Off-Topic Lounge [WARNING: NO POLITICS] For all off-topic discussion topics. |
View Poll Results: Which jab have you had? | |||
Pfizer | 53 | 51.96% | |
Moderna | 27 | 26.47% | |
Johnson & Johnson | 6 | 5.88% | |
AstraZeneca | 4 | 3.92% | |
Novavax | 0 | 0% | |
Sputnik | 1 | 0.98% | |
Convidecia | 0 | 0% | |
Homebrew with a big dose of something special | 11 | 10.78% | |
Voters: 102. You may not vote on this poll |
04-08-2021, 10:44 PM | #1471 | ||
Sent from my SM-G975U using Tapatalk |
04-08-2021, 10:50 PM | #1472 | |
helmholtz resonator
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | p1l0t (04-08-2021) |
04-08-2021, 11:02 PM | #1473 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
Ongoing studies are monitoring immune responses beyond 6 months as well as determining the effect of a booster dose to extend the duration and breadth of activity against emerging viral variants. What does it say? It says "ongoing studies are monitoring immune responses beyond 6 months [emphasis added] ... [and attempting to] determin[e] the effect of booster dose...against emerging viral variants." It says nothing about recommending a booster, nor does it say anything abut the timing, if any, of the booster dose. The booster every six months is something you are reading into the paper that is not there. Slow down a little and use a 2lb instead of a 2oz trigger. It just does not say what you say it said. Full Stop. Edit: If you don't want to get vaccinated, no one on this board is going force you. But, in my considered opinion, it would be best for you (and those with whom you come into contact) if you made that decision on the basis of what the research actually says. The efficacy of a vaccine against those emerging variants is likely to be very important because vaccine hesitancy is still around 25%. If a quarter of the adult population refuses to be vaccinated the virus will have a good sized population in which it can mutate into more virulent forms. Thus it is likely that to be protected against a mutating pathogen we will all need booster doses at some time. So, in effect, your (and the rest of the 25%) concern and subsequent refusal to be vaccinated becomes a self fulfilling prophecy.
Slow is smooth, and smooth is fast
04-08-2021, 11:08 PM | #1474 | |
04-08-2021, 11:20 PM | #1475 |
Because compromise ®
Drives: Red Herring
Ad hominem (Latin for 'to the person'), short for argumentum ad hominem, refers to several types of arguments, some but not all of which are fallacious. Typically this term refers to a rhetorical strategy where the speaker attacks the character, motive, or some other attribute of the person making an argument rather than attacking the substance of the argument itself. This avoids genuine debate by creating a diversion to some irrelevant but often highly charged issue. The most common form of this fallacy is "A makes a claim x, B asserts that A holds a property that is unwelcome, and hence B concludes that argument x is wrong".
Wiki
04-08-2021, 11:43 PM | #1476 | ||
Proud of BOXER
Drives: Subaru Boxer
Yep, scheduled for the 27th.
04-09-2021, 09:24 AM | #1477 |
The Dictater
Drives: '13 Red Scion FRS
04-09-2021, 09:48 AM | #1478 | |
The Dictater
At this point, I think it's a matter of visibility and acceptance that the inherent risk is realizable regardless of what decisions one makes. If you don't accept that the current situation imposes a risk on you or those around you for some reason (I am different than the general population because...), then it seems silly to intentionally increase your personal risk by any amount. If you instead recognize the risky situation you are already in, then the intentionally added risk to yourself is seen as an opportunity cost to reduce the overall risk level. The concept that others level of risk depends on an individual's decision brings another bit of complexity to the matter. Is it an individual's responsibility to manage risk for others? Should an individual take on some level of risk to reduce the overall risk level to society? That last bit brings up an interesting theory that any society involves individuals accepting some amount of personal risk in order reduce the risk on the whole, thus reducing overall risk to all individuals... |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
04-09-2021, 10:17 AM | #1479 | |
Persona Non Grata
I'm not ignoring that part. The key in that sentence is what? "... determining the impact..." What does that mean? It means this particular team is looking into the impact of boosters both on extending the efficacy of the vaccine over time, and on new variants. What does it NOT do? Make a concrete recommendation or argument in favor of a booster. Now, the reality is a booster will probably be necessary - if for no other reason than that vaccine rejecters such as yourself are going to prolong the pandemic by providing the virus with unvaccinated hosts in which it will be able to mutate into variants that are able to bypass the protections the current vaccines provide. As I said before, yours is a self fulfilling prophecy. By using the potential need of a booster dose as an excuse to not get vaccinated, you and other rejecters are making it more likely that booster doses will be needed. So, in reality, if I have to get a booster it could be your fault.
The Following 4 Users Say Thank You to Capt Spaulding For This Useful Post: |
04-09-2021, 10:24 AM | #1480 |
Exactly all about risk vs reward.
https://www.abc.net.au/news/2021-04-...lout/100058440 Sent from my SM-G975U using Tapatalk |
04-09-2021, 11:08 AM | #1481 |
Sarcastic SOB
I am a very pro-vaccination individual and I have probably prosthetized here regards to this on more than one occasion now. Unfortunately I might also tend to repeat myself.
I just want to point out to everyone (unless advised otherwise by their physician), if you are opposed to being vaccinated, YOU are the problem right now.
The Following 3 Users Say Thank You to wbradley For This Useful Post: |
04-09-2021, 11:42 AM | #1482 |
For what it is worth, I work in transportation and finally secured a vaccination appointment. In a matter of 24 hours I was able to get the Johnson & Johnson one shot dose. Process was streamlined, fast, and easy. (Thanks Pierce College)
FYI the shot definitely registers on the pain/soreness scale. I am glad I chose my non-dominant arm. It's now 24 hours later and I admit I am feeling Soreness at injection site Body soreness Headache Slightly Nauseous So it must be working? My 5G is better than ever! /jk |
The Following 4 Users Say Thank You to Spankopotomous For This Useful Post: |
04-09-2021, 11:48 AM | #1483 | |
Persona Non Grata
I find myself skeptical of the anti-vaccine arguments you make. They seem illogical and flimsy and virtually every explanation you offer muddies the water further. At some point, I'd appreciate it if you'd do some soul searching and confront the real reasons for your opposition. If you'd care to share it, we could perhaps, have a productive dialog.
The Following User Says Thank You to Capt Spaulding For This Useful Post: | Spuds (04-09-2021) |
04-09-2021, 01:29 PM | #1484 | |
My sister is fully vaccinated, my parents are getting their first Moderna doses today, and my brother is getting a dose of one of them today.
I'm the odd man out since I'm not super high-risk but also not an essential worker.
Instagram: @spike.brz
Tags |
eagle5 got sandy vag, tread harder daddy, tylerlieberman is a cuck |
Similar Threads | ||||
Political Threads? | norcalpb | Site Announcements / Questions / Issues | 18 | 09-21-2016 04:17 PM |
(CLOSED)WTB: 57XTREME 18X9.5 +40 5x100 (MATTE GRAPHITE)(CLOSED) | Ry.ruzn | Want-To-Buy Requests | 2 | 04-17-2016 11:03 PM |
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs | Sportsguy83 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 02-25-2014 10:46 AM |
Not trying to be political. Just offering my condolences. | NorseLegend | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 04-16-2013 01:20 AM |
FRS goes political - Or not. | MindtheGap | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 09-14-2012 03:15 PM |
