Old 08-31-2013, 11:17 AM   #15233
EZWood
BAMF
EZWood's Avatar
Yes. I guess they do an open test and tune fairly often on Fridays.
Sent from...somewhere?
How well is the track maintained?
Old 08-31-2013, 11:29 AM   #15234
Jar
Jar's Avatar
Drives: 2014 SWP BRZ Limited
Originally Posted by BRZSTIAZ View Post
I was getting on the 202 from Gilbert Rd. today with a WRX STi in front of me and when there was a clearing in traffic we both stepped on it and too my suprise I kept up. I am stock except for a catback exhaust. We went from about 50 to 80 mph. I was pulling in third and fourth gear. I thought that was pretty sweet. Btw a yellow older mazda tried to keep up with us but couldnt lol.
Hmmmm, I wouldn't leave an 86 in the dust or anything, but I would absolutely get away! Maybe he was driving in good-boy (i-drive) mode? But even then.
Jar is offline   Reply With Quote
Old 08-31-2013, 12:06 PM   #15235
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
I can't either, lol! I think I'm waking up early tomorrow and putting these bad boys on. No more drift mode when I hit a mid-corner bump and bottom out the suspension.
Sent from my GS4.
Did that jackass send the correct insert adapters for your shocks?
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
Old 08-31-2013, 12:10 PM   #15236
Evil86
Evil86's Avatar
Prosolo live at http://www.ustream.tv/channel/sccasolo
My car should be up soon.
Old 08-31-2013, 12:21 PM   #15237
Evil86
Evil86's Avatar
It is in the current run group. The driver is Elliott Speidell.
Old 08-31-2013, 12:24 PM   #15238
4azcats
4azcats's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Originally Posted by SpyderMS View Post
I had this same issue. Was going to wait til I got my oil changed to have them look at it but decided to take a crack at it myself. Just unscrewed both screws, and then screwed them back in. So far so good but if it gets loose again I'll have them take a look at it. Wasn't aware this was a common problem or that there is a revised base to fix it.
There have been several threads on the rear view mirror issues on this and other forums. Service advisor told me that since they revised the base and screws they haven't been having any problems-he was surprised that I was having issues again until they discovered that they hadn't used the correct screws.
4azcats is offline   Reply With Quote
Old 08-31-2013, 12:27 PM   #15239
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
I actually have to worry about two jackasses, I bought them used from Simmons.
We run the same shock design, so it should be okay. I slept in today so I'll probably install them tomorrow.
Sent from my GS4.
Old 08-31-2013, 12:41 PM   #15240
dsrttigr
"GOD ARM"
dsrttigr's Avatar
Drives: 2013 Toyota GT-86R E85 Tuned
Guessing nobody is coming over to help me with lowering springs? My garage is air conditioned B-).
dsrttigr is offline   Reply With Quote
Old 08-31-2013, 12:44 PM   #15241
EZWood
BAMF
EZWood's Avatar
I'd come give you a hand, but I work six days a week
Old 08-31-2013, 12:44 PM   #15242
Evil86
Evil86's Avatar
Sent from my GS4.
Want help? I have installed and pulled them quite a few times, and I have become adept at the task.
Old 08-31-2013, 12:51 PM   #15243
EZWood
BAMF
EZWood's Avatar
Originally Posted by 40flash View Post
I was playing in the rain tonight in a cool section at the south end of my subdivision where the streets have been paved for a while but no houses yet. I hit both buttons to supposedly turn off all assistance. It wouldn't let me get sideways. The yellow light on the tach would come on and cut out the engine every time I tried to slide it. Did I have it set wrong or is there a problem with the car? Considering popping the traction control fuses out and seeing what happens. Didn't buy this thing to have the nannies run my life. Any thoughts?
Its the button to the rear of the shifter on the driver side of the console. Hold it down till two hollow/orangeish lights are present on the dash. Have fun and be safe.
Old 08-31-2013, 12:53 PM   #15244
Evil86
Evil86's Avatar
Elliott redlighted the right side on his first run, and he coned on the right on his second run, no worries though because he still has four runs left on each side so he will get a fast clean run on the right.
He will be doing adjustments to the suspension before the afternoon runs to get more sticktion and balance.
Prosolo takes the best two out of the driver's six runs over three sets of competions on Sat. and Sun., and combines them.
Old 08-31-2013, 01:20 PM   #15245
jeffsides
AZ FRS 86
jeffsides's Avatar
Working
@AZFRS86
Old 08-31-2013, 01:31 PM   #15246
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
I'm under my car at the moment, no one sedona bound this weekend?
448hpsti is offline   Reply With Quote
