Old 03-19-2017, 12:29 AM   #1471
JW843
JW843's Avatar
Drives: 2013 BRZ Limited
Diagnosis ---- you don't have a problem.
STFT is supposed to vary widly in closed loop, and will be zero in open loop.
The LTFT of =/- 5% or less is good.
commanded afr and measured afr are close, maybe 3% rich top end but fine
IAM=1
no knock flkc or fbkc
all good
Well that's definitely reassuring news. Even having spikes in the +/-10-20% range is acceptable? I just don't remember having these patterns when I first tuned it a while back. Thanks for your help.
Sent from my SM-G925V using Tapatalk
JW843 is offline   Reply With Quote
Old 03-19-2017, 12:46 AM   #1472
steve99
yeah stft will vary a lot especially on large throttle changes this is normal
Old 03-19-2017, 11:29 AM   #1473
JW843
JW843's Avatar
One last question for now, i went through and tightened a few things, cleaned my O2 sensors and tightened them, and put my GrimmSpeed CAI back on. I've been getting more consistent numbers but my LTFT is pretty high now, consistently when i'm on very little throttle and just cruising. Is this more indicative of a vacuum leak or an exhaust leak? I did a battery reset and have driven at least 50 miles to the point it's stabilized.
http://www.datazap.me/u/jwiggins864/...7?log=0&data=9
Old 03-25-2017, 06:14 PM   #1474
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
Long time lurker, first time datalog uploader ....
I just installed OFH3. I'm running 93. This is my first log. I did a pull in 3rd and a pull in 4th from about 2K to about 6K.
How's my OFH install, and does everything look safe?
Thanks much to those of you who take the time and trouble to help others. @steve99 or @Wayno or others with experience, could you please chime in? Thanks, guys!
http://datazap.me/u/trvth/pulls-3rd-...2?log=0&data=1
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
trvth is offline   Reply With Quote
Old 03-30-2017, 09:06 PM   #1475
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
i am still learning, please help
please take a look at the logs, its a 2016 BRZ, OFT is not reading MAF voltage so i am looking at MAF, using wayno's default stage 1, is this log good? like if it is not broke dont fix it? or do i have clean things up>? the gap in AFR at 3000 or so rpm is when i floor the throttle so i am guessing thats the transition
http://datazap.me/u/neilvosko/log-14...0&zoom=311-371
neilvosko is offline   Reply With Quote
Old 03-30-2017, 09:08 PM   #1476
neilvosko
neilvosko's Avatar
lean 2500 to 3500 rpm or is this okay?
http://datazap.me/u/neilvosko/log-14...0&zoom=925-981
Old 03-30-2017, 09:12 PM   #1477
neilvosko
neilvosko's Avatar
third pull for consistency, what do you think?
its like at 50 to 60 MAF, reason i ask is i am still learning but dont want to change things for the sake of change. @Wayno's default v122 maf scaling
http://datazap.me/u/neilvosko/log-14...zoom=1336-1401
Old 03-31-2017, 08:26 AM   #1478
neilvosko
neilvosko's Avatar
looks like your are running a bit rich, consistently, have you tried a lean map ?
ie stage 1 or waynos lean map?
Old 03-31-2017, 09:28 AM   #1479
steve99
looks fine
its only about 2% off commanded afr no real need to change
you will get some deviation in AFR/commanded with large changes in throttle
Old 03-31-2017, 09:31 AM   #1480
steve99
as the other guy said looks on the rich side , safe but costs a little power. Knock all good IAM 1 no FLKC
you rearly need to do a full throttle run in second or third, ie 100% throttle from 2000 to redline.
In your logs the throttle varies a lot during the higher rpm runs
Old 04-03-2017, 11:26 AM   #1481
trvth
trvth's Avatar
Thanks for taking a look. Is it any "safer" to run a little rich, versus trying to lean it out a little for max power?
Here's a fresh log with a couple of hard pulls 2K -> 6K in 2nd and in 3rd.
http://datazap.me/u/trvth/wot-pulls-2nd-3rd
You guys really do a service for the community. I review these logs myself, but I just don't yet have enough experience to be confident in my conclusions.
Old 04-03-2017, 12:35 PM   #1482
Rezi
Drives: GT86
Fyi, OFT reads about 0.2 higher.
Rezi is offline   Reply With Quote
Old 04-03-2017, 07:32 PM   #1483
steve99
looks fine is about 3% or so rich at mid/high rpm,
if your rearly kean you coudl reduce the flow values in the maf scale above 3.4v by say 2.5%. Dont change the volts numbers just the flow numbers.
Old 04-03-2017, 07:46 PM   #1484
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
How do you know this? OFT reads what the factory computer reads from the O2 sensor. Unless the O2 calibration is off, there should be no reason that the OFT would read any leaner than what the O2 is reading.
Intent > Content
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
