 Users Say Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (06-26-2017), DustinS (06-26-2017), gramicci101 (06-25-2017), gtpvette (06-25-2017), ILLSMOQ (06-25-2017), mrg666 (06-25-2017)
Old 06-25-2017, 09:28 AM   #147
gtpvette
Drives: 2015 FRS - FFR GTM
Any details,,issues?????
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Sportsguy83 (06-25-2017)
Old 06-25-2017, 10:38 PM   #148
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
See something sexy in the background lol
Sent from my Pixel XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following 2 Users Say Thank You to Rican_D For This Useful Post:
gkubed (07-07-2017), Sportsguy83 (06-26-2017)
Old 06-25-2017, 11:07 PM   #149
Sportsguy83
Drives: Limited BRZ
CX Racing mounts will need a small spacer for clearance with the steering rack, remote oil filter system will need to have the fittings moved/modified/welded in a new direction to clear the steering rack, possibly will loose the front sway bar.
Old 07-03-2017, 08:49 AM   #150
Sportsguy83
Drives: Limited BRZ
I saw and worked on the cat Saturday. I didn't take any meaningful pictures, but I needed to buy a low mount Corvette alternator bracket as the OEM one on the top was touching the ABS unit. Got it from LSsimple.net which were the only ones that made a lower bracket to use with Corvette accessories and Corvette alternator (Vette accesories run 3/4" offset in compared to any other LS motor accessories and the bolt pattern for the alternator is different than for any other LS motor).
Aditionally, installed Fullblown slim fans and shroud for more room up front. The OEM fans would have been able to be used but needed a bit of shaving on the fan mount. It seems I have plenty of room to run the AC and heater lines on the firewall.
Lastly, it seems the 1/4" spacer on the mount coupled with some minor notching on the oil pan will allow me to keep the sway bar.
The oil pan relocator fittings will need to be cut and welded with hard 90s to clear the subframe.
Draco_PR23 (07-08-2017), DustinS (07-03-2017), gtpvette (07-03-2017), ILLSMOQ (07-04-2017)
Old 07-03-2017, 09:39 AM   #151
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
You're so close. Can't wait to see it running!
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (07-03-2017)
Old 07-03-2017, 09:40 AM   #152
Sportsguy83
Drives: Limited BRZ
Thanks man, can't wait either!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Rican_D (07-03-2017)
Old 07-03-2017, 10:33 AM   #153
all4spl
I was starting to wonder what happened with yours and dustins updates as I haven't seen anything in quite awhile. Glad it is working out for you.
all4spl is offline   Reply With Quote
The Following 2 Users Say Thank You to all4spl For This Useful Post:
DustinS (07-03-2017), Sportsguy83 (07-03-2017)
Old 07-06-2017, 05:47 PM   #154
Sportsguy83
Drives: Limited BRZ
I'll be able to retain the sway bar and will have enough room with the 1/4" spacer and a little notch on the oil pan.
To be fair with CXRacing, I'm not using their oil pan, I'm using the Sikky oil pan and the part of the oil pan that is hitting the steering rack is part of the Sikky pan, the CX Racing pan does not have the angles to support the tranmission cover on the back so if I had used the CX Racing oil pan, most probably it wouldn't be hitting the steering rack.
@all4spl
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
all4spl (07-07-2017), DustinS (07-07-2017), FRSToyota86 (02-28-2018)
Sportsguy's LS2 Swapped BRZ Sportsguy83 Member's Car Journals 2969 08-20-2018 11:12 AM
FS: (Sold) Sportsguy ArmRest kvnchu Interior Parts (Incl. Lighting) 22 03-13-2014 02:40 PM
Sportsguy's AVO Turbo experience, the Good the Bad and the Ugly Sportsguy83 Forced Induction 155 08-05-2013 06:17 PM
Motegi 126 customs kioton32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-26-2013 12:34 AM
FS: NY - Sportsguy Handcrafted Armrest xxscaxx Interior Parts (Incl. Lighting) 43 05-04-2013 05:30 PM
