Old 04-11-2013, 10:10 PM   #141
Yruyur
Yruyur's Avatar
You can order the projector only or order the full kit. Full kit is really the way to go.
Old 04-11-2013, 10:11 PM   #142
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by 86 FRS View Post
im noob with a retrofit thingy, so when u do a morimoto retrofit, can u still use the HID kit u use in a halogen projector or the retrofit has its own ballast, and replacing the bulb to D2S?
The mini H1s use a an H1 bulb, and the kit can be purchased with or without the ballast.
If you decide to use ballasts that you already have, you'll need to get new bulbs.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 04-12-2013, 09:07 PM   #143
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
After many days of rain, sometimes quite heavy, I am happy to say I have no leaks. Next I will take it to the car wash to be completely sure.
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
Old 04-12-2013, 09:17 PM   #144
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
oh ok thanks.. i saw on the site retro-quik is a bi-xenon projectors, correct? if so, is this the one with a hi/low beam function together?
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 04-12-2013, 09:25 PM   #145
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Correct and correct.
Parting out HERE
Old 04-12-2013, 09:33 PM   #146
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
oh ok. speedelement FRS in my local shop has the Bi-Xenon projectors hi/low beam, but its a D2S bulb. how is that compare to the mini h1 bulb? which is better?
Old 04-12-2013, 09:39 PM   #147
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
My newest retrofit
Gixxersixxerman is offline   Reply With Quote
Old 04-12-2013, 10:37 PM   #148
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Outstanding dual hid's
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-12-2013, 11:18 PM   #149
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Gixxersixxerman View Post
My newest retrofit
Very nice, info on projector in high beam location please!
Old 04-12-2013, 11:29 PM   #150
Gixxersixxerman
http://www.ft86club.com/forums/showthread.php?t=33559
It's morimoto matchbox projector..
Old 04-13-2013, 11:44 AM   #151
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Which is better depends more so on which projector was used than which bulb type it takes.
In other words, I can't say which is better without knowing what projector was used.
Parting out HERE
Old 04-13-2013, 04:02 PM   #152
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
wow I might have to get a set of those matchbox man that looks good
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-13-2013, 11:44 PM   #153
jonzhuxD
Drives: Ultramarine FR-S
That quad HID with the matchbox looks outstanding! Was there any cutting to do or did it fit right in?
jonzhuxD is offline   Reply With Quote
Old 04-14-2013, 04:16 AM   #154
Gixxersixxerman
There was quite a bit of cutting.. The socket on the projector is bigger then the hole on the housing, so I had to dremel that then dremel it flush .. Basically cut off the stock lightbulb mounting point of the stock housing
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 09:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 03:16 PM
