Old 04-20-2017, 05:27 PM   #1513
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by Vin View Post
I actually have a dyno planned in two weeks, will report on the result of the 100 STG2 tune and Gruppe-S header on EU BP 98 fuel.
I look forward to seeing that!
Tor is offline   Reply With Quote
Old 05-09-2017, 09:33 PM   #1514
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
I just loaded up Shiv's OFH Stage 2 93 octane tune after putting my invidia front pipe/q300 on (in addition to the OFH which I had before). Would anyone mind taking a look at the log? I didn't see anything that looked bad. LTFT was never really much beyond +/-5% but was more on the negative side. There's a few blips of knock correction but not anywhere near enough to cause IAM to drop below 1.
http://www.datazap.me/u/demasrv/5-9-...m?log=0&data=1
http://www.datazap.me/u/demasrv/5-9-...m?log=1&data=1
http://www.datazap.me/u/demasrv/5-9-...m?log=2&data=1
Only asking because I always just ran the OTS 93 octane tune before but wanted to try out the more aggressive OFH tune now that I'm running full exhaust.
Edit: Here's better (longer) log with a few pulls in 2nd and 3rd. Mostly interstate driving though.
http://www.datazap.me/u/demasrv/5-10...t?log=0&data=1
demasrv is offline   Reply With Quote
Old 05-13-2017, 01:05 AM   #1515
BRRRZZZ
http://www.datazap.me/u/brrrzzz/log-...3?log=0&data=1
calling on the experts....haha
seems like im getting a bit of knock...is this a concern? sometimes multiplier falls to around 0.88. also ltft seems high at idle? Could this be that my gas isnt good enough? im running chevron 94 and flashed to ots stage 1 tune. Is this tune safe to run on my car in general? thanks so much.
BRRRZZZ is offline   Reply With Quote
Old 05-27-2017, 08:46 PM   #1516
Its_Will
Drives: 2016-frs
So i am a noob at this and learning bits and pieces. If some one could take a look at my data log(S) i would appreciate. I was cruising around hitting the throttle here and there. I noticed the car feels and drives a bit different with each of the two seperate/diffirent tunes. I ran the stage 1 93 tune w/ 93 pump gas mixed with 10% ethanol, then the stage 1 91 tune w/ the same fuel. for the 93 tune it felt like a mission to hit the throttle. i had to press on the acceleration half way down to get a response. As for the 91 tune (w/93gas & E10) the pedal was throttle happy. i literlly tapped on it 20% of the way and got more acceleration and response. so this leads to my question: is there anything off from the 93tune as opposed to the 91tune even though they are running same fuel?
Stage 1 93 tune w/ 93 pump: http://datazap.me/u/itswill/frscruis...=0&data=1-2-10
Stage 1 91 tune w/ 93 pump: http://datazap.me/u/itswill/frsatcru...=1-2-10&solo=3
Last edited by Its_Will; 05-28-2017 at 11:20 PM. Reason: compared two different tunes, and added extra log
Its_Will is offline   Reply With Quote
Old 06-05-2017, 09:49 AM   #1517
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Phantom ESC v3 + Tomei header
just finished installed tomei uel and had datalogging
my mod is below
phantom esc v3
Tomei UEL
3rd Party OP
Berk FP
Q300
anway, i did some pulls on 3rd gear and looks little rich
i used 91 oct map
http://www.datazap.me/u/zc06kissther...a=1-2-5-7-8-10
here's some highway and some 4th gear pulls
http://www.datazap.me/u/zc06kissther...=1-5-7-8-10-12
last one is just driving around in highway as well as local
http://www.datazap.me/u/zc06kissther...og=0&data=1-12
i think i need some adjustment on tune.
thoughts?
Old 06-05-2017, 11:44 AM   #1518
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
my mod is below
phantom esc v3
Tomei UEL
3rd Party OP
Berk FP
Q300
i used 91 oct map
thoughts?
According to your MAF voltage your peak power should be around 270CHP. If I'm doing the right math haha.
I had no idea the Phantom ESC was capable of those gains up top. I always thought it was good for low end torque but being 70 hp over stock is impressive.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 06-05-2017, 01:17 PM   #1519
zc06_kisstherain
Drives: SWP BRZ
yeah but it lasts only few seconds though. and it needs time to recharge.
if i run E85, there could be more gain as well.
my AFR seems around 11.xx so little rich?
Old 06-05-2017, 02:23 PM   #1520
Detroiter
Detroiter's Avatar
I'm curious what would be possible with E85 now. This is kinda pushing me to thinking ESC for a while before I can afford a full turbo kit. How much was yours to get it fully up and running?
11.xx seems about right to me. I wouldn't want to push it into 12.xx under high load based off what I've read. Especially with it having some amount of boost pressure running through it. But I might be wrong.
Raven
Old 06-05-2017, 03:07 PM   #1521
zc06_kisstherain
Drives: SWP BRZ
Here's link you can check out for Phantom ESC.
http://www.ft86club.com/forums/showthread.php?t=39719
I thought it was joke and "is this ebay kit?" as soon as i read "electric" S/C
and another link for owner's thread
http://www.ft86club.com/forums/showthread.php?t=66862
kit is around $1900 - $2400 depends on options + Batteries and Procede module (instead of Throttle switch it controls by ECU)
obviously you need tune by OFT or ECUTEK
Advantage is very easy to install & uninstall
disadvantage is limited boost
another problem is long wait to get it. it took me 2 years to get it. (see thread)
I always thought below 12 AFR was kinda rich but i am not expert either.
all cars are different and i dont care as long as 11.xx AFR is fine for our vehicle.
Old 06-05-2017, 10:50 PM   #1522
zc06_kisstherain
Drives: SWP BRZ
my mod is below
phantom esc v3
Tomei UEL
3rd Party OP
Berk FP
Q300
i used 91 oct map
thoughts?
@steve99
you think ok? my afr is little rich i think though
Old 06-06-2017, 12:55 AM   #1523
steve99
@steve99
yeah looks rich wot mid/high rpm
Take 5% off the maf flow numbers over 3.4v (quick method)
Or redo your open loop maf scaling using the VGI tool.
closed loop looks ok
Old 06-06-2017, 07:18 AM   #1524
zc06_kisstherain
Drives: SWP BRZ
I have no idea how to do that. lol
i gotta take some lesson
Old 06-14-2017, 09:43 PM   #1525
nunonuna
nunonuna's Avatar
About few months ago I experienced weird thing happened.
I felt car jerk/bogging while at constant partial throttle(seems engine load drops all of sudden according to data log). NOT happening in idle(it idles perfectly fine), only in partial throttle while cruising or accelerating. It doesn't happen all the time but quite often. at least once or twice in 20 min driving. so I decided to log the data to see what is going on & this time it happened more than usual. It seems like engine load & maf voltage drops while afr spikes up(lean) at the same time. I cleaned maf couple months ago with maf cleaner and the symptom seems gone for few weeks but it happens again. No intake leak neither exhaust leak found. So I cleaned maf sensor about couple weeks ago again. Again, the symptom was gone for past couple weeks, but happening again. I first thought it was dirty maf sensor, but now Im thinking maybe my maf sensor is broken. Can someone take a look at the data and help me with advise?? Thanks in advance~
Im currently running OFT stage 2 UEL E85.
http://www.datazap.me/u/fa20frs/log-...zoom=1621-1852
nunonuna is offline   Reply With Quote
Old 06-14-2017, 11:42 PM   #1526
steve99
I felt car jerk/bogging while at constant partial throttle(seems engine load drops all of sudden according to data log). NOT happening in idle(it idles perfectly fine), only in partial throttle while cruising or accelerating. It doesn't happen all the time but quite often. at least once or twice in 20 min driving. so I decided to log the data to see what is going on & this time it happened more than usual. It seems like engine load & maf voltage drops while afr spikes up at the same time. I cleaned maf couple months ago with maf cleaner and the symptom seems gone for few weeks but it happens again. No intake leak neither exhaust leak found. So I cleaned maf sensor about couple weeks ago again. Again, the symptom was gone for past couple weeks, but happening again. I first thought it was dirty maf sensor, but now Im thinking maybe my maf sensor is broken. Can someone take a look at the data and help me with advise?? Thanks in advance~
Yes looks a little strange.
Try flashing a tune with the REAR o2 sensor fueling compensations zeroed out
See my post in thread here, ive seen a couple of guys with bad or damaged rear o2 sensor causing rich cruose fueling, wot and hard acceleration ok but on highway or cruising afr will go rich.
If zeroing out rear o2 compensations works then it generally the rear o2 thats bad
http://www.ft86club.com/forums/showthread.php?p=2908278
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
