Old 12-13-2016, 07:53 AM   #15009
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
added lightness.
Old 12-14-2016, 11:12 AM   #15010
Jackola
Drives: BRZ -16
Originally Posted by chermo12 View Post
4th winter for my BRZ...
Just a question. I'm on my first winter with my BRZ, and the paint is getting frickin peppered by the gravel they use on the roads. How is the paint on your car after four winters?
Jackola is offline   Reply With Quote
Old 12-14-2016, 11:52 AM   #15011
justinco
justinco's Avatar
Drives: 2022 GR86
I just had more PPF (clear-bra) applied to my car yesterday because of this. The 2017 BRZ paint seems to be a bit fragile and thin, I had small rock chips in front of the rear wheels in the usual spots.
I had PPF added behind the front and rear wheels as well as in front of the rear wheels. Hopefully this helps keep the car free from little scratches.
justinco is offline   Reply With Quote
Old 12-14-2016, 01:48 PM   #15012
johan
Drives: '14 981CS, '99 NB1
Nice! You did like Figo. How hard was it & how much came out roughly?
Originally Posted by Guru Woodman View Post
Yeah, I have that bookmarked on my pc. I'm just gutless, so I'm kinda chicken to do it... but maybe it's winter season, so I might try it out.
Originally Posted by olsonpg View Post
I'm actually a bit nervous to try this one too. Might be a fun winter project tho. Not an expensive replacement if you screw up either.
Well, if you do it before me, make sure to tag me with tips.
Haha ok. I might do it just for shits and giggles because i'm bored to tears.
I left some tips on the second page of that thread. Most time consuming thing is just working out the spacing for getting the correct fitment of the vent to the mounting shroud. Cutting the back part is a bit of a PITA too, but patience pays off.
johan is offline   Reply With Quote
Old 12-14-2016, 02:49 PM   #15013
Joe1206
Drives: 2015 Subaru BRZ Limited
What kind of HID's do you have chermo12?
Joe1206 is offline   Reply With Quote
Old 12-14-2016, 03:13 PM   #15014
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Thanks man!
Old 12-14-2016, 03:51 PM   #15015
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Haha yeah, it looks like a long tedious lesson on "just a litttttttle bit more filing" x100 times.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
Old 12-14-2016, 06:30 PM   #15016
FlipperBizkut
Drives: 2017 BRZ Limited
Bought her last week. It rained for the past couple of days, so I got out in the sub-50 degree weather and washed her.
FlipperBizkut is offline   Reply With Quote
Old 12-14-2016, 06:39 PM   #15017
chermo12
chermo12's Avatar
Drives: 2013 SSM BRZ
Paint is still flawless. I got paint protection film installed when I brought the car new. I felt it was a good investment for me. (Learned my lesson from my previous car)
OEM. The pic just makes it look more brighter/bluish.
________________________________
instagram - @FL4TBXR
chermo12 is offline   Reply With Quote
Old 12-14-2016, 07:00 PM   #15018
johan
I did zero filing. Hot utility knife is the trick. Cuts right through the plastic. Blow torch -> knife -> plastic. Repeat as needed. Allows for precision.
Also, once you make a big cut to remove a chunk of plastic, you can make successive little cuts along the same plane without re-heating the knife.
Old 12-16-2016, 07:52 PM   #15019
calidus
Drives: 2013 SWP BRZ Premium
I am on my third winter in my BRZ, my front bumber has taken a beating in Ohio, I has got a dozen paint chips that have used touch up paint on. Think more do the all the construction near me than the actually winters. The rest of the car's paint is in good shape.
calidus is offline   Reply With Quote
Old 12-17-2016, 03:16 PM   #15020
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Originally Posted by robotleader View Post
scraped the bottom of the front lip. its not even lowered!
Easiest thing in the world to do. Head-in parking against a concrete stop is the worst. I now stop two feet out (you'll never stick out in the back, our car is so tiny) and save up my scrapes for a big touchup job instead of doing them one by one.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 12-17-2016, 03:24 PM   #15021
pfaffendorn
Originally Posted by Bluesman62 View Post
Customizing these cars can be addicting! Just in the short time I've had mine I have changed the tail lights, added a third brake light flasher, added the Always On module for the DRLs, swapped out some of the interior trim pieces for silver ones, added the OEM arm rest, new tires and rims and lastly that gauge hood. Oh yea, and installed a sharkfin antenna. Where will it end!!
I like to say my changes are minimal, not even noticeable. But there are only two things on your list I have not done, and there are plenty more! This car is too easy to work on, that's the trouble!
Old 12-18-2016, 02:14 PM   #15022
cjny
Drives: 2016 BRZ
The temperature finally went above freezing so I gave it a quick wash today in my driveway. The hose was not usable but few buckets of rinse water water left better results than if I had driven to the car wash and back. Neighbors probably think I'm nuts.
cjny is offline   Reply With Quote
