03-29-2017, 07:55 AM | #141 | |
However, in ST trim...that would be legal. |
The Following User Says Thank You to M0nk3y For This Useful Post: | C4RBON (03-30-2017) |
03-29-2017, 12:48 PM | #142 |
Custom User Title
No, it is specifically called out in the rules that you may reverse them but not remove them. Recline the seat if you want to see.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
The Following User Says Thank You to Locust For This Useful Post: | C4RBON (03-30-2017) |
04-06-2017, 09:34 PM | #143 |
Drives: '15 Subaru BRZ
Hey all. Picked up a BRZ over the winter. Found a set of Koni's and a front Strano bar. Plan to use 225/45 RE71. Any advice on tire pressures and shock settings? Thanks for any info!
04-07-2017, 10:15 PM | #144 |
Custom User Title
Anyone know what options are out there aside from OEM for brake rotors? Correct me if I'm wrong but as long as the rotors are OEM spec'd replacements they are okay (meaning no slotted/drilled and must be 1-piece) which means you could technically find ones that were a pound or two lighter if they existed?
04-10-2017, 02:43 PM | #145 | |
Drives: 2013 FR-S 10 Series
I'm on the 215 RE71R in an FRS and she seems to like 30 in the rear and 35-36 in the front, but I've only had 2 autox since switching to this car. I'm used to more camber gain in the front so your mileage may vary. |
04-10-2017, 06:32 PM | #146 |
Custom User Title
RE71R start at 30front/28rear and see what you like/need around that.
Curious if anyone has a good starting point for the BFG 1.5S yet? I only have the test-n-tune at Crow's before I have to compete on them for the first time so I'm not sure how much pyrometer data I'll be able to get. Not the ideal testing for a national event but with how late our season starts here in Washington it's the best I can do.
04-10-2017, 08:03 PM | #147 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
04-11-2017, 09:30 AM | #148 |
2013 FR-S Whiteout / SSC
I ran 29 lbs at each corner with a half turn up from full soft each corner at my first event this year and it felt pretty good (half tread remaining RE71R). Good enough on Sunday for 2nd of 9 in my first scca event of the year (this may be an anomoly - watching a video of my best run it's apparent I'm not particularly good yet, lots of close competetion behind me in DS, and pax was 24/85)
The guy who beat me was in a wrx with the BFG 1.5s. He said that the sidewalls are noticeably stiffer than the 1.0s - enough that he noticed it leaving his driveway after installation. I am looking forwad to our match tour at the end of the month to see what's what re tires before buying my next set. I have 1.0s on a miata and think the RE71Rs are much much better. Last edited by Open Loop; 04-11-2017 at 12:10 PM. |
04-11-2017, 09:55 AM | #149 | |
Drives: 2013 Asphalt Scion FR-S
04-11-2017, 05:19 PM | #150 | |
Custom User Title
I appreciate the rest of the responses too guys but I need pyrometer checked pressures not just butt tuning.
04-11-2017, 07:35 PM | #151 |
Drives: 15 BRZ
Whats the consensus on rear pads? I'm running Ferodos up front and stock pads in the rear. I'm happy with the Ferodos, but would like a little more rear bias.
Delta/CENLA Region SCCA - DS
04-11-2017, 08:11 PM | #152 |
Same pads front and rear is the default for this chassis.
04-11-2017, 08:28 PM | #153 |
Drives: 15 BRZ
Yeah, I figured as much. Didn't know if there was some unconventional approach out there that also works.
04-12-2017, 09:47 AM | #154 | |
The Following User Says Thank You to chucky12012 For This Useful Post: | AustinTX (04-12-2017) |
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
