Old 05-04-2015, 03:14 PM   #1457
Astroboy
Astroboy's Avatar
Drives: None
Has anybody been guilty of punching the throttle before the car reached operating temps?
Astroboy is offline   Reply With Quote
Old 05-14-2015, 05:17 PM   #1458
Astroboy
Astroboy's Avatar
Drives: None
AVO Turbo Kit Owners Topic
Should I consider investing in an oil cooler for this kit if I never go past 104c?
Old 05-15-2015, 06:21 PM   #1459
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Yeah. On some outings more then I would like to admit.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 05-15-2015, 06:23 PM   #1460
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Originally Posted by JustBoostin View Post
I just used the stock washer from that spot, and added the crush washer, and it worked beautifully!
Also, does anyone have the avo street breather tank AND a Mishimoto oil cooler? The part that replaces the oil cap won't thread on because it's hitting the sandwich plate. Thoughts on a remedy?
Could you take a picture of that?
Old 05-15-2015, 08:41 PM   #1461
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
So...
...a tiny leak developed.
(YES, I used the STI gaskets)
(YES, I used permitex "copper" exhaust sealant)
(YES, all of the bolts are properly torqued town and were re-torqued after 100 or so heat cycles)
So my question to the community is should I worry about this? I'm at 8 psi right now...
Old 05-15-2015, 08:58 PM   #1462
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by @Art_Mighty View Post
So...
Just get it fixed. I didn't use any sealant for my headers
Old 05-15-2015, 09:02 PM   #1463
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
but fixed means taking the whole kit off the car and doing what exactly:
1) Getting a new header from Paul?
2) Taking the existing header to a shop and having them ground flat?
3) ????
Old 05-15-2015, 09:51 PM   #1464
protpibe
protpibe's Avatar
Paul won't give you a new header, it will come down to "installation issues". If you have it planed down you may run into fit issues with your overpipe. Your best bet is to just live with the tiny bit of leakage.
Old 05-15-2015, 09:53 PM   #1465
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
3) ????
It was mentioned earlier in the thread that grinding it flat is not the way to go based on how the header mounts to the engine.
It was either Bob or AVO that posted it.
Old 05-15-2015, 10:31 PM   #1466
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
There were no "installation issues..."
...the straight edge is a custom ground unit even to within .0001" of an inch. We can see in these installation pics how uneven the header is with itself. The funny thing is that it's the side that wasn't too bad that's leaking.
So basically AVO's warranty as it sits is worthless?
(I did mention this to Paul but at the time he didn't think it would become an issue. )
Old 05-15-2015, 10:36 PM   #1467
protpibe
protpibe's Avatar
It's worth a try but I don't think there's been that many people who have had theirs replaced, myself included.
Old 05-16-2015, 02:05 AM   #1468
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Does anyone know if new headers from later production runs are any better than the headers from earlier runs?
Old 05-16-2015, 02:52 AM   #1469
Astroboy
Astroboy's Avatar
Drives: None
Finally ordered my avo oil cooler kit. To anybody who has installed one, do you have any pointers when installing? Pics maybe?
Old 05-21-2015, 05:32 PM   #1470
aquaman
aquaman's Avatar
has anyone had an issue with the seal where the mechanical pump for the oil return line meets the block? when i get to redline and letoff, there is a drop of oil that comes out and lands on the overpipe and smokes. Is there an OE gasket or that could be used? maybe whatever they use on the automatics? when installed I used high temp RTV sylicone...
aquaman is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
